Old 06-28-2013, 08:40 PM   #281
s0sl0w
Proud of Boxer
I'm very interested in this...
s0sl0w is offline   Reply With Quote
Old 06-28-2013, 08:43 PM   #282
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Originally Posted by uspspro View Post
Can't ECUtek handle an analog output based on a 2-parameter table?
The analog output could be fed to some controller, calibrated such that it properly controls the power of the electric motor.
Needs to be a digital output
Old 06-28-2013, 09:32 PM   #283
Whitigir
Drives: 450 awhp twin turbo vr4
Thanks fenton. So it works under WOT only ? Is it possible to dyno the car without going WOT ?
I am interested in seeing a normally driven condition power and torque curves ! Also To see how the system cope with low battery conditions.
I appreciate your works and results
Whitigir is offline   Reply With Quote
Old 06-28-2013, 10:32 PM   #284
nonicname
Drives: it has 4 wheels and a motor
I can see the future of these Electric SCs!
someone needs to make those Carbon batteries prototyped by LG available now!
they charge in seconds and they are super light.
nonicname is offline   Reply With Quote
Old 06-28-2013, 10:37 PM   #285
unijabnx2000
unijabnx2000's Avatar
Drives: Nissan
Sounds like LG makes those batteries...
unijabnx2000 is offline   Reply With Quote
Old 06-28-2013, 11:03 PM   #286
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Hmmmm.... Could be an excellent application for ultra-capacitors.
Old 06-28-2013, 11:14 PM   #287
jamesm
It's easy enough to read off on CAN/OBD2 with a raspberry pi or arduino that the ecutek isn't even necessary. I get really fast response reading both (when watching just a few PIDs. You could handle the whole thing probably with an arduino alone if you had a schematic for the speed controller from the kit.
Old 06-28-2013, 11:17 PM   #288
fenton
Originally Posted by Calum View Post
I'd think something to ease it in to operation would be easier to tune, easier on the engine, easier on the motor, and easier to drive. There's just so many possibilities here, if a plug and play EBC can be produced, why not a plug and play controller that is run by the ECU? I realize that's alot more complicated and more money, it's just awesome to dream about where this technology can go in the near future.
Well you can feel it kick on its not like BAM 190 ft pd. I'm just trying to stress that it's no where near a turbo where there is 1 to 2 seconds lag.
You hit the switch and it spools right away.
Sent from my HTC One using Tapatalk 2
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Calum (06-29-2013)
Old 06-29-2013, 12:46 AM   #289
fenton
The videos that I'm going to work on this weekend will show normal driving. This system is on demand. When you want it you push it down and you are greeted by a heard of magically Internet unicorns haha :-)
I can't stop driving the car, it's just a blast to go part throttle up to 3500 rpm and matt it, at 4500 rpm we are up 60 HP from stock.
Took the fiancé out for a drive today..... I got the "what happened to this car it feels like the subaru" my last car was a stage 1 2011 sti sedan. :-)
Old 06-29-2013, 01:13 AM   #290
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Pretty cool, I was definitely skeptical at first but glad to see the results!
BTW, love the haters on the thread for the first half, then dyno results, then silence from the haters.
DylanFRS is offline   Reply With Quote
Old 06-29-2013, 01:40 AM   #291
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by d1ck View Post
If they ever get thermo-electric generators cheap enough to use in automotive applications these could be a viable replacement for turbos. Almost a third of the fuels energy is blown out the exhaust in the form of gas flow at high temperature.
This setup could be very cool.
While you might consider exhaust gas very hot, it's not nearly as hot as the temperatures that fuel is typically burned at to generate power. To generate a significant amount of power one would need rather large heat exchangers.
However I'd love to have a TEC setup to power the electrical system. That would be pretty neat, and if you're careful you could get such a contraption pretty close to the weight of a bigger alternator. Maybe in a few years we'll be able to buy such a thing, or at least get the parts to put one together.
Old 06-29-2013, 02:13 AM   #292
fenton
I was a hater / disbelieve too until I saw it perform on the dyno. This system is impressive for the investment for sure. We are talking almost 90tq and 60 HP in parts of the band for.... Not much at all.
Dollar to performance is through the roof on this one guys.... I'm pumped to be a part of this.
This is on the first installation with stock tune!
Old 06-29-2013, 02:16 AM   #293
fenton
Keep in mind this is with the addition of maybe 5 pounds because the stock battery is replaced with the triple battery.
Going to visit the scale tomorrow
Old 06-29-2013, 02:28 AM   #294
ft_sjo
Drives: GT86
What IAT's are you logging?
And when is someone going to make a proper controller for it so you can have turbo speed/pressure controlled by tps/rpm?
The Following User Says Thank You to ft_sjo For This Useful Post:
Calum (06-29-2013)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
