Old 06-06-2013, 05:43 PM   #1
JerryMichaels7
Drives: Whiteout FRS
Weld Drag Rims
Anyone know or not if its possible to fit 15x10's on the back? and if so what backspacing
JerryMichaels7 is offline   Reply With Quote
Old 06-06-2013, 07:51 PM   #2
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
i'd say maybe about 8 or so inches maybe?
i had a 18x11J +25 on the rear and the barrel was hitting the wheel well at -10 degrees of camber, and had to dial it down to -9.5
On the wheel i have 7" of backspacing, but with all that negative camber i think we can fit maybe an inch or two more of backspacing with a very low negative camber setup. Hope this helps
SLICVIC is offline   Reply With Quote
Old 06-06-2013, 08:24 PM   #3
JerryMichaels7
outside off the wheel well?? width wise from what i have seen its not crazy. I am more worried about the wheel being 15 inches, i know i seen one but it was 15x6 and this is strictly for 1/4 use
Old 06-12-2014, 08:24 AM   #4
Fear
Drives: Ft86
that's what i'm trying to figure out. what is proper back spacing
Fear is offline   Reply With Quote
FS:17x8 35mm offset Drag Rims in flat black Ryeong86 Wheels and Tires 1 06-06-2013 06:19 PM
FS: 17x8 35 offset Drag rims with tires Ryeong86 Wheels and Tires 4 05-31-2013 08:55 PM
Opinion on running 17x7 et40 drag dr9 white rims FRSFOB Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-13-2013 07:10 PM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 09:36 PM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 08:12 PM
