Old 06-28-2013, 12:35 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
brighter fog light bulb for BRZ?
can anyone recommend a brighter fog light bulb for the BRZ that i can just plug it in with minimal work required?
I put yellow overlay on my fog lens and noticed that the stalk light bulb doesn't shine through enough. I need a brighter bulb. thanks
chenshuo is offline   Reply With Quote
Old 06-28-2013, 01:18 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You're kinda out of luck with the stock housing. If you really want them functional, I'd recommend either upgrading to the Outback foglights which use real headlight bulbs, or Hella 3" aftermarket replacement fogs.
Old 06-28-2013, 07:11 PM   #3
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
what year? thanks!
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 06-28-2013, 07:20 PM   #4
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
I went with this setup. Nice and bright
Bulbs
http://www.ebay.com/itm/Narva-H11-12...item5895eaaf5f
Fog assembly
I'm using the 2010-2012 Outback fog lights, they have a glass front and use the H11 bulb.
Wiring adapter for H11 so they are plug and play..no cutting.
http://www.ebay.com/itm/111040380281...84.m1555.l2649
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 06-29-2013, 07:07 AM   #5
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I'm surprised that Subaru took so little time to match the color of the fog lights to the other lights. Other other lights are bright white LED's and then we have very red looking (by comparison) 20th century technology for fogs. It's something I've noticed, made a mental note to change, but haven't taken any action.
I'm assuming that there aren't any drop-in LED replacements?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-29-2013, 08:17 AM   #6
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
LED Fog Light Bulb at Diode Dynamics. Just pick up their Stage 2 option and you should be good.
Skippman is offline   Reply With Quote
Old 06-29-2013, 12:21 PM   #7
infinite012
Drives: 13 DGM BRZ Ltd
Red? Are you color blind? They're yellow.
infinite012 is offline   Reply With Quote
Old 06-29-2013, 02:21 PM   #8
Gary in NJ
Gary in NJ's Avatar
Red spectrum. ROYGBIV
Old 06-29-2013, 02:48 PM   #9
infinite012
Fixed.
Old 06-29-2013, 03:31 PM   #10
crazyprac
Drives: WRB BRZ
bright enough with yellow overlays?
crazyprac is offline   Reply With Quote
Old 06-29-2013, 06:32 PM   #11
Skippman
Skippman's Avatar
The Stage 2 bulbs are supposed to be much brighter than factory lights. They have a money back guarantee.
Old 06-29-2013, 11:37 PM   #12
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
are you referring to their LED fog light bulb? is it plug and play? I heard from my dealer that installing LED bulbs can mess up electrical system.
Old 06-29-2013, 11:49 PM   #13
Skippman
Skippman's Avatar
Yes, it is plug and play. The only thing that might mess up electrically when using LED bulbs is something called hyper blinking. This occurs when you replace the turn signals without also replacing the relay. Take a look at Diode Dynamics or any other LED light retailers web site on here and you will see installation instructions and videos.
I do not work for Diode Dynamics or am affiliated with them in any way. Just attempting to present you a reasonable cost solution.
Old 06-30-2013, 08:03 AM   #14
Gary in NJ
Gary in NJ's Avatar
From Diode Dynamics website.
"Please note that LED fog lights are for cosmetic purposes only, and will not project light in the same way that the factory bulbs do. Your car will look great at night, but if you are looking for higher output, we strongly recommend using an HID conversion.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity."
How to change BRZ fog light bulb? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 19 05-30-2020 05:31 PM
Fog light bulb size? huma Cosmetic Modification (Interior/Exterior/Lighting) 19 01-22-2015 05:57 PM
Light bulb question 86driver Cosmetic Modification (Interior/Exterior/Lighting) 0 05-14-2013 01:48 AM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 08:59 PM
BRZ signal light bulb ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 8 06-20-2012 01:26 AM
