Old 06-17-2013, 12:19 PM   #43
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by carbonBLUE View Post
if there were a way to run a drive shaft through a fuel tank, then it would have been done, saddle shape tanks have solutions, a pump system or relocate the fuel tank to the trunk with an aftermarket option.
it just depends, if you are over 1/4 full you probably wont see problems on the street. only people tracking the frs/brz see problems and there are solutions for them depending on how serious they want to apply the car.
My BMW E30 has the same style tank, and we suffer from the same issues when the tank gets low. There is a crossover pipe that helps some, but can't flow the amount needed under hard cornering. The best solution is a transfer pump to take fuel from the passenger side of the saddle to the driver side. None of the SpecE30 drivers want to run an aftermarket tank in the trunk due to putting that large weight so high up in the chassis when compared to the OEM tank. I just always start my races with a full tank.
qoncept (06-17-2013)
Old 06-17-2013, 12:51 PM   #44
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Mine comes on, I fill up, and its always 10.6 before the pump clicks. That's a shitload left so I feel you OP. Granted I've only filled up twice since Ive had her lol. 24 and 25mpg average :/
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
WolfpackS2k (06-17-2013)
Old 06-17-2013, 12:57 PM   #45
qoncept
qoncept's Avatar
There's a trick to it.
qoncept is offline   Reply With Quote
Old 06-17-2013, 01:04 PM   #46
BlueDubbinTDI
My commute is a lot of stop and go 4 miles to work. I don't plan to hypermile this car though lol it is what it is.
Old 06-17-2013, 01:06 PM   #47
qoncept
qoncept's Avatar
Yeah yeah, I just had to have a friend snap a pic since I was being pretty ridiculous. 20mph in 6th every day. We'll see how my mileage looks after autox's 7 weekends in a row. I was at 31mpg for the tank after an autox and a 2 hour drive yesterday.
Old 06-17-2013, 01:12 PM   #48
thill
You sir, should consider a Prius.
Old 06-17-2013, 02:27 PM   #49
King Tut
NASA SpecE30 Racer
King Tut's Avatar
20 mph in 6th gear has got to be damaging the motor. I hate the way 6th feels at 42 mph.
Old 06-17-2013, 02:51 PM   #50
qoncept
qoncept's Avatar
Just idling on flat roads.
Old 06-17-2013, 04:50 PM   #51
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Autox'ing shouldn't hurt your mileage much at all. An average autox consists of less than 10 miles of total driving (all runs combined). Even driving flat out you'll barely use one gallon of fuel.
Yeah, whenever I would track my S2000 the fuel tank seemed large enough to just make it through a day of an HPDE. Like clockwork the fuel light would come on when I was leaving the track at day's end. Given that both cars share the same sized tank (13.2 gallons, 50 liters) I would imagine results in the BRZ will be similar. Never had any fuel starvation problems either.
Old 06-17-2013, 04:57 PM   #52
qoncept
qoncept's Avatar
At my first autox I reset my trip odometer and economy. I drove exactly 8 miles and it read exactly 8.0mpg. I average about 35mpg and a tank a week. That makes my full tank mileage about 32mpg. So almost 10%.
Old 06-17-2013, 05:19 PM   #53
WolfpackS2k
Out of curiosity why are you obsessed with your mpg? Regardless of how the number drops you're only "costing" yourself around $5 (or less) from that bad mileage, from autoxing. And I'm talking in the long run. Throw in your low fuel economy from an autox into your rolling average over over a month and it's a blip on the radar.
Again, what's the point?
Old 06-17-2013, 05:25 PM   #54
RurumariGhost
Drives: Dark Grey Metallic 2013 BRZ
I fill up at 1/4. I worry about suspended particulates getting into the engine if i go much lower. Given I buy high quality gas and am probably being ocd, but better safe than stranded
RurumariGhost is offline   Reply With Quote
The Following User Says Thank You to RurumariGhost For This Useful Post:
DeeezNuuuts83 (06-17-2013)
Old 06-17-2013, 05:31 PM   #55
WolfpackS2k
I don't think that would be anything to worry about unless your car was 10+ years old.
Old 06-17-2013, 05:37 PM   #56
DeeezNuuuts83
Drives: 2006 Evo IX SE
Maybe he plans on keeping the car that long and would like it to run as closely as possible to new throughout ownership.
DeeezNuuuts83 is offline   Reply With Quote
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 09:33 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 04:56 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
