go_a_way1
Old 06-29-2013, 02:37 PM   #309
fenton
Well the good thing is when I'm in first gear the tires let go first :-)
Sent from my HTC One using Tapatalk 2
fenton is offline   Reply With Quote
Old 06-29-2013, 02:40 PM   #310
Levi
Drives: Toyota
Very interesting. Too bad nobody (company OEM or supplier) researched on alternative FI possibilities. I remember AMG did something with a Pressure Wave Supercharger, but the development was not advance enough, so the A 45 AMG ended up with a conventional 2.0 Turbocharged I4 making 360 PS.
@fenton: How does the engine sound at full throttle when the supercharger is spinning? Like a normal supercharged engine or like a turbocharged engine? Does is sound as good as naturally aspirated?
There are rumors the new M3 so as the new WRX will have electric supercharger assissted turbo engines to totally eliminate that well known turbo-lag.
Levi is offline   Reply With Quote
Old 06-29-2013, 03:08 PM   #311
fenton
It sounds like the vortech cars... Which is to say they basically sound NA.
You can hear the movement of additional air and you feel the torque.
I'm going to swap in a K and N panel filter that might increase induction noise.
Old 06-29-2013, 03:32 PM   #312
mid_life_crisis
Drives: FR-S 10 #103 AT
All the posters talking about wanting to tie the electrocharger to the throttle so it is always running and its speed is linked to throttle position are overlooking the discussions about current electrical storage technology. In a few years it may no longer be an issue, but for now the system has to be part time so the batteries have a chance to recharge (which happens surprisingly fast) between full throttle runs. I've driven both manual and automatic versions of the FR-S and under normal, just putting around town type driving, the dreaded torque dip is not an issue. When you get spirited the electrocharger does wonderful things for the power curve, so full time running is not necessary.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following 2 Users Say Thank You to mid_life_crisis For This Useful Post:
fenton (06-29-2013), SpyderMS (08-30-2013)
Old 06-29-2013, 03:41 PM   #313
fenton
This is bang on. The amount of capacity you would need to run full time would outweigh the gains.
The system that we will be testing next week that looks for negative pressure between the charger and throttle body and adds a small amount of boost(raises to atmospheric pressure really) should be a nice stop gap.
Old 06-29-2013, 03:48 PM   #314
mid_life_crisis
The dyno chart we really need is no electrocharger compared to installed electrocharger but not engaged.
Old 06-29-2013, 03:57 PM   #315
Levi
Drives: Toyota
It could also be done thanks to brake-energy-regeneration, and this already exists on many cars.
Old 06-29-2013, 03:58 PM   #316
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
@fenton could I get a ride along sometime in the near future? I'm in Calgary often.
Cool project
Lawnik is offline   Reply With Quote
Old 06-29-2013, 04:11 PM   #317
fenton
I can see where your coming from but that isn't the main point of the system. How many times do you take your car to redline at 80 percent throttle?
I think the most important part is that daily driving isn't affected and when you want the power it is there.
At the top end the compressor will be holding the engine back a bit until it is engaged. That is where the pressure loss system is going to come into play.
Honestly before 4500 rpm you can hardly notice a difference because the engine isn't flowing much and that's where people daily drive if not even lower.
Videos will explain all in the end
Old 06-29-2013, 04:12 PM   #318
fenton
Cool project
Sure thing I don't mind. Planning on meeting up with Bu-Tang next week sometime as well. His buddy in a s2000 wants to race. I was all for it until he told me has comtech centi supercharger at 7 psi. Haha
Old 06-29-2013, 04:16 PM   #319
FT_Monk
Drives: Over the hill WRX
Originally Posted by DylanFRS View Post
Pretty cool, I was definitely skeptical at first but glad to see the results!
BTW, love the haters on the thread for the first half, then dyno results, then silence from the haters.
That just means that the "haters" are not haters at all. They are skeptical but not in denial when proofs are available. Unlike blind believer who always responded to skeptical questions or comments with hissy fit.
I am sure most people wants this to be successful; it is in their interest too. No one in their right mind is going to reject a SC system that is easy to install and has instance boost. There are obstacles to overcome, but this system is a good first step. I think.
FT_Monk is offline   Reply With Quote
Old 06-29-2013, 04:18 PM   #320
jamesm
Moore's Law may not apply to batteries, but with all the money getting dumped into that area of research and recent advances, it would be wise to think a bit ahead when developing something that could be finished a few years from now. There are batteries being developed right now with thousands of times the energy density and charge rate.
here is one example.
so the time will come that full-time operation and much higher boost is feasible. until then, it would be cool if you could have a switch like KERS along with the throttle switch
Old 06-29-2013, 04:18 PM   #321
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I don't think many people are saying to tie it into the thottle so its on all the time, but rather so that it can activate at some point before WOT and possibly provide a little more dynamic and progressive control over the motor when it is in use.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
ATL BRZ (06-29-2013), Calum (06-29-2013)
Old 06-29-2013, 04:25 PM   #322
ft_sjo
Drives: GT86
You have to remain open-minded. You could always run it at ~14v from the primary starter battery at low boost levels and then switch to the 'power pack' under higher load conditions. Lots of ways to do it.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
