Old 06-22-2013, 06:27 PM   #1
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Click when stomping the gas...
I read that the intake opens and closes depending on how much air is needed...
It's pretty loud though. Could it be sticking or something? Or another problem all together?
Brahsbrah is offline   Reply With Quote
Old 06-22-2013, 06:34 PM   #2
ft_sjo
Drives: GT86
Are you running 91 gas?
Old 06-22-2013, 06:35 PM   #3
Brahsbrah
Yessir!
Old 06-22-2013, 06:50 PM   #4
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
I have this also. Got louder after installing my inlet hose.
husker741 is offline   Reply With Quote
Old 06-22-2013, 11:30 PM   #5
Brahsbrah
No idea what is causing it?
It seems like it only happens when I got from no throttle and stop it...
Old 06-23-2013, 03:01 AM   #6
ft_sjo
Drives: GT86
Does it sound like a metal ball bearing hitting a metal pan?
Old 06-23-2013, 08:39 AM   #7
BRZnut
Drives: BRZ DGM Limited
Need sound clip!
Old 06-23-2013, 08:57 AM   #8
radroach
Drives: car
Automatic or Manual?
Old 06-23-2013, 10:55 AM   #9
Brahsbrah
Perfect description.
I can take a sound clip later if I remember.
And yes it is 6MT.
Old 06-23-2013, 01:04 PM   #10
ft_sjo
Drives: GT86
It sounds like transient detonation. Try to change gear a little easier and ensure your foot is off the clutch before you go back on the throttle.
Old 06-23-2013, 05:03 PM   #11
Brahsbrah
I googled that and couldn't really find put what it meant. Can you elaborate?
Old 06-24-2013, 03:53 AM   #12
ft_sjo
Drives: GT86
Well, historically it means that the ECU/sensors in the car couldn't keep up with your movements, so when rapidly change something (e.g. the throttle) then for a split second the timing would be too advanced and you'd get a little click of light det/knock/pinking. It's not normally an issue.
However, I would expect better from a modern car, fast electronics, complex calibration/strategies. I too get some 'tip-in det'. Tip-in means when go into a change, e.g. from 0% to 100% throttle. Tip-out is the opposite, so if you reverse the action.
There are control strategies and tables in the ecu which are supposed to handle transients and knock should not happen. It sounds as if the behaviour is worse on 91 AKI. I run equiv. of 93 AKI (98RON) and I do get some tip-in det when driven poorly (e.g. medium engine speed, quick gear changes, some clutch slipping).
Some folk think it's because the mixture is lean but to be honest there's not enough time during a transient for a lean/hot mixture to cause det, it's 99% likely to be due to spark angle at the time.
There's nothing you can do as a consumer really other than a) complain at your dealer (who will just say it's normal), b) change gear a bit nicer.
Old 06-24-2013, 07:33 AM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
Wouldn't the latest ROM fix the issue? I know US dealers may not have access to it yet, but it's available through tuners, no?
Old 06-24-2013, 07:56 AM   #14
ft_sjo
Drives: GT86
No, this is a different transient det behaviour. The one apparently killer injector seals only happens above 5200rpm when you change gear < 600ms.
Note, I said 'behaviour' and not 'problem'.
transmission or diferential peoblem? CLICK/TICK subiesteve Issues | Warranty | Recalls / TSB 38 08-17-2013 09:20 PM
Click lock hardwood floors? Wonderbar Northwest 1 04-08-2013 12:27 AM
Got camber? Click for lolz SubarooMike Other Vehicles & General Automotive Discussions 8 11-12-2012 12:45 AM
Click on window roll down. DantKR Issues | Warranty | Recalls / TSB 3 09-07-2012 10:37 AM
Want a first-shipment BRZ? Click here Tainen BRZ First-Gen (2012+) — General Topics 17 05-14-2012 02:29 PM
