Old 02-15-2013, 06:10 PM   #1205
OrbitalEllipses
Drives: Attitude
mmmburrito
mmmmtorques
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
chanomatik (02-15-2013), Jive Turkey (02-18-2013)
Old 02-15-2013, 06:12 PM   #1206
BRZ?
Drives: 2014 SWP 6MT BRZ
BRZ? is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZ? For This Useful Post:
chanomatik (02-15-2013), Freeman (02-15-2013), OrbitalEllipses (02-15-2013)
Old 02-15-2013, 06:44 PM   #1207
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by johnbradley View Post
Video will be a little ways out. Final numbers with the smaller exhaust 188/153 and a best torque run of 186.7/157.2. I'll have the dyno sheets off to Nameless to sort through after I go grab some lunch....3 hours no food sucks. So as you would expect smaller exhaust made less power, but only really seems to have dropped below 4500 for the most part.
I am confused...the dyno posted several days ago showed these same numbers basically. How is it down on power? Only in the lower end?
Old 02-15-2013, 06:46 PM   #1208
wootwoot
Drives: FRS
Thank you for all your hard work!
Old 02-15-2013, 07:00 PM   #1209
johnbradley
Drives: Turbocharged
It did 191/162 before and it makes less below 4500 now...
johnbradley is offline   Reply With Quote
Old 02-15-2013, 07:16 PM   #1210
zuldajin
zuldajin's Avatar
Drives: K24 Swapped FRS
zuldajin is offline   Reply With Quote
Old 02-15-2013, 07:34 PM   #1211
johnbradley
If I get in trouble for this I am blaming all of you
Please keep in mind this is just the prelimn. I have mountains of data to go through and figure out why it is what it is.
The Following 3 Users Say Thank You to johnbradley For This Useful Post:
Calum (02-15-2013), chanomatik (02-15-2013), LeeMaster (02-16-2013)
Old 02-15-2013, 07:35 PM   #1212
OrbitalEllipses
Drives: Attitude
How much less...?
Old 02-15-2013, 07:40 PM   #1213
johnbradley
10-13 ft lbs down low, 4-5 thru some areas of the powerband. If I knew why after the first flash the torque is up in the dip but then reverts ( I assume electronic interference since its repeatable) after that on the very next pull I can lessen the dip. I am almost willing to pay for the explanation but I am not sure that it would be shared if its known.
The Following User Says Thank You to johnbradley For This Useful Post:
industrial (02-15-2013)
Old 02-15-2013, 08:11 PM   #1214
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by Wepeel View Post
F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5 F5
Seeing these results makes me want to go out and buy a BRZ.
Someone has played maple story before.
NickFRS is offline   Reply With Quote
Old 02-15-2013, 08:23 PM   #1215
johnbradley
Here is an example of what I am talking about with the torque "regression" as someone called it-
No other changes other than a second pull. The first pull (blue) is immediately following a flash, the red following that. The advance mulitplier was lower on the blue which explains most of it, but additive timing kept the over all timing within a degree. If the dip was limited to that amount every pull then you would never know what was going on unless you were being picky.
Old 02-15-2013, 09:01 PM   #1216
Calum
That Guy
Drives: 2013 asphalt FRS MT
AVO posted a while ago about having trouble with the cam phasing sticking. Any chance this could be the cause?
The Following User Says Thank You to Calum For This Useful Post:
Dimman (02-15-2013)
Old 02-15-2013, 09:18 PM   #1217
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
No expert here, but have read a lot that after a flash, the car needs to adjust and "learn" the new flash. Some have talked about flashing, then letting the car idle 5 minutes before driving away and that after driving, some miles need to be put in the car for the ECU to adjust. May be possible that while the ECU is learning something happens with cam phasing? (this is assuming you guys are flashing and right away running first dyno run then second dyno run, no idle time between flashing and dyno run).
Old 02-15-2013, 09:22 PM   #1218
sierra
Drives: Skoda Yeti DSG diesel 4x4
I think it's more likely to be the ECU adjusting to the changes.
My car certainly improved steadily over the first 1000km and then I decided to re-set it to see what would happen. It felt flat again, with some hesitation to the throttle and is gradually improving. I read somewhere it learns and adjusts to changes without being re-set and that it takes some time to optimise those changes.
That same process might slowly eat away at some of the changes that were flashed into it?
sierra is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
