Old 06-13-2013, 02:12 PM   #15
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
gas cap?
Freetime is offline   Reply With Quote
Old 06-13-2013, 02:15 PM   #16
sklimo
No she is running fine. Gas cap on and tight
Old 06-13-2013, 02:26 PM   #17
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
disconnect battery and see if it comes back again
Old 06-13-2013, 02:27 PM   #18
sklimo
Ok
Old 06-13-2013, 02:35 PM   #19
sklimo
Still on.
FML. Got 7 am appt.
Old 06-13-2013, 03:06 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Is there any chance the car was damaged during the process of jacking it up to put the exhaust on?
Old 06-13-2013, 03:28 PM   #21
Chee-Hu
Chee-Hu's Avatar
Cam shaft sensor, crankcase sensor. I think time to call dealer
These have nothing to do with the exhaust unless I'm completely mistaken.
Chee-Hu is offline   Reply With Quote
Old 06-13-2013, 03:32 PM   #22
sklimo
Backed over the pit here at work so no.
I know this has nothing to do with exhaust now after reading codes. Just crazy ass timing I guess???????
Old 06-13-2013, 03:44 PM   #23
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
put your stock exhaust back on before you go to Dealer.
Old 06-13-2013, 04:07 PM   #24
sklimo
Won't have time. Shouldn't be an issue should it??
Old 06-14-2013, 12:12 AM   #25
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
In theory you should be fine, but some dealers are worse than others when it comes to mods.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
sklimo (06-14-2013)
Old 06-14-2013, 09:38 AM   #26
sklimo
Found out it is the camshaft position sensor, and there is a TSB for it!!
Also found out if run low on oil that will throw the codes
Old 06-14-2013, 12:48 PM   #27
sklimo
All fixed!!!!!!! Thanks for all your input!!!!
LOC Needed? delusional Electronics | Audio | NAV | Infotainment 2 04-09-2013 10:24 AM
Lug Nut Help Needed USMC -FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-17-2013 11:06 PM
FR-S needed in Miami. greenguy101 Southeast 8 10-19-2012 02:08 PM
MOD's Needed. Help Please! GT-ROKIN Cosmetic Modification (Interior/Exterior/Lighting) 17 10-06-2012 02:18 AM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 09:12 PM
