Old 06-12-2013, 09:42 AM   #1
evilconcarne999
My LFA
evilconcarne999's Avatar
Drives: No Boost
Cusco Verticle Air/Oil type Catch Can Install help
Hey was wondering if someone could give me a hand on the install of this. Ill be getting it in the mail today and just need some help on where to route the lines etc. If someone who has one installed already could chime in and put some pics showing where all the lines need to get routed for this to work id appreciate it thanks.
WSIR 1:46.023 (Need Better Tires)
My Car Build: 171.9WHP/137WTQ (Mustang Dyno)
http://www.ft86club.com/forums/showthread.php?t=21824
My For Sale Aftermarket and OEM parts
http://www.ft86club.com/forums/showt...484#post998484
evilconcarne999 is offline   Reply With Quote
Old 06-12-2013, 10:56 AM   #2
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
i have this installed on my car, the instructions arent in english, but the pics are pretty straight forward, should take you about 30 minutes max. the hose comes in one long piece, so ull need to cut it to get two separate lengths of hose.
DAN_BRZ is offline   Reply With Quote
Old 06-13-2013, 01:02 PM   #3
evilconcarne999
My LFA
Drives: No Boost
so did you install your lines how the picture showed that came with the can? because ive read of people installing the lines in various different configurations and saying this and that on how effective it is one way or another.
Old 06-13-2013, 03:31 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The best way to connect it will be inline with the PCV valve on the back of the block that connects to the back of the intake manifold. Remove the hose from the intake manifold and connect one of the clear hoses to it and then connect the other clear hose to the back of the intake manifold.
Old 06-14-2013, 11:09 AM   #5
DAN_BRZ
DAN_BRZ's Avatar
when i installed mine the last things i did was run the hose. i connected on end to the can, clamped it on, and ran the other to the pcv, eye balled that i would have enough lengh to run the second hose and made my cut. if i remember correctly i halfed the hose.
Old 06-14-2013, 11:36 AM   #6
DAN_BRZ
DAN_BRZ's Avatar
Old 06-22-2013, 05:39 PM   #7
evilconcarne999
My LFA
Drives: No Boost
ok i got the back of the PCV valve under the D4s cover now the back of the intake manifold when i remove the hose the cusco hose is too fat for the inlet thats sticking up, did you have to modify a piece of the stock hose to get it to fit snug?
Old 06-22-2013, 06:26 PM   #8
evilconcarne999
My LFA
Drives: No Boost
Got it installed finally
Old 06-22-2013, 06:29 PM   #9
evilconcarne999
My LFA
Drives: No Boost
Appreciate the Help @DAN_BRZ and @King Tut
Old 06-24-2013, 01:24 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep. The D3PE can uses a hose barb fitting to connect to the OEM hose and you have to cut it where the hose is the correct size because as you know it changes sizes near the back of the intake manifold.
Old 06-24-2013, 01:54 PM   #11
evilconcarne999
My LFA
Drives: No Boost
yeah i actually cut the rubber stock hose where it connected to the back of the block, that skinny plastic piece that sticks up, i took the stock hose cut off the end and made it long enough to stick in the cusco tube and sinch down with the clip. So now it fits great, gonna check it in a day or 2 make sure its not leaking.
Old 03-19-2014, 05:11 PM   #12
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Do you hav any problem so far?
I am thinkin to reconnect my Cusco catch can to this way..
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 03-19-2014, 05:24 PM   #13
DAN_BRZ
DAN_BRZ's Avatar
i am going to re install mine this way, any more pics of ur install??
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Cusco catch can install diagram wbradley DIY (Do-It-Yourself) Guides 52 03-02-2016 12:01 AM
Cusco Oil Catch Can Install Help (horizontal type) Juurian Engine, Exhaust, Transmission 2 04-29-2013 12:24 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
Cusco catch can install wbradley Engine, Exhaust, Transmission 2 01-11-2013 12:11 AM
