Drives: 2013 WRB BRZ
KONI Inserts - Installation Advice?
I have questions regrading Koni front inserts installed on oem top hats:
Drives: Sterling BRZ Ltd
mine look the same, I have white line mounts so they have there own covers. I drilled a small hole in the center so just the tip of the adjuster pokes through, should keep most of the grime out.
I will probably pull a strut apart again to make sure everything is as far down as possible, I would like to see some more spare treads.
Drives: Attitude
Pretty sure the front nuts are more than 37ft lbs. Realistically, the nut is going to stop on the threaded portion of the shaft once the nyloc seal is engaged. Make sure it's nice and snug.
I cut a hole in the OEM dust cover for the adjuster to poke through. |
yeah 37 does sound low now that I read it. I'll admit I didn't exactly torque mine, I welded up a custom tool since i dont have fancy through sockets.
Thanks for the input!
I did feel that the nyloc seal (blue color seal) engaged. So it should be alright then. I will also drill out the rubber OEM dust cover for the adjuster. Here is Koni saying 37 ft lbs: |
Drives: Attitude
I think the rear are like 20lbs, its not a lot.
Drives: Attitude
The rear is secured with an M12 nut and flat washer (not a flanged nyloc nut like the front) and Koni provides a table with different values based on size (M10, 12, 14) and type of fastener (flanged nut, nut with flat washer, etc.). I can dig this up when I get home tonight.
#9 | |
#10 |
I think stock was much lower?
#12 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
#13 |
#14 |
Lap time enthusiast
| red door handle inserts | abutterman | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-04-2015 08:10 PM |
| Update on Koni inserts | Turn in Concepts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 06-18-2014 04:39 PM |
| KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni | Circuit Motorsports | Brakes, Suspension, Chassis | 115 | 08-30-2013 10:29 AM |
| Modellista fender inserts | Minovsky | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-25-2013 01:42 PM |
| Koni inserts or wait for full Koni replacements | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-18-2013 05:48 PM |
