Old 06-23-2013, 10:02 PM   #15
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Originally Posted by AG3NT_5CARFAC3 View Post
Maybe when the FRS 10 Series comes out we can order those lights for less? Maybe?
Got quoted $4200 yesterday for the lights. Might be cheaper finding them elsewhere.
sent from a Galaxy SIII...
Overland'n'5thGEN is offline   Reply With Quote
Old 06-23-2013, 10:54 PM   #16
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by iketiak View Post
I think he means removing the DRL resistor and powering the DRL lights which is located on the passenger side underneath the headlights. I had a little trouble with that also. Thanks to you and motop post I am finally able to get everything working correctly.
so the plug that is connected to the drl resistor that is going to the car is the one where you tap the white wires into on the prongs of the connector?
so drl resistor unplug, plug left on the car that normally goes into the drl resistor, tap into those prongs in the connector and it should be good?
ft86me is offline   Reply With Quote
Old 06-23-2013, 10:56 PM   #17
ft86me
ft86me's Avatar
Drives: 2013 FRS
any way to get pics of the drl wiring portion? i'm confused as to what's going on here.
Old 06-24-2013, 12:00 AM   #18
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Unplug the DRL resistor which is shown in the guide, then tap into the positive side harness. The positive side is colored stripe green for me don't know if it's different for another car.
iketiak is offline   Reply With Quote
The Following 2 Users Say Thank You to iketiak For This Useful Post:
6spd (05-14-2016), ft86me (06-24-2013)
Old 06-24-2013, 02:39 AM   #19
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
Thanks for the DIY! Got to install mine today and this made it so much easier.
Trojan_SC is offline   Reply With Quote
The Following 4 Users Say Thank You to Trojan_SC For This Useful Post:
ft86me (06-24-2013), nigel-jdmparts (06-24-2013), Perihelion (06-25-2013), tbwoodlee (06-25-2013)
Old 06-24-2013, 03:40 AM   #20
ft86me
ft86me's Avatar
Drives: 2013 FRS
just co clarify so i will two wires going into the prong that the striped green is going to? sorry im just trying to cover my ass here.
Old 06-25-2013, 03:39 PM   #21
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Yes, two wires, one for each headlight. The way I did it was I tapped the passenger headlight to the green wire in the drl resistor, then I tapped the driver headlight into the passenger's drl line (which was tapped into the drl resistor line). As long as they are both getting power from the positive DRL line you are good, how you do it doesn't matter.
tbwoodlee is offline   Reply With Quote
The Following User Says Thank You to tbwoodlee For This Useful Post:
ft86me (06-25-2013)
Old 06-25-2013, 10:44 PM   #22
ft86me
ft86me's Avatar
Drives: 2013 FRS
thank you soooo sooo sooo much for your help!!
The Following User Says Thank You to ft86me For This Useful Post:
KamalT (08-31-2013)
Old 06-26-2013, 06:54 PM   #23
Trojan_SC
Trojan_SC's Avatar
FYI, if you want a reversible install for the last pin (DRL), find some single pin connectors online. I had a set left over from a motorcycle HID kit I never used and it made everything look even cleaner. Just a suggestion to avoid having to remove the pin from the last wire.
Old 06-27-2013, 08:53 AM   #24
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
No problem, glad to help out if I can. Make sure to post pics so we can see the finished result!
ft86me (06-27-2013)
Old 06-27-2013, 01:46 PM   #25
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
might as well import them at that rate
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
NemesisPrime909 is offline   Reply With Quote
Old 06-27-2013, 08:00 PM   #26
Overland'n'5thGEN
Agree and I will down the road.
Old 06-27-2013, 10:17 PM   #27
ft86me
ft86me's Avatar
Drives: 2013 FRS
will do!
Old 06-30-2013, 07:30 PM   #28
ft86me
ft86me's Avatar
Drives: 2013 FRS
dude thank you much for your help! my buddy that was helping me with wiring said your instructions were very good and the pictures also helped for the installation of the pins. gotta admit the usdm pins are a pain compared to teh jdm ones! the DRL are perfect and work as they are supposed to! thank you!
only thing I will mention is that if you have a vortech kit and a perrin oil cooler. the driver side is going to be a pain in the ass with the reservoir that comes with the vortech kit. all i'm saying is it's gonna be squished a bit haha. also the oil lines need to be moved over towards the center to make everything work. the passenger side is gravy!
WTT: FR-S headlamps for BRZ Nothing Southeast 2 03-30-2013 06:41 AM
Auto-Off Headlamps nktech Scion FR-S / Toyota 86 GT86 General Forum 12 12-10-2012 09:51 AM
Purple/Blue headlamps BMWDavid Other Vehicles & General Automotive Discussions 0 11-24-2012 01:40 PM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 02:08 PM
limited 86 headlamps SuperDave FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 08-04-2012 03:41 AM
