Old 06-16-2013, 01:25 AM   #757
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by Tobz View Post
Got it installed yet? Let us know how u went!
Sent from my HTC One using Tapatalk 2
Somewhat? Forgot my laptop at a buddies house so haven't flashed the rom yet. Unit works and plays music, gotta run the GPS to the vent and then run RCA cables to my new amps. No idea how to do the antenna yet, been reading the last few pages and hope someone figures it out 100% and posts it up
pheoxs is offline   Reply With Quote
Old 06-16-2013, 04:27 AM   #758
Tobz
Tobz's Avatar
Drives: Toyota 86 GTS
Did u get the rear camera working?
Tobz is offline   Reply With Quote
Old 06-16-2013, 09:30 AM   #759
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Hi , guys...I get a trouble...I insert on T7019 the HDSPA key with Vodafone Sim enabled to surf. On PC and Mac the key works fine...but on 7019 signal is there (blue led light for Hdspa) but it seems no connection is. I set the correct APN...but nothing. I tried on hub and front, disabling wifi and so on, Any ideas..? are there some apk to solve this trouble?
Trap63 is offline   Reply With Quote
Old 06-16-2013, 12:00 PM   #760
pheoxs
don't have one yet
Old 06-16-2013, 02:52 PM   #761
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Have you tried it with just the key directly to the USB female lead rather in a USB hub?
Personally I'm not using a 3G or 4G connection. I simply link it using wifi to personal hotspot on my iPhone. I know others with android phones also tether it to their phones as well. Works much better that a SIM dongle from the glovebox.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Trap63 (06-16-2013)
Old 06-16-2013, 03:30 PM   #762
Trap63
Trap63's Avatar
Tried on front usb and as single on back no way to work,......HU works fine with iphone hotspot..., so I'll manage with tether...
Old 06-16-2013, 04:26 PM   #763
nzer
nzer's Avatar
Did you go through all the head unit setup process of the carrier and all that stuff? Mine didn't work initially and had to google some of my provider settings to get all the fields filled in correctly.
Mine didn't come with a manual although got one later and it details all the setup fields you need to complete so it will work with your provider.
Trap63 (06-19-2013)
Old 06-16-2013, 04:49 PM   #764
Trap63
Trap63's Avatar
I tried with all settings found on provider.....now I am writing with wifi!
sent by my android car navi
Old 06-16-2013, 04:52 PM   #765
nzer
nzer's Avatar
Oh well - the tether signal is generally better anyway!
Trap63 (06-16-2013)
Old 06-17-2013, 11:57 AM   #766
pheoxs
Random question, on the stock rom my wifi dongle doesn't work on the rear usb port, only the front.
Haven't tried since I rooted it (will try tonight)
Old 06-17-2013, 01:21 PM   #767
Pacific
Pacific's Avatar
Drives: 5 Celica since 1978.Now a GT86
Trap63 regarding the various connections.
The brake wire, is to be connected to pin 6 on 16pins connector. This will avoid to look DVD and may be change GPS infos during driving this means if brake is not on ie not shielded. Personnaly, although I do not watch video during driving I have connect same directly to shield and is OK.Must point out that on T7019 menu you have the option to use this function or not. Leaving this wire free will certainly have no consequences.
For the rear camera, the vidéo plug to use is noted "CAMERRA" this will be switched on when the wire noted reverse is connected to pin 2 on 28pins connector and rear gear is on.In fact, this pin will give 12v when rear is on.
Regarding root, I have used the last Hal9k firmware for 2.3.7 with new Google Play. Found on 4pda russian forum.
Every things are well functionning, I installed TomTom as GPS and other little things for Android, wifi is also ok. I make various trial on desk as I have not yet the time to put in the car, and this will be the opportunity to have a look on the LEDs.
Pacific is offline   Reply With Quote
The Following 2 Users Say Thank You to Pacific For This Useful Post:
Tobz (06-17-2013), Trap63 (06-19-2013)
Old 06-17-2013, 02:44 PM   #768
nzer
nzer's Avatar
Are you using a USB hub on the back or only the wifi dongle?
I had two hubs and one worked with multiple things plugged it and the other hub didn't.
So, if using a hub suggest you try plugging directly in. If tat works then try another hub. Also, make sure you have it plugged in before turning the unit on. If you plug and unplug stuff while unit is on they sometimes won't work.
chris's fr-s (02-13-2014)
Old 06-17-2013, 02:54 PM   #769
pheoxs
This was just straight plugged in out of the box. I'll try again tonight I don't have my sockets with me at work. The front works great it can be on and plug it in and it immediately detects everything.
I'll try again with the rear
Old 06-17-2013, 07:26 PM   #770
Ghostmerlott
Drives: GT86
That shouldnt be the case, is the LED on the dongle flashing?
Ghostmerlott is offline   Reply With Quote
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
