#29 | |
Drives: Crystal Black BR-Z Limited
Agreed. The Stoptech Street pads are an amazing pad. They are made with a para-arimid compound which makes them a clean and quiet pad when paired with the performance they offer. They have a Maximum Operating Temperature (MOT) of 1300°F which I believe is the highest of any other Street Pad on the market right now. Price wise, they really cannot be beaten. I've seen a lot of people compare them to the HPS pads, but there really is no comparison. Stoptech did a test of the two pads on their brake dyno and found that the Street pads out performed the HPS pads by 25% from 0-700°F. After 700°F the HPS pads began to fade while the Stoptech pads continued to improve all the way to their MOT of 1300°F. They also work very well at cold start as we have many customers who run these pads in subzero climates. However, if you plan on doing track days, Stoptech does recommend switching out to a dedicated track pad. But even if you have a great brake setup, you still need good tires for them to be effective. |
#30 | |
#31 | |
I'll send them an email and see if they can send me something. I'm sure the brake dyno produces some kind of print out. I have to shoot them an email anyway, I'll ask for that as well in the email. If I get anything, I'll shoot you a PM. |
#32 |
Awesome, thank you!
#33 |
Any recommendation on front pads that will fit my wilwood kit:
http://www.wilwood.com/BrakePads/Bra...emno=150-8946K I'm looking for a good street set with high-performance and also a dedicated track set (full race is fine). I'm about to swap ferodo ds2500s in the rear.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#34 | |
Also, what compounds have you used in the past? What did you like and dislike about each? |
#35 | |
http://www.wilwood.com/BrakeKits/Bra...temno=140-9193 I ran their BP-10 pads that were provided. I got a little fade towards the end of my 4th session at a HPDE over the weekend, they also feel weaker than they did new now. I just want something with more bite and higher heat tolerance. Thanks!
#36 |
PM sent
#37 |
Drives: Raven Scion FR-S
is it 100% necessary to bleed the brakes when installing? what is the reason behind doing this? couldn't i just replace the pads do the break in process and be good to go?
i got the Hawk HPS pads and all my driving is street spirited driving No AutoX ... don't want that embarrassing squeak lmao i hope the hawks don't fail me =/
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#38 | |
2022 BRZ Build 2013 FR-S Build |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Carwash Recommendations | CamryDS | Northern California | 26 | 05-17-2013 10:50 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| recommendations for coilovers..help!! | FRS-HHH | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 10-20-2012 11:11 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
