Old 06-19-2013, 12:43 PM   #15
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
First off, I'm not a Subaru guy. Don't really care what they came off, just know they go on my brz. And, I can't figure out how to change the thread title.
Fronts: went on perfect, no adapters or cutting or anything.
Rears: need adapters and the wrx rotors won't work due to our ebrake system being huge in comparison.
They bite hard in comparison to stock, which may be attributed to the ebc red pads and ebc rotors. The loss in weight is well worth the money since these are much cheaper than the aftermarket bbk's. I also get a woody having "Subaru" brakes instead of some other brand, I think it just looks cooler.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following User Says Thank You to Wonderbar For This Useful Post:
SkAsphalt (07-11-2013)
Old 06-19-2013, 12:45 PM   #16
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Go to first post, 'Edit', 'Go Advanced'
The Following User Says Thank You to SloS14 For This Useful Post:
Brzzee (07-15-2013)
Old 06-19-2013, 01:10 PM   #17
OrbitalEllipses
Drives: Attitude
The adapter part is correct...but you should be able to use your OEM rear rotor.
Pre-08 (non STI) parking brake diameter: 170mm
STI and all 08+ parking brake diameter: 190mm
Centric part numbers and diagrams below.
06-07 WRX rear rotor:
13 BRZ rear rotor (high-spec):
Old 06-19-2013, 01:17 PM   #18
Wonderbar
Driveway labs.
Wonderbar's Avatar
Fixed. Better?
SloS14 (06-19-2013)
Old 06-19-2013, 01:19 PM   #19
Wonderbar
Driveway labs.
Wonderbar's Avatar
Yeah, they fit the stock rotors fine, I can't actually get the bracket to fit the caliper. It's like a 1/32 inch off and won't thread the bolts
Old 06-19-2013, 01:21 PM   #20
OrbitalEllipses
Drives: Attitude
http://www.knsbrakes.com/carItemDeta...&item_id=37648
This bracket should work; if it doesn't call Ken. I know that you need to modify something very slightly or at least you had to in early versions.
EDIT: Install PDF http://knsbrakes.com/RearBremboV2ALL.php
Old 06-19-2013, 02:39 PM   #21
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Did you not have to change anything with the fluid lines on the front? I know on the wrx the calipers sit on the back side if the rotor where ours sit on the front.
I've been looking into doing this upgrade for the front for awhile now but I'm waiting for a good deal to pop up for some used calipers.
Flat Black VW is offline   Reply With Quote
Old 06-19-2013, 03:06 PM   #22
Racecomp Engineering
He doesn't have to because the calipers are not differentially bored, so you can put the bleeder on top without issue.
- andy
Racecomp Engineering is online now   Reply With Quote
Wonderbar (06-19-2013)
Old 06-19-2013, 03:29 PM   #23
Flat Black VW
- andy
Awesome, now to just find a good deal on a set somewhere. Time to head to crazy rays and see if they have any wrxs.
Old 06-19-2013, 03:29 PM   #24
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Originally Posted by RallySport Direct View Post
And just in case anyone wants these, they come stock on the 06-07 WRX's and utilize an aluminum caliper. You can also find them off the early JDM WRX's 93-01, but they will be a cast steel. The Steel ones will have painted raised Subaru letters, where the Aluminum calipers will use a flat sticker. Hope this helps
Thanks,
Rick
This is news and exciting! Can @Wonderbar slap a magnet on these brakes to confirm what @RallySport Direct is saying about these being aluminum.
I didn't know that the WRX version calipers are aluminum and was under the impression they were all cast steel.
And to clarify you can get the Black version with a flat Subaru sticker now like mine. The older JDM versions did have raised lettering.
Beyer Subaru is offline   Reply With Quote
Old 06-19-2013, 03:46 PM   #25
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
so much want
SLICVIC is offline   Reply With Quote
Old 06-19-2013, 03:54 PM   #26
OrbitalEllipses
Drives: Attitude
I'm pretty sure the fronts are NOT aluminum; I thought only the 300ZX turbo calipers were aluminum. The rears ARE cast aluminum, I can confirm that. I also have confirmation beyond the diagrams I provided that the rears fit with a bracket and our OEM rotor.
Also, I'm looking to get the black version, but I'm not having luck. You got a P/N or are they still a JDM item? If they still a JDM item, got a JParts P/N?
Beyer Subaru (06-19-2013)
Old 06-19-2013, 04:01 PM   #27
Wonderbar
Driveway labs.
Wonderbar's Avatar
- andy
Correct! No changes to lines, although, I highly recommend braided steel lines with these.
Old 06-19-2013, 04:07 PM   #28
Beyer Subaru
Hmmmmm? I didn't think that this would be a mod that you would do being so function over form minded. These brakes are really just a bling mod with our brakes being so efficient from the factory.
I got em from sgp - http://www.subarugenuineparts.com/pr...cb7e31499676cd
I'm with you on the 300Z brakes. I just tested my buddies 300z calipers on his 240 and they are aluminum. But I'd really like confirm on the fronts as a 2lb difference between steel and aluminum doesn't seem possible.
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 Premium Auto Styling Southern California 2 06-22-2012 07:34 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
