Old 05-26-2013, 02:32 PM   #351
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Where did you purchase the sensor and pins?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 05-26-2013, 02:38 PM   #352
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I ordered the sensor from Subaru Parts Warehouse (10% discount this weekend), and the pins I'm getting from Tweaked Performance.
kmbkk is offline   Reply With Quote
Old 05-27-2013, 08:48 AM   #353
fulofbrightnes
Drives: 2013 scion fr-s ultramarine
so have we figured out that the wires are not there from the factory and we will have to run the wires to the bcm in order for it to work?
fulofbrightnes is offline   Reply With Quote
Old 05-27-2013, 11:18 AM   #354
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
The wires for the auto function are NOT there. You'll need to add 3 wires from the sensor to the MB ECU, and 1 wire from the stalk to the MB ECU. I have a separate thread on this and will update it once I get the parts I need for install.
The Following 2 Users Say Thank You to kmbkk For This Useful Post:
civicdrivr (05-27-2013), Dadhawk (05-27-2013)
Old 06-02-2013, 04:55 PM   #355
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
If anyone is planning to install EDM/JDM headlights with auto level, looks like there will not be any harnesses available for plug and play.
Anyone with GT86 headlights can confirm what the grey connector is for? and if they also have the same plastic capped wire bundle?
iketiak is offline   Reply With Quote
Old 06-30-2013, 11:51 AM   #356
tonystewart
Thanks to all for their efforts and guidance.
Will FRSFirestorm ever has his pictures again?
Old 06-30-2013, 11:52 AM   #357
tonystewart
Any updates?
Old 06-30-2013, 04:12 PM   #358
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Nah, I've been out of town the past 3 weeks. I haven't been able to find a connector for the sensor. Worst case I connect the wires directly to the sensor.
Old 10-30-2013, 09:27 AM   #359
Imperius
Imperius's Avatar
Drives: Subaru BRZ
is there a similar option for BRZ ? or dose one need to pay 300usd for the original kit ?
Imperius is offline   Reply With Quote
Old 11-15-2013, 09:17 PM   #360
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
Let me see if I got this straight. Just use the H11 connectors from the fogs, run hot wire to white/red on passenger side, and red/white on drivers side, ground the fogs and I'm done? Fogs will come automatically come on with the headlights?
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 12-26-2013, 01:19 AM   #361
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
what wire do I tap into to make the fog indicator on the dash illuminate? I already have the fogs installed with the push button switch.
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 12-26-2013, 12:01 PM   #362
jonzhuxD
Drives: Ultramarine FR-S
By push button switch do you mean through the USDM fog light kit? I don't think there's any way to have the dash light illuminate with the fogs without using either the harness the USDM foglight kit uses or pin #4 on the turn signal socket
jonzhuxD is offline   Reply With Quote
Old 12-26-2013, 03:44 PM   #363
AG3NT_5CARFAC3
Drives: Toyota GT86
This is where I put my on/off switch:
It would just be nice that when the switch is pushed in (fogs are on), the fog indicator on the dash would also come on; I'm sure it can be done, I just dont know what wire I would have to tap into to make that work.
Old 12-26-2013, 08:36 PM   #364
jonzhuxD
Attachment 61249
How is the switch hooked up? Directly to a relay to the fogs or through a factory harness? I don't think you can get the indicator to illuminate if you don't use any factory wiring in your install
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
