CANADA Canada
Old 04-23-2013, 11:53 AM   #43
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I've had it since I picked up the car, I thought it was just the Petro 94 issue which is what I think they put in when I first got it. I switched to Shell 91 immediately when I emptied the tank, on my 3rd fill-up 1250~KM still have the chirp, but it wasn't the same chirp as before I think. It was a lot worse on my first tank. I figure I'll drive to 2,000KM before I take it in for the chirp check.
Originally Posted by grgonium View Post
Started to get Chirping within past month. Fill gas with Shell 91. No Ethenol.
Went to dealer yesterday, and chirping went away. Go figure. Lucky i took a video earlier in the week. It's the Fuel Injection that's causing the chirp.
Under Warrenty, so geting it replaced as we speak.
Which dealership did you go to?
Myv is offline   Reply With Quote
Old 04-23-2013, 12:15 PM   #44
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
My car does the same, it chirps very loud when using 94 and the sound is very high pitch.
When I switch to V power, the chirp becomes a lot more quiet, almost faints in the background, and not as high pitch.
shu5892001 is offline   Reply With Quote
Old 04-23-2013, 12:28 PM   #45
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
Don Valley North Toyota/Scion
grgonium is offline   Reply With Quote
Old 04-23-2013, 05:38 PM   #46
P5yk0t1c
Drives: 2014 FR-S
Originally Posted by ottopilot View Post
I've been using Premium Petro-Canada since the beginning and not a sign of chirping @ 3000 KM so far...the engine has a pretty loud clicking to it but it seems to come from the DI injectors, probably normal since DI engines sounds like crap.
Dido. I have been using the 94 Octane Petro-Canada stuff and she has never sounded so good!!
P5yk0t1c is offline   Reply With Quote
Old 05-03-2013, 11:40 AM   #47
solution
solution's Avatar
Drives: Scion FRS
Totally agree with this guy.. I used Petro when I first got my car. Chirping started at about 5000km. Stopped using Petro and went to Esso with the odd time at Shell 91 octane and Chirping was gone.
Originally Posted by DjDATZ View Post
From personal experience here's my anecdote:
- I started using Esso when I got my car, no chirping
- Then switched to Shell due to the premium not having ethanol in it, and didn't notice a change.
- Then went to Petro for 2 fill-ups because I couldn't find a Shell when I needed gas.
- With Petro I could hear my car starting to chirp.
- Switched back to Esso and since then, no chirping.
No evidence from this, take from it what you want.
solution is offline   Reply With Quote
Old 05-05-2013, 11:12 PM   #48
mashal
DADA
mashal's Avatar
Drives: 2013
I worked for Shell for many years, I've tried every gas company in Alberta. Shell has given me the best mileage and performance for my FRS now and for all the previous cars I've owned.
Not being biased , but I would not fill up anywhere else unless I was out of gas.
mashal is offline   Reply With Quote
Old 05-06-2013, 07:56 AM   #49
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Been using Shell, but I have been consistently that when I gas at this one gas station, it chirps. I am suspecting that that shell is selling non-premium as premium gas! Do not GO!
Green Lane and Yonge
https://maps.google.ca/maps?client=f...d=0CJwBEPwSMAA
Chinadian is offline   Reply With Quote
Old 05-11-2013, 09:22 AM   #50
Skurj
Drives: SOLD...
Filled with petro can 94 on Thursday, and for the first time I noticed the chirp on Friday while sittin in the drive thru. Was in for my first service today (5250kms) and they have a service bulletin so they have ordered the part for me. Service guy said he hadn't heard about this before.
BTW this is C&C Subaru in Whitby
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 05-11-2013, 09:33 AM   #51
Burrcold
Drives: Subaru BRZ Limited
I've found the exact same thing. Petro Canada and a get chirps, Shell and Esso they completely go away. I've been tracking my chirping and station use as notes when I use Fuelly.
Old 05-17-2013, 06:10 PM   #52
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
I just filled up my tank using Petro 94 for the first time (been using Costco 91 all winter and Esso last summer) and I heard the chirping for the first time yesterday. I'll definitely be trying Shell once I empty this tank.
D18 is offline   Reply With Quote
Old 05-20-2013, 08:52 AM   #53
minus220
minus220's Avatar
Drives: Scion FR-S
so I got my fuel pump changed out maybe a month ago for the chirping and after about 1100 km it started again, been using the ultra 94 the whole time and by chance ran out of gas and had to stop at shell used their 91 with 0E and it doesn't chirp. I went back and forth a few with a few tanks to see and it's the ethanol that's making mine chirp for sure.
if u read the main post for this issue most people agree it's the ethanol.
minus220 is offline   Reply With Quote
Old 05-20-2013, 09:35 AM   #54
df.dima
Drives: FR-S and Mazda 3 Sky
I've been exclusively on Shell 91, I started getting chirps this year after longer drives, especially when its hot. Same station all the time, I might try another one, just to see if it makes a difference. Doesn't bother me much, looks like its not a sure fix to get a "newer" pump, so I'm holding off on asking for a fix.
df.dima is offline   Reply With Quote
Old 06-30-2013, 01:48 PM   #55
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Okay... so I don't believe it's the ethanol since our neighbours in the U.S. have guys running E85 tune and they seem to be fine.
hmong337 is offline   Reply With Quote
(TSB) No More Crickets Under My Hood!! xpicer Issues | Warranty | Recalls / TSB 1140 12-04-2015 08:53 AM
Fixing Red stitching? Tigranakert Cosmetic Modification (Interior/Exterior/Lighting) 10 11-01-2012 02:52 PM
fixing your car at a dealership? jarviz Scion FR-S / Toyota 86 GT86 General Forum 21 10-18-2012 11:11 AM
Fixing the radio antenna CyberFormula Electronics | Audio | NAV | Infotainment 19 05-07-2012 07:21 PM
Why fixing your car is fun OldSkoolToys Other Vehicles & General Automotive Discussions 134 05-04-2011 05:50 PM
