Old 06-06-2013, 02:22 AM   #15
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I will be attempting to cut some OEM struts with a #3 pipe cutter I bought from harbor freight for $20 tomorrow. Wish me luck and hopefully I won't screw anything up too badly.
I've had my prokits and Koni yellows for a couple weeks now and I'm dying to get them on but want to do the install myself (with a friend that knows more than I do).
mit_peid is offline   Reply With Quote
Old 06-16-2013, 03:36 PM   #16
mit_peid
Boosted Noob
mit_peid's Avatar
I just did the front install with the Koni yellows and Eibach Pro-Kits. Pro-Kits are advertised to be a 1" drop but I'm closer to a 9/16" drop right now immediately after the front install (still need to do the rear next). I didn't use a torque wrench for the top nut either (since I don't have the right adapters on my 1/2" drive torque wrench for it) to get to 37 lb fts. I just torque'd it slightly more than hand tighten hoping I get in the ball park.
This may not be a question about the Koni Yellows but more so about the Pro-Kits, but how much do springs typically settle?
red door handle inserts abutterman Cosmetic Modification (Interior/Exterior/Lighting) 4 08-04-2015 08:10 PM
Update on Koni inserts Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-18-2014 04:39 PM
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 10:29 AM
Modellista fender inserts Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2013 01:42 PM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 05:48 PM
