Old 06-17-2013, 01:43 PM   #15
djdnz
1337
Drives: 2013 BRZ WRB S/C
You could always get a 3-5mm spacer for the fronts. Then down the road, get coilovers and swap the spacer to the rear to bring the rears closer to flush (or just sell the spacers).
Easy and cheap interim solution.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
BRZ RN (03-17-2015)
Old 06-17-2013, 02:34 PM   #16
wparsons
wparsons's Avatar
Originally Posted by garfull View Post
Just got off phone with Rudy at Tirerack, very knowledgeable guy, worked with him before on the miata forums. He recommends no less than 1/2" clearance for proper fitment. He suggested a 10mm spacer which will get me to 1/2" clearance. That's too much for my taste and I don't want to change out wheel studs. A 5mm spacer would get me 8mm of clearance, but I think I'm going to go with coilovers. Now I see why others have gone with the 35et with more poke
If they're only your track wheels, why does 10mm of poke matter??
flickr
Old 06-17-2013, 03:29 PM   #17
loogs
Drives: on cruise control
ive got the exact same wheel/ tire setup and im not rubbing at all. im dropped an inch on eibachs too. i am getting fortune coil overs but its mainly because i want to go lower. like i posted in my thread, the only issue im having now is that at full wheel lock, the rim hits the tie-rod. but thats it
loogs is offline   Reply With Quote
Old 06-17-2013, 04:34 PM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think 3-5mm of spacers is the best solution for your track day.
BRZ RN (03-17-2015)
Old 06-17-2013, 05:42 PM   #19
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
which wheel and which direction at full lock? are you hitting the tie rod because its lowered?
garfull is offline   Reply With Quote
Old 06-17-2013, 05:48 PM   #20
garfull
garfull's Avatar
Thats what I was thinking so I already put in an order on some coilovers. I wanted to be systematic and do small incremental upgrades so I can see how the car behaves but looks like thats out the door.
Thanks for everyone's advice.
Originally Posted by BlaineWasHere View Post
The et45s will fit fine with coils but won't be flush, they will sit inside the fender some due to the negative camber you'll gain on the drop. This is what I have.
Coils is a better way to go anyway, you'd put drop springs on stock struts and ware those out quickly then in a year when you get new struts you'd wish you'd just put that money into coils in the first place. Made that mistake on other cars before.
Old 06-17-2013, 05:59 PM   #21
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
It's the quality of damper (weather is a coil or stock style strut) that impacts the ride/handling more than the springs or anything. Putting drop springs on stock struts was not likely to change the handing hardly at all unless the rates are different than stock.
Old 06-17-2013, 06:47 PM   #22
loogs
yeah just go with coils
Old 06-18-2013, 04:56 AM   #23
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I have cured this (under normal driving conditions) with an alignment. Slight negative toe and also by adjusting the camber at the strut rather than the camber top gives enough room to not hit. Mine is lowered 20mm. The lower you go the more it hits. I'm sure it could rub in some situations but will be using the OEM wheels now for any track activities so I'm happy now..
86•BRZ is offline   Reply With Quote
Old 06-19-2013, 01:45 AM   #24
IllusiveFRS
IllusiveFRS's Avatar
Drives: 13 Scion FRS, Asphalt
only time you should rub is under full lock steer and suspension under compression, I personally don't see you full lock at a track event or Autox. I have had 0 rubbing on my RPF1's and I run 255/40/17(must have coilovers to run this size) Hankook RS3's on 17x9 et45. as mentioned previously I am running as much camber as possible just by the lowering and factory bolts which I believe yields -1.5. good luck with Future mods
13 FRS Asphalt
Jackson Racing Supercharged, Nameless Performance front pipe with cat and helmholtz resonator, Greddy EVO3 exhaust, tuned by Church Auto Testing. Cusco braces all around, KW V3 coilovers. Winmax brake pads with DBA rotors. Thank you CSG for all the useful help!
IllusiveFRS is offline   Reply With Quote
Old 06-19-2013, 03:05 PM   #25
garfull
garfull's Avatar
thanks for the info. yeah no full lock at the track for sure. just wanted to know because i have a short in length but tall in height driveway that i will have to drive thru sideways once lowered.
Old 09-17-2013, 10:42 AM   #26
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
I'm putting 17x9 +32 offset wheels with 245/40/17 tires on tomorrow. I have Eibach sportlines and whiteline camber bolts. I REALLY hope I don't rub but if I do should I get spacers too? Also, should I wait to get it aligned after I put the wheels on or before?
Thongpocket is offline   Reply With Quote
Old 09-17-2013, 12:53 PM   #27
garfull
garfull's Avatar
32 offset you will be fine with that setup. only the 45 offset puts you close to the strut. a lot of people run 35 offset no issues.
Old 09-17-2013, 01:01 PM   #28
MyRx
MyRx's Avatar
Get the alignment after you get the wheels on. The shop should align with the new offset of wheels.
I have Sportlines and same camber bolts. I also have WL top hats and they aligned my fronts to -1.9 (bolts and hats = up -3). Great bite and corner handling. But just the camber bolts only go to -1.5 so try that first and see how you like it.
The Following User Says Thank You to MyRx For This Useful Post:
Thongpocket (09-17-2013)
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 03:51 PM
Wheel Directory: OEM Nissan GT-R 20x9.5 +45 MaDBaRMaN Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-01-2014 10:31 AM
Wheel Directory: Drag DR-19 17x7.5 +45 sirhc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-08-2013 02:47 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
largest tire for 19x8.5 et45 garfull Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-24-2013 11:44 PM
