Old 06-19-2013, 03:35 PM   #1835
mid_life_crisis
Drives: FR-S 10 #103 AT
It's now a year to the day since this thread was opened.
Quality takes time, but...
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following 2 Users Say Thank You to mid_life_crisis For This Useful Post:
LeeMaster (06-19-2013), SkAsphalt (06-20-2013)
Old 06-20-2013, 12:34 AM   #1836
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
It'll depend on how much power it makes over other headers....
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 06-20-2013, 10:39 AM   #1837
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Take into account it's also a 3' not a 2.5 like everything else, so it's not a true apples to apples comparison.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 06-20-2013, 11:50 AM   #1838
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
What is 3" ?
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 06-20-2013, 12:30 PM   #1839
FR-S Matt
Originally Posted by ill86 View Post
What is 3" ?
The exhaust the header was tested on was a full 3" exhaust, not 2.5.
3" from the Overpipe to the Axleback.
The Following User Says Thank You to FR-S Matt For This Useful Post:
ill86 (06-20-2013)
Old 06-20-2013, 09:35 PM   #1840
StormTrooper
somehow i doubt you'll see much more power going from 2.5" to 3" exhaust....it's not a bottle neck on stock turbo subaru's much less naturally aspirated ones.
GR86 MT premium
Old 06-20-2013, 10:15 PM   #1841
FR-S Matt
There won't be a difference in power, but there will be a difference in volume for sure. I'm going 3" so I can just replace the header if I decide to go UEL for a bit before going turbo later down the road. That way I don't have to toss out my exhaust and if I end up going high horsepower on a turbo build, I've got the size for it.
Most probably won't like the volume, but I'll probably be able to handle it.
Old 06-21-2013, 12:39 AM   #1842
OrbitalEllipses
Drives: Attitude
The Following 4 Users Say Thank You to OrbitalEllipses For This Useful Post:
FR-S Matt (06-21-2013), Hawaiian (06-21-2013), ill86 (06-21-2013), zuldajin (06-21-2013)
Old 06-21-2013, 06:34 AM   #1843
FR-S Matt
Careful or I'll start adding stickers to my car! Then you'll know what's up.
Old 06-21-2013, 07:57 AM   #1844
mad_sb
Drives: 2013 Asphalt FR-S
They tested both and posted plots of both... LT3Y Header + Full 3" and LT3Y Header with 2.5 front / over + Stock mid pipe + nameless axle back. 2.5 lost out a little bit down low and midrange, but not much.
The Following User Says Thank You to mad_sb For This Useful Post:
Old 06-21-2013, 08:03 AM   #1845
mad_sb
From testing 3" vs 2.5...
Originally Posted by johnbradley View Post
Video will be a little ways out. Final numbers with the smaller exhaust 188/153 and a best torque run of 186.7/157.2. I'll have the dyno sheets off to Nameless to sort through after I go grab some lunch....3 hours no food sucks. So as you would expect smaller exhaust made less power, but only really seems to have dropped below 4500 for the most part.
10-13 ft lbs down low, 4-5 thru some areas of the powerband. If I knew why after the first flash the torque is up in the dip but then reverts ( I assume electronic interference since its repeatable) after that on the very next pull I can lessen the dip. I am almost willing to pay for the explanation but I am not sure that it would be shared if its known.
If I get in trouble for this I am blaming all of you
Please keep in mind this is just the prelimn. I have mountains of data to go through and figure out why it is what it is.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
FR-S Matt (06-21-2013), SkAsphalt (06-21-2013)
Old 06-21-2013, 04:14 PM   #1846
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Yeaaaah I am just moving around my pennies until I have over 1,000 saved up for the day this header with a cat finally gets announced
Old 06-21-2013, 04:46 PM   #1847
xjohnx
Grip>Slip
xjohnx's Avatar
dude, you're going to need more than 10 bucks.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
topazsparrow (06-21-2013), wparsons (06-21-2013)
Old 06-21-2013, 05:18 PM   #1848
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
lol
I meant save up my pennies until I have well over $1,000 saved up. Though I do appreciate your humor
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
