Old 05-30-2013, 11:15 AM   #43
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by civicdrivr View Post
I'm really hoping thats the case, but the white smoke out of my exhaust while on the dyno concerned me. Same with the compression test that the dealer did. If anything, the compression should rise when warm, not the drop (which is what it did).
I shouldn't have said guys. I was meaning guys other than you. There is definitely a chance there is something wrong with your motor. I was just telling others to not be alarmed by the amount of coolant in the overflow changing often.
civicdrivr (05-30-2013)
Old 05-31-2013, 03:02 PM   #44
zoomzoomers
zoomzoomers's Avatar
I'm going to check this weekend to see if my car is doing this as well. Good luck guys on finding a solution.
Old 06-01-2013, 11:57 AM   #45
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Finally got clarification from the dealer regarding the compression test.
According to them all four cylinders were down 4psi over 15 minutes when hot. That sounds odd to me, and I plan to bring it to a different dealer for another compression test.
Sent from my Nexus 4
ok
1. air is less dense when hotter
when air goes into the cylinder its cooler, the metal in the combustion chamber heats the air resulting in a pressure drop.
2. coolant
i had to fill my coolant overflow twice now, after 25k miles i have yet to add a drop of coolant to my car. Seems like the car has a long break in period for misc items.
coolant also splashes out of the overflow a lot and the engine does run hot enough to evaporate it but not boil over.
my passenger window always works now
crickets... still there but no performance issues yet
idle doesn't dip anymore
ect. ect.
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
vgi (06-01-2013)
Old 06-01-2013, 02:30 PM   #46
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by carbonBLUE View Post
ok
2. coolant
ect. ect.
If you heat a gas and its volume remains the same the pressure will go up not down. The hot metal in the combustion chamber will heat the air resulting in a pressure increase, in theory. That's why hot tires have higher psi than cold. Also, I have never heard of a coolant system having a break in period but I guess its possible for the seals and gaskets and hose clamps to settle in a bit.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following 2 Users Say Thank You to ahausheer For This Useful Post:
civicdrivr (06-01-2013), n0m0h0s (11-17-2013)
Old 06-01-2013, 03:54 PM   #47
carbonBLUE
Reverse Burnouts
Doh... lol i was tired this moring... derp... i guess my brain was trying to relate the post to a nother thread talking about VE... my coolant problems up and disappeared after a while, im only speculating.
(wont forget you)
2011 Infiniti G37x
Old 06-01-2013, 04:05 PM   #48
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
What coolant did u use ? Im going to top mine today
Old 06-01-2013, 09:10 PM   #49
carbonBLUE
Reverse Burnouts
I just use the factory blue stuff. Just get topped off at the dealership, should be free if you are under 24,000 miles.
(wont forget you)
2011 Infiniti G37x
Old 06-02-2013, 12:41 AM   #50
SmsAlSuwaidi
Boosted
I kinda don't have time to visit my dealership >,< guess I'll order it online
Old 06-03-2013, 01:51 AM   #51
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This probably deserves a new thread, but....
[ame="https://www.youtube.com/watch?v=XHBlIvzgfYE&feature=youtube_gdata_player"]Scion FR-S sounds bad - YouTube[/ame]
The car was running weird on the way to work today. It sat for 9 hours while at work, then half way home I started hearing a weird ticking noise. I had been driving at a constant 65mph for about 13 miles. It almost sounded like a baseball card hitting the spokes of a bicycle wheel.
I got off the highway and came to a stop at a red light. The car began to misfire but didn't throw any CELs. The HPFP was chirping loudly without pause. For the first 22k miles I never had a chirp, it came and went once around 22,500. But its been silent since, until tonight.
The car currently has almost 27k miles. It will be going to the dealer first thing in the morning.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-03-2013, 02:33 AM   #52
Dezoris
Dezoris's Avatar
I would not be driving it, could be fuel issue of some type injectors possibly. Remove all your mods as well if possible namely the catch can before you go in.
Old 06-03-2013, 02:35 AM   #53
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yea, only mods related to the engine at the moment are the exhaust and catch can. It sometimes sounds like the popping noise others have mentioned that comes from the direct injector seals.
Parting out HERE
Old 06-04-2013, 08:39 PM   #54
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The dealer opened another Techline case with Toyota. I'll be picking up a rental in the morning, and hopefully getting more information out of the dealer.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
xjohnx (06-04-2013)
Old 06-05-2013, 10:58 AM   #55
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The dealer is going to replace the HPFP and have the car ready tomorrow afternoon. I know my car had the infamous crickets, but I'm trying to figure out how it would cause knocking and ticking from the engine itself (driver side cylinder bank to be exact). I'll let them replace it though, but I will not be taking the car back if its still knocking and ticking.
Parting out HERE
Old 06-06-2013, 04:38 PM   #56
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
HPFP has been replaced, and didn't make a difference. A Toyota field engineer will be at the dealer Tuesday.
Parting out HERE
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
