Old 06-24-2013, 04:56 PM   #1
RYU
RYU's Avatar
Drives: really slow...
Exclamation Racecomp Engineering Springs RCE BRZ/FRS
Yours for $249. These normally sell for $349.
These are the best matched lowering springs to the OEM dampers imho. They are also well matched to the Koni dampers as well. I'm including everything that came with the kit such as RCE custom bumpstops and the dust boot.
• 20mm Drop FRONT and REAR
• 250lb/in rate FRONT and REAR
• Well-matched to OEM Shocks
• Replacement bumpstops included
Lowballers will be ignored but happy to take reasonable offers.
If you are local to socal i'm willing to trade my OEM dampers already pre-assembled with these springs in exchange for your OEM dampers.
RYU is offline   Reply With Quote
Old 07-02-2013, 01:25 PM   #2
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Oh man. I'm tempted! I work in San Clemente and a straight damper/spring swap would be perfect. If you still have these once I get some money in, I'm game.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 07-02-2013, 01:28 PM   #3
Chupacabra
'it's the yeti of Texas'
Chupacabra's Avatar
Drives: 2013 Whiteout 6MT FR-S
@RYU How many miles have you put on these?
BRZerhood & FR-Society
Chupacabra is offline   Reply With Quote
Old 07-02-2013, 02:08 PM   #4
OrbitalEllipses
Drives: Attitude
Irrelevant; good springs don't "wear out" like that.
Old 07-02-2013, 02:27 PM   #5
Chupacabra
Chupacabra's Avatar
I was just curious Orb. I want to give RYU a fair offer.
Old 07-02-2013, 02:28 PM   #6
OrbitalEllipses
Drives: Attitude
I was just trying to say that you shouldn't be concerned about wear and getting ripped off
Old 07-02-2013, 02:30 PM   #7
Chupacabra
Chupacabra's Avatar
Heart you too amigo. And holy free bumps @RYU!
Old 07-02-2013, 02:37 PM   #8
ayau
Drives: Some rust bucket
Won't you be selling your Yellows once you get your Tarmacs?
Old 07-02-2013, 04:26 PM   #9
RYU
RYU's Avatar
I pass by San Clemente at least once a month
Agree, on the wearing out part
Though, I have had springs break on my 1966 Chevelle but those were on 40yr old springs that's been sitting out in the farm somewhere before I bought it.
I doubt these even have any knicks on them. I'm stupid careful and meticulous about installs.
I was starting to wonder why there were so many reply posts and I haven't been getting notified! Then I realized it was all for today. hehehehe
Old 07-03-2013, 12:07 PM   #10
2point0
2point0's Avatar
How much on top of trade are you looking for? Or straight swap? Cuz that I can do without hesitation!
Old 07-03-2013, 01:52 PM   #11
RYU
RYU's Avatar
Straight swap is ok with me. I can do either. No $ charge either way. I'm providing this option as a convenience but I can easily uninstall the spring from the damper also.
Most guys don't have a spring compressor on-hand to uncompress the OEM spring.
I'm passing thru Oceanside tomorrow morning and will be in Encinitas thru Saturday for some surfing! LMK if you want it. I can drop it off your way
Old 07-03-2013, 02:45 PM   #12
bcmakesiteasy
Drives: 2013 FRS Ultramarine
Sorry for the noob question. But what do you mean by the dampener swap? Everything on my FRS suspension is factory, are you trying to swap out your springs and damper for just my oem set up? I'm located in orange county.
FR-S Ultramarine: Berk Technology Dual Exit Muffler delete, all around tint, plasti dipped emblems/rims, ddm tuning HID 6000k kit
bcmakesiteasy is offline   Reply With Quote
Old 07-03-2013, 04:30 PM   #13
RYU
RYU's Avatar
No problem. Let me try to illustrate better.
These springs are designed to be installed using the OEM damper. These springs are specifically designed for either the BRZ or the FRS damper rates.
After uninstalling the OEM damper and spring unit from the car you have to uninstall/uncompress the OEM spring which can be a dangerous job if you do not know what you're doing. Once the OEM spring is removed from OEM damper using a spring compressor then you have to reverse the steps to compress the RCE spring onto the OEM damper again.
It's a easy process if you have the right tools. It's outright dangerous if you do not.
I'm simply offering a plug n' play option if the buyer wants my dampers already preassembled with the RCE springs on them in exchange for their OEM stuff.
I'm assuming most buyers will have relatively low miles on their dampers (like I have) to where the mileage/wear won't really matter to me.
I'm not sure how to describe it any better. If anyone cares to help describe.. please do. thanks!
Old 07-03-2013, 04:43 PM   #14
OrbitalEllipses
Drives: Attitude
Anyone local to you should just go for the direct swap of strut/spring assemblies. Less labor, less time, less hassle, and you only need an alignment at the end.
Compressing the springs requires a [ame="http://www.amazon.com/OEM-25550-Strut-Spring-Compressor/dp/B000CMDPLM"]$20-50 tool[/ame] and an impact gun (directions say no impact guns, but are you REALLY going to try and spin the compressor with a wrench? No you aren't, you lazy bum). It's easy...but it's not exactly fun and it's time consuming. Realistically an assembled set of struts should take less than 2 hours to do from removal to installation. Removing your assembly, disassembling it, removing his, disassembling it, then reassembling both, THEN bolting them to the car is a waste of time if he's offering his assembled struts.
Racecomp Engineering Tarmac Springs forwallblakmail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 03-25-2017 11:40 AM
Racecomp Engineering Yellow lowering springs install special! Racecomp Engineering Mid-Atlantic 12 12-17-2015 01:34 PM
BRZ lowered on RaceComp Engineering springs! OrbitalEllipses Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 03-19-2014 06:26 PM
Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-28-2013 12:22 AM
Racecomp Engineering industrial User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-02-2013 04:17 PM
