Old 06-13-2013, 08:37 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Guys/Gals who installed KWV3 install these washers?
I've been reading researching till eyes red. Recently I've seen these washers come up "alot" in threads and more recently reference to them being needed on install for even the KW V3s is this so??
Old 06-13-2013, 09:14 PM   #2
cnk
Drives: '13 DGM BRZ Limited
I got my KW V3's from RaceComp and they installed the washers.
Old 06-13-2013, 09:24 PM   #3
Nardi330
Nardi330's Avatar
Drives: 86
I got my mechanic to install my v3 with this washer. i have stock top mount.
Nardi330 is offline   Reply With Quote
Old 06-13-2013, 09:38 PM   #4
powerj2
powerj2's Avatar
Drives: 2013 Scion FRS
I didn't put these in. Whats the reasoning behind?
Pew
powerj2 is offline   Reply With Quote
Old 06-13-2013, 10:28 PM   #5
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yes i run these, or else the bearing in the top hat will have issues.
Jive Turkey is offline   Reply With Quote
Old 06-14-2013, 01:29 AM   #6
OICU812
Just a dude
OICU812's Avatar
So even running stock too hat you need these? Frustrating these do not come included why wouldn't KW do that to begin with? I only recently discovered this in reading on the Tarmac thread and trying to narrow down for a final choice here .... Thank good was for forums anyhow...geesh
Old 06-14-2013, 01:35 AM   #7
OrbitalEllipses
Drives: Attitude
Anytime you're not using the OEM upper perch, you need this washer. If you take a look at the OEM upper perch, it has this washer welded onto it.
In the Impreza, this washer is separate from the perch.
Where can I buy the trans and diff washers? ngabdala Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-09-2013 12:35 AM
Can the transmission crush washers be reused? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-15-2013 07:35 PM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 12:24 AM
HAPPY 8/6 Guys and Gals! Filipino Royale BRZ First-Gen (2012+) — General Topics 11 08-07-2012 07:05 AM
