Old 05-24-2013, 06:49 PM   #43
smellslikecurry
whats the weight difference on these from stock?
smellslikecurry is offline   Reply With Quote
Old 05-24-2013, 06:57 PM   #44
OrbitalEllipses
Drives: Attitude
Originally Posted by Cade01 View Post
What would you use for rotors? Would you have to re-drill stock ones or will other Subaru ones work?
Redrilled rotors. There aren't many 5x114.3 WRX sized rotors, unless they are Group N or Gravel Spec rotors which I know little about aside from their existence.
KNS Brakes redrills the rotors they sell, which includes the entire DBA catalog.
Old 05-24-2013, 07:40 PM   #45
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Are they going to be as safe as a once drilled rotor, or I there any concern for failure?
Cade01 is offline   Reply With Quote
Old 05-24-2013, 08:35 PM   #46
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
I'm thinking you can do an STi Brembo upgrade. Reuse the 5x114.3 rotors, and upgrade the calipers. Instant "OE" BBK.
Redstar is offline   Reply With Quote
Old 05-25-2013, 01:19 AM   #47
Cade01
Cade01's Avatar
Maybe some caliper adapters?
Old 05-30-2013, 01:06 AM   #48
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Subbed. Interested in this once the rotor thing is sorted out and when a few people have done the swap
Sent from my Nexus 7 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
The Following User Says Thank You to pheoxs For This Useful Post:
AyJay (02-06-2014)
Old 06-01-2013, 01:16 AM   #49
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Imma ask hardrace about this rotor issue. Will update once i've confirmed it.
JackSmiley is offline   Reply With Quote
Old 06-02-2013, 01:51 PM   #50
EarlQHan
Drives: Subarus
Available now: http://www.meganracing.com/product_d...=1580&catid=97
EarlQHan is offline   Reply With Quote
Old 06-02-2013, 05:56 PM   #51
the_butcher
Drives: 2013 Scion FRS
Originally Posted by EarlQHan View Post
YES! Getting these.
How much should I expect to pay for new rotors? Do I just pick out a set of 5x114.3 discs, stick the conversion kit on it, and go? I'm seeing them priced from $50 all the way up into the hundreds of dollars. A link to something that would fit perfect would be appreciated by anyone. Still learning how all of this stuff works. Thanks!
the_butcher is offline   Reply With Quote
Old 06-02-2013, 08:03 PM   #52
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by the_butcher View Post
YES! Getting these.
You also need new wheels and depending on the size wheels, tires as well. From my understanding on other posts, these kits retain the OEM offsets.
From a price standpoint, the $50 conversions are just spacers that convert to 5x114.3 (this will throw off your offsets because they're spacing as well as converting). The "hundreds" of dollar conversions are literally hubs that your axle will fit in. I don't believe this has anything to do with your brake setup, so don't worry about that.
slicktop is offline   Reply With Quote
Old 06-02-2013, 09:28 PM   #53
the_butcher
" *Note: Please make sure the correct size rotors (5x114.3 rotors) are fitted with this kit"
Old 06-02-2013, 09:43 PM   #54
slicktop
Wow, yeah, you're right... whoops!
Old 06-07-2013, 07:45 PM   #55
zlegend
yee
zlegend's Avatar
Drives: mehhhh i lost count.
subscribed
this seems interesting!
zlegend is offline   Reply With Quote
Old 06-08-2013, 02:17 AM   #56
OrbitalEllipses
Drives: Attitude
Don't need them if using 08+ STI Brembos.
Steering Wheels and Hubs Juurian Cosmetic Modification (Interior/Exterior/Lighting) 3 03-08-2013 09:21 PM
Any news on 5x114.3 front hubs for BRZ/FRS yet? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 10-25-2012 10:10 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 12:24 AM
