Old 07-01-2013, 12:14 PM   #29
Excelerate
Excelerate's Avatar
Drives: Crystal Black BR-Z Limited
Originally Posted by r1concepts View Post
I would recommend Stoptech pads to replace the OEM pads. If you're not tracking the car at all, don't waste your money on a BBK. Just replace the lines, rotors, pads, and brake fluid to improve the braking.
Agreed. The Stoptech Street pads are an amazing pad. They are made with a para-arimid compound which makes them a clean and quiet pad when paired with the performance they offer. They have a Maximum Operating Temperature (MOT) of 1300°F which I believe is the highest of any other Street Pad on the market right now. Price wise, they really cannot be beaten. I've seen a lot of people compare them to the HPS pads, but there really is no comparison. Stoptech did a test of the two pads on their brake dyno and found that the Street pads out performed the HPS pads by 25% from 0-700°F. After 700°F the HPS pads began to fade while the Stoptech pads continued to improve all the way to their MOT of 1300°F. They also work very well at cold start as we have many customers who run these pads in subzero climates.
However, if you plan on doing track days, Stoptech does recommend switching out to a dedicated track pad.
But even if you have a great brake setup, you still need good tires for them to be effective.
Excelerate is offline   Reply With Quote
The Following 2 Users Say Thank You to Excelerate For This Useful Post:
Calum (07-01-2013), hmong337 (02-18-2014)
Old 07-01-2013, 12:49 PM   #30
CSG Mike
CSG Mike's Avatar
Is there any hard documentation on the MOT? I've never been able to find anything from their current set of marketing materials and I'd love to have that on hand for any clients that have questions. Thanks!
Old 07-01-2013, 05:17 PM   #31
Excelerate
Excelerate's Avatar
I'll send them an email and see if they can send me something. I'm sure the brake dyno produces some kind of print out. I have to shoot them an email anyway, I'll ask for that as well in the email. If I get anything, I'll shoot you a PM.
Old 07-01-2013, 05:29 PM   #32
CSG Mike
CSG Mike's Avatar
Awesome, thank you!
Old 07-01-2013, 08:34 PM   #33
swift996
swift996's Avatar
Awesome, thank you!
Any recommendation on front pads that will fit my wilwood kit:
http://www.wilwood.com/BrakePads/Bra...emno=150-8946K
I'm looking for a good street set with high-performance and also a dedicated track set (full race is fine).
I'm about to swap ferodo ds2500s in the rear.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-01-2013, 08:44 PM   #34
CSG Mike
CSG Mike's Avatar
Can you get me a caliper model please? I'm not specifically familiar with wilwood pad numbers.
Also, what compounds have you used in the past? What did you like and dislike about each?
Old 07-01-2013, 08:48 PM   #35
swift996
swift996's Avatar
Sorry I'm a little new to aftermarket brake options, here is the kit with details on the caliper:
http://www.wilwood.com/BrakeKits/Bra...temno=140-9193
I ran their BP-10 pads that were provided. I got a little fade towards the end of my 4th session at a HPDE over the weekend, they also feel weaker than they did new now. I just want something with more bite and higher heat tolerance.
Thanks!
Old 07-01-2013, 08:59 PM   #36
CSG Mike
CSG Mike's Avatar
PM sent
Old 08-21-2014, 02:59 PM   #37
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
is it 100% necessary to bleed the brakes when installing? what is the reason behind doing this? couldn't i just replace the pads do the break in process and be good to go?
i got the Hawk HPS pads and all my driving is street spirited driving No AutoX ... don't want that embarrassing squeak lmao i hope the hawks don't fail me =/
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 08-21-2014, 03:54 PM   #38
DarkSunrise
DarkSunrise's Avatar
Not necessary to bleed them. Keep an eye on your reservoir though. If your old pads were worn, you could get fluid backup as you compress the pistons.
2022 BRZ Build
2013 FR-S Build
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Carwash Recommendations CamryDS Northern California 26 05-17-2013 10:50 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
recommendations for coilovers..help!! FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-20-2012 11:11 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
