Old 06-26-2013, 06:53 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Brake pad recommendations.
Title says it all.
If i stick with the stock calipers/rotors for now, what are some good upgrades for the front and rear pads.
Or should i just skip that and put new BBK on all four or front only?
Thanks!
gdrider77 is offline   Reply With Quote
Old 06-26-2013, 07:01 PM   #2
r1concepts
r1concepts's Avatar
I would recommend Stoptech pads to replace the OEM pads. If you're not tracking the car at all, don't waste your money on a BBK. Just replace the lines, rotors, pads, and brake fluid to improve the braking.
r1concepts is offline   Reply With Quote
Old 06-26-2013, 07:05 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
My god this comes up alot. The good thing is I'm starting to see some patterns. Stop Tech, Project Mu, and Ferodo all seem to get the most recommendations.
Myself, I'm a little hesitant to try the Stop Techs because the price seems to good to be true. I fear I'll get what I payed for them. That said, they are cheap enough to take the risk on.
Old 06-26-2013, 07:15 PM   #4
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
The Stoptech's are great pads for the money. We have them on our car with STI Brembo's. They are a notch above the OEM, similar to the Hawk HPS or Project Mu Type NS or B Force.
If you want a pad that can truly run dual duty, cold bite on the street, and can take the heat of the track, the Project Mu HC+800 are killer. They are noisy and dusty though.
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
Calum (06-26-2013)
Old 06-26-2013, 07:20 PM   #5
CSG David
CSG David's Avatar
Originally Posted by gdrider77 View Post
Title says it all.
Thanks!
What type of application are you looking for? Can you breakdown the type of driving you will be doing?
Old 06-26-2013, 07:26 PM   #6
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
stop techs are awesome pads. I never had them fade on me in my STi when i did autox or mountain roads.
bkblitzed is offline   Reply With Quote
Old 06-26-2013, 07:28 PM   #7
Title says it all.
Thanks!
What's your goal?
I don't like blindly making recommendations, when I have no idea what you're trying to accomplish.
Old 06-26-2013, 07:59 PM   #8
gdrider77
gdrider77's Avatar
Thanks for the input all. Guess i should have clarified. I would say at this point 80% street, and 20% track. Although if i start tracking and enjoying it, will probably attempt to start doing that more. Thinking like 2 track days a month for the the next 3-4 months, at least till it starts snowing.
Old 06-26-2013, 08:26 PM   #9
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Again mentioning in previous similar threads. Braking power is cumulative, and a good set of tires is overlooked many times as a big factor in braking performance.
WingsofWar is offline   Reply With Quote
The Following User Says Thank You to WingsofWar For This Useful Post:
cdrazic93 (08-21-2014)
Old 06-26-2013, 08:30 PM   #10
CSG David
CSG David's Avatar
We recommend a dedicated track pad if you intend to track 2 days a month for 3-4 months. That is a fairly aggressive schedule and no street intended compound will sustain your pace long enough to keep you happy.
Old 06-26-2013, 08:47 PM   #11
ModBargains.com
ModBargains.com's Avatar
Stoptech pads are good, Hawk HPS pads would be good as well. I do the same percentage on the track as well, just about, but I went with the Hawk HP Plus pads. The HP Plus pads stop like a mother, but they do squeak and make noise on cold stops in the morning for example, and some other situations. I've never had a pad stop that hard, except for when I did have a Brembo BBK on my previous car with track pads, but for the stock caliper/rotor they are the strongest pads I can find that are good for the street too.
In all honesty, you might be good with just Stoptech OR with the HPS pads if you don't want squeaks and noises.
ModBargains.com is offline   Reply With Quote
Old 06-26-2013, 08:48 PM   #12
I'd recommend getting a pair of pads: a track set and a street set that have compatible bedding.
Carbotech 1521/XP8/10/12
Project Mu NS400/HC+800/HC+/CR/999
Old 06-28-2013, 11:49 AM   #13
gdrider77
gdrider77's Avatar
That was kind of the direction i was thinking, get a set for each application. I was really expecting to be replacing pads after every track day, or at least every month, since that would be around 2 track days and then some minimal daily driving.
Old 06-28-2013, 12:12 PM   #14
If you buy the proper tools, it's super quick.
Lightweight floor jack
Jack stands
Cordless Impact
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Carwash Recommendations CamryDS Northern California 26 05-17-2013 11:50 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
recommendations for coilovers..help!! FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-21-2012 12:11 AM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
