Old 02-13-2013, 10:47 AM   #1
Turn in Concepts
Turn in Concepts's Avatar
Update on Koni inserts
First batch of Koni inserts are in the states and shipping to vendors and distributors now.
We kind of cheated and drove 20 minutes down the road to pick ours up.
Turn in Concepts is offline   Reply With Quote
Old 02-13-2013, 10:55 AM   #2
Racecomp Engineering
Huzzah!
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 02-13-2013, 10:57 AM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Shorter than stock, with same stroke?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-13-2013, 10:57 AM   #4
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
These w/ RCE Yellows.
Old 02-13-2013, 11:45 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Are there instructions anywhere on how to disassemble the OEM struts and install the Koni yellow inserts? @Racecomp Engineering , @Turn in Concepts
What can we expect from the Konis plus the RCE Yellows? Stiffer than stock, but what else as far as the detailed specs of the combination goes, and how does that combo compare with a quality coilover (KW, RCE, Eibach) set in regards to adjustability and ride quality?
Old 02-13-2013, 12:42 PM   #6
Here's a good thread on installing the Konis:
http://forums.nasioc.com/forums/show....php?t=1219607
I'll let TIC comment on the 2nd part since they have the only time spent with Koni and RCE Yellow at this point! Obviously you lose out on height adjustability to a coilover, but since we're sticking with a mild drop and medium spring rates, ride quality should be very good since you have some decent travel left and on the softer end Konis can be pretty comfortable. And when adjusted up, the Konis can get quite firm if you need them to be. You're just limited in spring rate compared to a coilover which can easily swap to stiffer springs.
- Andrew
Old 02-13-2013, 03:55 PM   #7
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Want to try these with our Hotchkis Springs and camber plates. I too am interested if they have the same fully collapsed length as OE. It would be nice to have a slightly shorter shock for lowered cars.
Nitro22 is offline   Reply With Quote
Old 02-14-2013, 11:53 AM   #8
Wepeel
Drives: '13 BRZ Ltd
Dumb question - I thought the rear was a full shock replacement? Where is the spring perch?
Wepeel is offline   Reply With Quote
Old 02-14-2013, 12:09 PM   #9
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Subscribed. Cant wait to have some Konis on my car!
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-14-2013, 12:24 PM   #10
infinite012
Drives: 13 DGM BRZ Ltd
Looks like the seat for the spring perch is there, just gotta put it on the shock.
infinite012 is offline   Reply With Quote
Old 02-14-2013, 06:54 PM   #11
tisb0b
Drives: Grey GT86 MT
Definitely cannot wait to see how the RCE Springs + Koni's perform.
tisb0b is offline   Reply With Quote
Old 02-14-2013, 08:52 PM   #12
Captain Insano
Similar question to ATL BRZ except in the opposite direction...
TiC, please provide review when you can. I'm wondering how much different/better a koni/aftermarket spring combo (eibach pro, RC yellow for example) is compared to stock/aftermarket spring combo (again eibach pro, RC yellow for example).
Old 02-15-2013, 06:55 AM   #13
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I was worried about it the difficulty of doing inserts but now its not looking so bad. Pics when they're assembled please!
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 02-15-2013, 02:20 PM   #14
Turn in Concepts
Koni with RCE Yellows
After a few months of testing this suspension setup we have completely fallen in love with it. The ride quality is very similar to stock and the car is quite comfortable to drive making this setup perfect for a daily driver. As expected, the only noticeable difference in comfort is found over large bumps and rough patches in the road however we found that for street driving, setting the dampers to their lower settings minimized the increased roughness of the Konis compared tot he OEM setup.
When you push the car in the turns, the fun really begins, much of the stock body roll is eliminated. The responsiveness of the car at turn in is astounding! The nimbleness that the car has in stock forum is not lost with this setup. The car can still be thrown around and controlled but is now even easier to control at the limit. Whether you are tracking, Auto X, or just hooning the car is simply more fun to drive, and much faster!
For anyone looking for a setup that looks great, performs great, and feels great this is the setup for you.
red door handle inserts abutterman Cosmetic Modification (Interior/Exterior/Lighting) 4 08-04-2015 08:10 PM
Koni Suspension Components dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 06-20-2013 09:00 PM
FYI: Status of Koni Sports Sam Strano Tracking / Autocross / HPDE / Drifting 68 06-14-2013 03:19 PM
KONI!! Are here! Turn in Concepts Brakes, Suspension, Chassis 14 04-01-2013 06:38 AM
Cross member bushings vs. Inserts wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-22-2012 02:40 PM
