Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
Subaru 4 pots!
So I was lucky enough to get a great set locally here in Tacoma. They are in great shape with only minor chips and scuffs. I went with these over brembo because I wanted to keep 17in wheels and I think the Subaru logo is way cooler to put on the Brz.
The fronts fit perfectly, I have 17x7, +42 Tenzo R wheels and there is clearance for days. Bolts straight up using stock bolts. The rears are a little less direct swap, the sti rotors don't work with our ebrake system. Our ebrake circumference is huge in comparison. Also gonna need some brackets for them to fit. The weight difference on the fronts are pretty good also, 11.8lbs for the 4 pots and 14lbs for the stockers. The overall rotor diameter is the same on both front and rear, as with the rotor width. So in theory, you could use stock rotors with these brakes. - Subaru 4 pot fronts - ebc red pads - ebc slotted and dimpled rotors - Subaru 2 pot rears (pending) - ebc red pads rears (pending) - ebc slotted and dimpled rotors rear (pending)
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) Last edited by Wonderbar; 06-19-2013 at 12:59 PM. |
#2 |
Driveway labs.
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following 5 Users Say Thank You to Wonderbar For This Useful Post: | glamcem (06-08-2014), hmong337 (06-15-2014), LeeMaster (06-19-2013), RallySport Direct (06-17-2013), Scooby South (06-26-2013) |
#3 |
Drives: 2014 Widebody Cosworth FR-S
And just in case anyone wants these, they come stock on the 06-07 WRX's. You can also find them off the early JDM WRX/STi's 93-01. The old WRX/Sti calipers will have painted raised Subaru letters, where the new calipers will use a flat sticker. Hope this helps
![]() Thanks, Rick Last edited by RallySport Direct; 06-19-2013 at 05:10 PM. |
| The Following 4 Users Say Thank You to RallySport Direct For This Useful Post: |
#4 |
Grip>Drift
Drives: FRS
Title says 05 STi brakes but these are clearly 06-07 WRX brakes.
#5 |
Drives: Attitude
Confusing OP. As the above poster says, these aren't STI brakes...or at least not "modern" STI brakes. I believe these were JDM STI brakes on the first gen, but calling them STI brakes is a misnomer.
FWIW, you can fit those rears to the our car with a bracket from KNS (Mach V also carries it) and IIRC, continue to use our rear discs. |
#6 |
doh, i recalled incorrectly.
- Andrew Last edited by Racecomp Engineering; 06-17-2013 at 04:10 PM. |
#7 |
Driveway labs.
The rotors on the rear are the same diameter. Needs brackets to mount the calipers. Wrx rotors won't work due to ebrake. Driving, will post later
#8 |
Drives: Scion FRS
same calipers that come on the 300zx
#9 |
Drives: Attitude
#10 |
Drives: 86
That a good saving on the rotor wight. I wish if I can find a lighter option.
#11 |
Kouki-Monster
no bracket or anything needed? just bolt on and go?
Rich Anderson
EMPOWER AUTO |
#12 | |
Drives: UK GT86
Can the OP change the title of the thread as these aren't STi brakes.
.: Stealth 86 :.
#13 |
Drives: Attitude
#14 |
Red wine
Drives: Subaru BRZ(R.I.P)
For the people who says rotors dont matter, IT DOES. Just look at the weight difference, it reduces rotating mass and has the same effects as going with lightweight rims. With that being said, I might consider these, I cannot believe I passed on these when I found a fresh 06 WRX at the junkyard. DOH!
| The Following User Says Thank You to LeeMaster For This Useful Post: | Wonderbar (06-19-2013) |
| Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 113 | 11-21-2020 01:02 PM |
| Subaru BRZ - RAW Subaru | Official Subaru Australia Ad | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 15 | 07-20-2012 08:20 AM |
| Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 | Premium Auto Styling | Southern California | 2 | 06-22-2012 07:34 PM |
| Subaru/Toyota Coupe spotted in Socal with Subaru Plates | owsiu | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 05-25-2011 10:27 PM |
| Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) — General Topics | 39 | 03-24-2011 09:22 AM |
