Old 05-27-2013, 11:01 AM   #43
eckoflyte
Drives: Toyota 86 GTS
Any updates on these? Curious to what eta is of possible. Cheers
eckoflyte is offline   Reply With Quote
Old 05-28-2013, 09:59 AM   #44
Raceseng
Raceseng's Avatar
We have prototype sets installed on the Raceseng development car and Eric Simmons autoX car. We are doing our due diligence with testing to ensure a sound product. I will be posting updates in this thread as we get closer to production. Thanks much!
Raceseng is offline   Reply With Quote
Old 06-05-2013, 04:44 AM   #45
s2d4
s2d4's Avatar
A few more questions if I may:
1. What is the drop in height from stock?
2. If I was to order for stock struts with aftermarket springs, can they be used again if I end up going down the KW V3 route?
3. The final finish, will it be black/orange only? What about clear anodised?
4. How is the testing so far on simmon's car?
5. How is the testing so far on your own shop car?
Old 06-06-2013, 08:48 AM   #46
Raceseng
Raceseng's Avatar
Originally Posted by s2d4 View Post
Please pardon my ignorance, will this be fronts only?
We are working on rear strut tops right now. They will give a much needed increase in shock travel!
The Following User Says Thank You to Raceseng For This Useful Post:
Scooby South (06-27-2013)
Old 06-06-2013, 09:04 AM   #47
Raceseng
Raceseng's Avatar
My responses are in orange under your questions.
I would have to measure the drop in height from stock but remember that as of now these can't be used with stock front struts.
These can only be used with aftermarket coil overs right now. We are custom machining the upper and lower spherical bearing bushing to work with whatever coil overs our customers have. We have a form designed We are working on a spring perch, upper/lower bushing that will accept the stock strut.
Offering a variety of anodizing options is a nightmare from an inventory standpoint. They will most likely have the following finishing: Black anodized camber/caster plate, orange anodized spring perch and electroless nickel plated steel components.
Eric gained 3/4" travel over his MSI plates and the testing is going well. He was competed and won in multiple AutoX events with the plates. Feel free to PM Eric, he will give you an honest non-biased opinion of our caster/camber plates.
I put 1,500 miles on the car so far and they are as quiet and smooth as they were from the get go. When load is taken off the front wheels, the caster and camber is effortless to adjust.
The Following 3 Users Say Thank You to Raceseng For This Useful Post:
s2d4 (06-07-2013), Scooby South (06-27-2013), whataboutbob (11-01-2013)
Old 06-06-2013, 10:40 PM   #48
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
They are Awesome so far, NO noise at all
I even had them on last week when I was driving on Long Island NY, some of the worst roads I have ever been on. They held up fine.
Very easy to adjust caster and camber compared to other tops I have used.
Let me know if you have any more questions.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
s2d4 (06-07-2013)
Old 06-14-2013, 04:12 AM   #49
eckoflyte
Although I am in Australia, would be in for a group buy. Any chance you would make such an option available for this forum?
The Following User Says Thank You to eckoflyte For This Useful Post:
Raceseng (06-25-2013)
Old 06-14-2013, 05:27 AM   #50
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
My question is will I be able to put these on top of the RCE Tarmac 0s?
I am a car suspension newb, been wrench on my Runner for years though.
What would the assembly look like from top to bottom? Top mount, .....,spring/coilover? What goes in-between?
Overland'n'5thGEN is offline   Reply With Quote
The Following User Says Thank You to Overland'n'5thGEN For This Useful Post:
Old 06-14-2013, 09:18 AM   #51
Raceseng
Raceseng's Avatar
A group buy will be hard because we need to custom machine the upper nut and lower bushing per each set of coil over requests we get.
Old 06-14-2013, 12:29 PM   #52
Raceseng
Raceseng's Avatar
We will machine spring perches for 2 1/2", 2 1/4" and 60mm springs. That will cover all the springs on the market.
The parts that we will machine per coil over are the upper nut and lower bushing. See attached section view for your reference.
TrogDor the Burninator (08-10-2013)
Old 06-25-2013, 08:49 PM   #53
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Would these work with RCE Tarmac 0's? Given that the Zeros are based off the KW3's. Thanks.
TRD_07 is offline   Reply With Quote
The Following User Says Thank You to TRD_07 For This Useful Post:
Old 06-26-2013, 01:47 AM   #54
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Incredibly interested in these camber plates. I'm looking to pick up a set of AST 4150's as soon as they are available. Will there be any testing done to ensure compatibility?
Acree is offline   Reply With Quote
Old 06-26-2013, 06:55 AM   #55
Raceseng
Raceseng's Avatar
We have the design and machining capability to make our cc plates work with any coil over set up. I believe AST has some basic dimensioned prints of their shocks on their website, that would be a great place if you can find one of your coil over set up.
Please feel free to email me at jarrett[at]raceseng.com if you find the print.
If you can't, we made a strut shaft form that you can fill in with dimensions. Either way, we can make it happen!
Old 06-26-2013, 02:17 PM   #56
wparsons
wparsons's Avatar
I didn't see this question asked yet, do these require any trimming of the strut towers to work? I know some plates on some cars require trimming the tower to get any adjustment range.
flickr
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
