Old 06-26-2013, 08:40 AM   #15
FR-S Matt
Mind = blown after reading this post.
Old 06-26-2013, 09:08 AM   #16
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
http://www.ft86club.com/forums/showthread.php?t=39769
Originally Posted by Frsexxxy View Post
So I just welded my srt exhaust in place, and just now ordered my ft86club catted headers to add on.
I don't know anything about the SRT exhaust, but it's a bolt-in deal, right?
Old 06-26-2013, 09:14 AM   #17
Foobar
SLO NO MO
Foobar's Avatar
Wait, what? Why would you weld headers on to your block? And I also see that you've welded your SRT exhaust in place, welded on to what?
Old 06-26-2013, 09:20 AM   #18
JiB
JiB's Avatar
Drives: GT86
Da fuq did i just read
JiB is offline   Reply With Quote
The Following 4 Users Say Thank You to JiB For This Useful Post:
ATL BRZ (06-26-2013), FRSPirate (06-26-2013), TheSlickOne17 (06-26-2013), wparsons (06-26-2013)
Old 06-26-2013, 09:28 AM   #19
vgi
Drives: frs
Originally Posted by GTB/ZR-1 View Post
I have welded together every single mating surface on my car that didn't melt in the process...
My car will NEVER, EVER come apart!!! lol
duh! for melting parts you should've used special type of welding called J-B!
vgi is offline   Reply With Quote
Old 06-26-2013, 09:28 AM   #20
xjohnx
Grip>Slip
xjohnx's Avatar
That's just plain insanity. Welding them to the block. I was just bicurious because I've seen people weld them to blocks, which I find crazy and wanted to know if bolting them on will be as safe
Please don't take offense to this question, but where the hell have you seen people weld headers to their blocks?
This is a photo of a Cosworth F1 engine. Take note of how the header (exhaust manifold) is bolted to the block. If it's good enough for F1, it's good enough for your 86.
Bolt them on. Your factory headers are bolted on and are fine, the FA20Club header will be the same. Put new gaskets on and you should be golden. You could probably even reuse the OEM gasket, but as cheap as they are, i'd put new ones on the first time.
Frsexxxy (06-26-2013)
Old 06-26-2013, 09:51 AM   #21
rx3
You couldn't weld them onto the block even if you wanted to, as the block consists of aluminum and the header consists of steel.
rx3 is offline   Reply With Quote
The Following User Says Thank You to rx3 For This Useful Post:
DylanFRS (06-26-2013)
Old 06-26-2013, 10:01 AM   #22
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Is this code for butt sex? Can't keep up with the lingo.
industrial is offline   Reply With Quote
The Following 3 Users Say Thank You to industrial For This Useful Post:
GeorgeJFrick (06-26-2013), Sportsguy83 (06-26-2013), wparsons (06-26-2013)
Old 06-26-2013, 10:35 AM   #23
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Ohh baby.. I want to weld my header to your exhaust port!
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 06-26-2013, 10:39 AM   #24
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Psh you fools are still running steel headers? You should use aluminum headers for ultimate weight savings and reliability.
No Limit Motorsport is offline   Reply With Quote
Old 06-26-2013, 10:44 AM   #25
SloS14
SloS14's Avatar
I welded a turbo to a manifold before. I'm not proud of it but it happened. 16g CRV
Old 06-26-2013, 10:54 AM   #26
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
The OP may mean did you weld you header to the overpipe
Fett4Real is offline   Reply With Quote
Old 06-26-2013, 10:59 AM   #27
Frsexxxy
Drives: White Virgin frs
Onto my drive shaft
Frsexxxy is offline   Reply With Quote
Old 06-26-2013, 11:01 AM   #28
FRS-Chief
Drives: 2013 FRS
If you buy a quality header and use new quality gaskets you shouldn't need to weld them. You can weld aluminum to steel but the process isn't easy.
FRS-Chief is offline   Reply With Quote
gloriously dipspastic
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 09:43 AM
Weld Drag Rims JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-12-2014 09:24 AM
Headers cuddefred AUSTRALIA 4 05-25-2013 07:16 PM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 10:36 PM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 09:12 PM
