Old 06-24-2013, 07:02 PM   #29
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by Draco-REX View Post
You're at WOT at 2500rpm daily?
Some people like to pass people without down shifting., that's 45mph in 6th.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-24-2013, 07:04 PM   #30
vgi
Drives: frs
Originally Posted by Adeets View Post
I think the idea that was perceived by this kit was it was going to make gobs of torque from the get go, but at 4k the vortech starts making flat linear torque that climbs way above this kit, my hope for this kit was to start out kicking vortechs ass in torque and keep it till 6k ish, what it does instead is has a lil flare right before 3.5, then the vortech seems to match it, then surpasses it, by a pretty significant margin.
I just think that this nonintercooled kit has been hyped way to much, and it's not really even a contender for the other options out there. If your worried about carb, go vortech, even the ugly flatliner tunes seem better then this. If your not worried by carb, go turbo, if you don't want lag go vortech. I'm not seeing where this kit has a market, what are the pros of it compared to the rest out there?
Maybe a market for people who think installing intercoolers is to hard? Well, they probably won't be buying a kit at all.
I may be wrong, but how about these from the top of my head:
- installation, nice and easy, no cutting/bending, easy to put back to stock
- maintenance, no need to take it out if you want to replace something upfront, service period is 30-35k vs 7k
- price point, almost 2k less
- the sound may be addictive for some
the car doesn't really need that much more power, it doea need torque though and this kit delivers a fairly good deal for those that DD their cars and don't plan on more power.
vgi is offline   Reply With Quote
Old 06-24-2013, 07:05 PM   #31
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Laziness. From the very start, this car has been about shifting to keep it in the proper rev band. No reason why it should be different now.
Old 06-24-2013, 07:05 PM   #32
jamesm
If you ever want to pass a car on the highway without downshifting, the yes I suppose that's reasonable. The torque loss shown is just because they weren't wot yet. There's no way it makes less torque than stock anywhere, that's what the twin screw is all about lol.
Old 06-24-2013, 07:07 PM   #33
jamesm
It should be different because you bolted a freakin' supercharger to it lol. No one is debating whether its good power, just that there isn't anywhere near enough of it to compete with the alternatives.
Old 06-24-2013, 07:10 PM   #34
Calum
That Guy
Drives: 2013 asphalt FRS MT
Yes. And even if I'm not, that's about a third less power available for partial throttle passing, or just climbing a hill. Crap, I didn't even think about trying to climb a hill. Adding a mild FI kit shouldn't cause me to down shift to make it up a hill when I didn't have to before. Damn, I really was excited about this kit. Much like Robi's oil cooler/rad, I want to keep the FI simple. I was hoping 250-260 whp as the starting point, AND not loosing power anywhere. If that had to be the intercooled system so be it. Anyway, I've said my piece. I don't need to bag on a vendor's product anymore then this. I'm not the target audience for this kit. I thought I was, but clearly I'm not.
Old 06-24-2013, 07:12 PM   #35
jamesm
again, this kit will not lose power anywhere in the rev band. the dyno operator clearly was not at wot until 3.5k or so in the dyno. it's not reasonable to believe that bolting on a positive displacement supercharger will lose power down low, unless the tuning is very, very bad.
Old 06-24-2013, 07:13 PM   #36
jamesm
If you re-read the OP, you'll see that the 210rwhp you're quoting is on a low-reading dyno. Closer inspection puts the stock run at about 140rwhp. Assuming a 15% driveline loss, a stock BRZ should be around 160. Adjusting for the discrepancy, that puts his final numbers at over 240rwhp or roughly 282bhp.
innovate's dyno was on a dynojet. it made 211whp.
Old 06-24-2013, 07:17 PM   #37
Adeets
OEDC
Adeets's Avatar
Why wouldn't he be wot when he was in gear to make the pull, that makes no sense.
My BRZ FI Build
Old 06-24-2013, 07:17 PM   #38
TemeCal
Drives: 86
Innovate also said this:
While we did make several stronger pulls, we felt our lowest single pull would best represent the low end of what one would likely experience with our turn-key stage 1 system
...they very well could have thrown up the highest dyno reading, but they didn't. This is also on a bone stock car.
TemeCal is offline   Reply With Quote
Old 06-24-2013, 07:19 PM   #39
Adeets
OEDC
Adeets's Avatar
And you honestly believe a company, who's financial security depends on this product selling is actually gonna post their lowest pull?
My BRZ FI Build
Old 06-24-2013, 07:20 PM   #40
Draco-REX
Corner Junkie
Draco-REX's Avatar
On an otherwise stock car, non-intercooled, with Cali 91 octane, and a "bulletproof" OTS tune. But if you want to write the kit off immediately, go ahead. I'll still have a big smile on my face.
Old 06-24-2013, 07:21 PM   #41
jamesm
he started the pull at 3.5k. the other pull started at lower revs. as soon as he opened it up around 3.5k the torque jumped up to where you'd expect it to be. very low, but where you'd expect it to be none the less.
edit: on second look, you are correct. it appears as though this thing is actually losing power below 3.2k or so. i was looking at the graph innovate posted. wow. i stand corrected.
Old 06-24-2013, 07:21 PM   #42
Draco-REX
Corner Junkie
Draco-REX's Avatar
I don't believe Innovate will go under if this kit doesn't sell.
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
