Old 06-28-2013, 09:32 AM   #197
Rinzler
Rinzler's Avatar
Drives: BRZ Limited
Originally Posted by Foobar View Post
Tap into pin 7 of the 16 pin harness on the HU. David sells the pin connected to a wire if you need it. It produces 6 volts so make sure your camera can take that.
Sent from my Nexus 4 using Tapatalk 2
Wire the camera power wire all the way up to the headunit?
My friend tried tapping the power it into what I believe is what of the amp 6v wires for the speakers. Works fine, but I guess with speakers loud, it starts cutting out.
So I guess now I need to fix that at some point.
Rinzler is offline   Reply With Quote
Old 06-28-2013, 10:54 AM   #198
Foobar
SLO NO MO
Foobar's Avatar
Your options are go back to the head unit so that it is powered only when transmission goes into reverse (preferred method so as to prolong the life of your camera), go back to the fuse block and run a new fuse to accessory (camera will always be powered on with car), or tap into the 12v that goes to the amp in the trunk. Also on whenever the car is powered. I don't remember which pin it is on the amp, but it was discussed in one of these threads before. I think it was a green wire.
Old 06-29-2013, 02:01 PM   #199
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Originally Posted by michaelahess View Post
I did this the same way. I used an old female RCA plug instead of stripping the Rydeen wire.
If it helps anyone, in the above shots:
Gray: 3rd from left, if you ground this you will bypass the brake lockout of video/nav.
Red: 2nd from left, this is the power. For a Rydeen duo, you ONLY NEED THIS POWER; you tape off the other. No need to connect it to the rear amp/etc.
Pink/Black: 1st from left, and LOWER 1st from left. This is only pink (I believe) because the Rydeen's is pink. I didn't strip the Rydeen, so I can't be 100%. The picture is unclear though so...
When you strip an rca style video wire it has an outer sheath of metal and then another wire (unstripped) inside. So you have to strip it; pull the sheath of wire and twist it up, and then strip the inner wire. The inner wire goes into the top, and the outer sheathing goes into the bottom; that's what your seeing above.
So wiring wise:
1. Attach the ground wire where appropriate.
2. Tape off the 'brake light' red wire.
3. Run the red brake wire into the 2nd from left slot.
4. Strip or convert the RCA wire into two wires and put inner in top and outter in bottom 1st slots.
5. You'll want to glue gun or otherwise secure the wires.
I really like this install and the Rydeen product.
GeorgeJFrick is offline   Reply With Quote
The Following User Says Thank You to GeorgeJFrick For This Useful Post:
michaelahess (06-29-2013)
Old 06-29-2013, 03:49 PM   #200
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
The RCA I cut up for this had the pink, didn't strip the Rydeen either. The insulated wire on an RCA cable will always be the center conductor and the non insulated will be the ground or outer portion of the RCA. Using a "dongle" like this is much preferred as it's a fairly simple disconnect if you need to remove or preposition the cable at a later time.
I also hot glued the hell out of the back of that connector to hold everything in.
Thanks for explaining my pictures better than I could! :happy0180:
michaelahess is offline   Reply With Quote
The Following User Says Thank You to michaelahess For This Useful Post:
GeorgeJFrick (06-29-2013)
Old 07-09-2013, 11:13 PM   #201
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Does anyone have phone # for Dave at Svxdc? I try to order a harness from him but he never answer his email or reply my PM to him. Thanks
Anyone get theirs yet? I can't get a response from svxdc via e-mail.
#944_10_Series_FRS is offline   Reply With Quote
Old 07-21-2013, 05:15 PM   #202
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
camera just stopped help!!!
so i had mine all wire up and working perfect. just had video and anode power wired in front of stereo to test before finishing up. so disconnected those 2, ran behind stereo, and now my camera wont turn on. no wiring setup was changed and all cables still have power, but the camera doenst come on when i go into reverse now. the headunit acts like it's not even there. anybody have any ideas what's wrong
lbroskee is offline   Reply With Quote
Old 07-23-2013, 08:21 AM   #203
boatski
Drives: Dark Gray Metallic Limited
He took about five days to get around to answering my emails. Once he did answer, he was quick to reply and fast to ship.
boatski is offline   Reply With Quote
The Following User Says Thank You to boatski For This Useful Post:
#944_10_Series_FRS (07-23-2013)
Old 12-08-2013, 11:56 AM   #204
davesbrz
davesbrz's Avatar
Drives: '14 SWP BRZ
Painting a Rydeen duo
Has anyone tried to paint one of these cameras?
I am thinking that it wouldn't be so difficult for me to mask the camera hole and get a rough match to SWP and make this camera look less visible.
Opinions? Suggestions?
Thanks!
davesbrz is offline   Reply With Quote
Old 12-15-2013, 10:27 PM   #205
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
I have that question too. I'm actually surprised to see so many pics of white BRZ/FR-S with a black rear cam. It stands out too much IMHO.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 12-19-2013, 02:17 PM   #206
davesbrz
davesbrz's Avatar
Drives: '14 SWP BRZ
If anyone is looking for the Rydeen Duo, its available via Amazon Marketplace from merchant = Adventurers Bag for $82 with fast FedEx shipping (+$10)
[ame="http://www.amazon.com/Rydeen-RYD-ZH07150B-NightVision-Technology/dp/B00GQTYG3Q/ref=lh_ni_t?ie=UTF8&psc=1&smid=A21C4U5X700J66"]Linky[/ame]: < [ame="http://www.amazon.com/Rydeen-RYD-ZH07150B-NightVision-Technology/dp/B00GQTYG3Q/ref=lh_ni_t?ie=UTF8&psc=1&smid=A21C4U5X700J66"]Amazon.com: Rydeen RYD ZH07150B Universal Mini Camera, CMOS III NightVision Technology: Camera & Photo[/ame] >
Has anyone tried to paint one of these cameras? ...
BTW, per previous post #204, I am planning on painting this thing white. I just have to be super careful when I mask the lens.
Old 12-20-2013, 08:06 AM   #207
dontpanic
Drives: shiny side up.
Conflicting specs on Rydeen Duo - their lit has it as a 12v unit:
http://www.rydeenmobile.com/downloads/DUO_Cam.pdf
Has anyone used this camera?
http://www.ebay.com/itm/Genuine-Suba...-/181211991004
dontpanic is offline   Reply With Quote
Old 12-20-2013, 08:16 AM   #208
ImSixString
ImSixString's Avatar
Drives: WRB BRZ Premium & 2008 YZF-R6
The Rydeen Duo works, used it on my BRZ using the 6v out from the stock head unit.
Sent from my DROID RAZR using Tapatalk
ImSixString is offline   Reply With Quote
Old 12-21-2013, 08:13 PM   #209
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Just ordered a Rydeen DUO and sent an email to 96svx.dc requesting a 16 - pin rear camera harness plus the power wire. Been wanting to do this install for a while. Thanks to everyone who posted info on how to do it.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 01-06-2014, 08:18 PM   #210
davesbrz
davesbrz's Avatar
Drives: '14 SWP BRZ
Thanks!
Okay - did it. Pic below shows the painted Rydeen duo mounted on a SWP BRZ limited.
The Following User Says Thank You to davesbrz For This Useful Post:
Marcoscrdo (01-07-2014)
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
