Old 05-06-2013, 11:54 PM   #29
jdogi
Just so that I'm clear, are you saying that that the DW265 is really a drop in replacement? Meaning all the factory parts can be used, including the stock "filter sock" and the lower portion of the internal canister?
I was not terribly happy to have aborted my install of the 290lph "drop-in" pump when I realized that I was going to need to use "duct tape and paper clips" to get it properly secured. Okay, I was pissed. :-)
Side question, does the high pressure pump feed off of the output of the drop in pump, or is it fed by a separate feed line from the tank?
My quick math tells me that 4x500cc/min=2l/min=120lph @ 100% duty cycle. I don't know much about sizing fuel pumps, but, assuming that we only need this pump to feed these 4x500cc port injectors, then a 265lph pump shouldn't have any problem maxing out these 4 injectors. And that doesn't even take into account that at the time of highest fuel needs (let's say 14.5psi [1 bar]), these 500cc injectors will only be flowing effectively ~400cc/min at 100% duty cycle, since they'll be trying to squirt against 14.5 psi manifold pressure.
jdogi is offline   Reply With Quote
Old 06-11-2013, 11:58 PM   #30
kaybee123
Drives: Scion FR-S
I have the 290 LPH....
Wtf do I do since it doesn't fit?!?
Removing the filter sounds like a bad idea considering you'll probably mess up your engine if there's residue in the gasoline at the pump.
Zip-ties?!
What have people done?
kaybee123 is offline   Reply With Quote
Old 06-12-2013, 10:35 PM   #31
kaybee123
Drives: Scion FR-S
holy shit! I just started my car and fuel was leaking through the bottom of the car!!!
Help!
Old 06-13-2013, 02:00 PM   #32
kaybee123
Drives: Scion FR-S
Update: Pulled it out, secured back in... now the fuel pump isn't working :\
Old 06-23-2013, 12:37 PM   #33
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
You don't hear it turning on when you turn your key to on? (Or with PB start no foot on clutch, hot button twice.)
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-23-2013, 01:58 PM   #34
kaybee123
Drives: Scion FR-S
I resolved this issue.
The fuel injector was short circuiting (injector fuse was blowing) which was the reason the car wasn't sending any instructions to the fuel pump.
When we fixed the short, the car started no problem.
Old 06-24-2013, 08:05 AM   #35
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Zip-ties?!
Guys, make sure to quote the person you are asking the question to or mention them or something. If not, its impossible for me to know you asked unless I come in and look for it.
The DW 265c still requires the stock fuel sock to be cut out. No big deal on that one, if you ever need to go back to stock the stock sock will still work with the stock pump. But, the canister does close completely. Since I made my post, I had to re open the canister and use 4 O rings for the fuel pump in order for it to keep pressure and work 100% even under full load (I think 3 O rings would have worked).
On the 290 LPH pump, it has been found out that you can close the canister with it. The key is NOT using the white spacer but using 3 O rings.
I had used zip ties to hold it in place. Good luck everyone!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Aaronimoe (08-02-2016)
Old 07-06-2013, 01:22 PM   #36
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Odd question: Does this resolve the "crickets under the hood" issue? I took my BRZ in and they replaced it under warranty at 7500 miles because of the cricket noise, but the replacement is still making the same noise.
omegared19 is offline   Reply With Quote
Old 07-06-2013, 01:29 PM   #37
charged86
charged86's Avatar
No it does not
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-06-2013, 01:32 PM   #38
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
u had ur high pressure fuel pump not the actual fuel pump thats under the back seats
Old 07-06-2013, 01:36 PM   #39
omegared19
omegared19's Avatar
Well $#!T......now I know. But I'm dying to get rid of that noise.
Old 07-06-2013, 01:39 PM   #40
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
imo
noise is normal due to Direct Injection system
try to use shell v power
Old 07-06-2013, 01:59 PM   #41
omegared19
omegared19's Avatar
imo
Yeah, I'll give it a shot
Old 07-06-2013, 03:17 PM   #42
Lonewolf
Lonewolf's Avatar
Drives: Moped
And any future replacements will make the same noise...until an entirely new pump design is released, the crickets will come back
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
New tail lights and fuel pump inc MindtheGap Mid-Atlantic 14 12-19-2012 07:42 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
