Old 06-15-2013, 03:59 PM   #1
Pneub
Drives: Dark Grey BRZ
Swapping rear brakes to match Stoptech BBK
I have red Stoptech BBK in the front and I'd like to have something nicer on the rear without spending another 2K. Can I pull any STI rear brakes and put them on? Are there other cars that have good rear brakes I could pull from?
Pneub is offline   Reply With Quote
Old 06-15-2013, 05:27 PM   #2
asia_minor
Superleggera
Drives: 2016 Mazda MX-5
2004 STI rears should do nicely (powder coated red, of course).
problem is finding a set.
asia_minor is offline   Reply With Quote
The Following User Says Thank You to asia_minor For This Useful Post:
Pneub (06-15-2013)
Old 06-16-2013, 06:47 PM   #3
OrbitalEllipses
Drives: Attitude
2004 STI rears require a $250 bracket...you want 2008+ STI rears for "bolt-on" fitment.
asia_minor (06-17-2013)
Old 06-16-2013, 07:11 PM   #4
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Paint stock rear calipers red. They are as good as STi bremobs.
Old 06-16-2013, 07:29 PM   #5
mashal
DADA
mashal's Avatar
Drives: 2013
This. If your lucky to find one I'm sure you'll be paying 1g for it
mashal is offline   Reply With Quote
Old 06-16-2013, 07:32 PM   #6
swift996
swift996's Avatar
I'm thinking of swapping pads, throwing on slotted rotors, and stainless lines when it's time to replace. I'm hoping that will match my Wilwood front kit well.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-16-2013, 08:19 PM   #7
Pneub
My main goal here is just to match the style and color by having a nice flat surface to powder coat or paint red. Spending a grand to have red rear brakes just doesn't make sense to me and painting the ugly stock ones won't work either. I guess I'll just have to deal with it.
Old 06-16-2013, 09:39 PM   #8
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Forgive my ignorance, I'm not from subaru land. Do the STi rears have the drum e-brake?
spdfreak is offline   Reply With Quote
Old 06-17-2013, 02:21 AM   #9
asia_minor
Superleggera
yes.
spdfreak (06-18-2013)
Old 06-17-2013, 10:14 AM   #10
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
So are you looking to even the system out because there is too much front brake? Or just looking for something pretty?
Stock brakes on this car are fantastic. IMO, I wouldn't touch a thing, even for heavy track use. Upgraded pads, lines, and fluid and just go.
That being said, which stoptech kit do you have? 328mm or 355? You may want to contact them as certain kits are designed to work with the factory rear brakes and others are not.
GTM_Challenge is offline   Reply With Quote
Old 06-17-2013, 12:54 PM   #11
Pneub
It's all visual. My car is a daily driver and have the 328mm which is doing more than enough to stop my car. My rear brakes work great but are just ugly.
Old 06-17-2013, 01:16 PM   #12
OrbitalEllipses
Drives: Attitude
Little known fact, the rear Brembo results in LESS rear brake...so while you're going for looks, that may not be the best route as far as performance. Just food for thought.
Old 06-17-2013, 01:46 PM   #13
djdnz
1337
Drives: 2013 BRZ WRB S/C
Are you opposed to throwing on some caliper paint and calling it a day? 30 bucks and two hours of work.
djdnz is offline   Reply With Quote
Old 06-17-2013, 02:01 PM   #14
Racecomp Engineering
This. The rear Brembos are larger yes, but less brake torque due to much smaller pistons. So the only thing you would really be evening out is looks.
- Andy
Sportsguy83 (10-09-2013)
rear brakes
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 01:37 AM
Rear brakes on base gt model of gt86 acro Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-01-2013 10:09 PM
B2autodesigns Suspension and Brakes Cusco, Eibach, Tein, H&R, Whiteline and Stoptech b2autodesigns Brakes, Suspension, Chassis 44 01-17-2013 11:18 AM
StopTech Stainless Brake Lines (Front and Rear) for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 1 07-19-2012 01:41 PM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 10:58 AM
