go_a_way1
Old 05-19-2013, 05:55 PM   #1415
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
What he said ^^.
Originally Posted by FRSTRM View Post
Apologize if these sizes have been touched upon before - wheels really aren't my specialty. I'm considering the Platinum Widow 18"
Brand_____ Platinum
Model _____Widow
Item Weight______30 pounds
How would these fit on stock? I may lower in the future, but not by much.
EDIT: I would also likely get 225/40 tires - would this work as well?
(This isn't my car - I own a Firestorm, but this is how it looks on an FRS [images show 17" wheels])
Holy crap, I really hope that 30 lbs is a typo.
But they would fit and 225/40R18 is a good size for this wheel.
Slick is offline   Reply With Quote
Old 05-19-2013, 06:02 PM   #1416
Slick
Slick's Avatar
Quick google search indicates that these wheels are actually 28.5 lbs. Even if they include the box in the weight, that is way too heavy. Find another set of wheels you like that are closer to 20 lbs or less.
Old 05-19-2013, 07:20 PM   #1417
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
What he said ^^.
Originally Posted by jshadeck View Post
30 pounds? 😬
Yeah - I actually noticed the weight after I posted. It's much heavier than stock and I think I'm going to get back towards stock weight in another wheel
:happy0180:
FRSTRM is offline   Reply With Quote
Old 05-21-2013, 10:07 AM   #1418
nokia7190
Drives: Subaru BRZ limited WRB
Target setup:
Front - 18x8.5 +30 -> 225/40/18
Rear - 18x9.5 +35 -> 255/35/18
Questions:
1) Would they fit stock height and alignment?
2) Would they fit with 1" or 1.5" lowering, front camber...
nokia7190 is offline   Reply With Quote
Old 05-21-2013, 10:17 AM   #1419
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Originally Posted by nokia7190 View Post
Target setup:
Questions:
I think you'll be fine. With an offset of 30 up front, you will poke some.
white_knight is offline   Reply With Quote
Old 05-22-2013, 03:53 AM   #1420
Dephective
Drives: '13 Whiteout FRS
Sorry if this has been covered. Will these fit without fender mods:
17x9 +25 square on wither 235 or 245 rubber
Sitting on Fortune Auto 500's and will be getting camber bolts for the rear. Currently at -1.5F -2.5R
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 05-22-2013, 10:04 AM   #1421
Slick
Slick's Avatar
Doubt this will fit, even with skinny rubber. Max offset for 17x9 is around +35 or +30 with alot of camber.
You can add camber bolts to the front (not available on the rear) and it will give you somewhere between .5 to .75 more negative camber.
For reference, here is a 9" wide +35 wheel with spring compressed to static height (suspension Eibach ProKit with camber bolts installed):
Old 05-22-2013, 09:37 PM   #1422
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
How would a 18x8.5 et +38 square with a 245/35x18 tire sit up front? I am on stock suspension right now but will eventually throw coils on and lower about 1" all around. I know the rear will be tucked but will I have issues up front?
Overland'n'5thGEN is offline   Reply With Quote
Old 05-22-2013, 10:38 PM   #1423
Slick
Slick's Avatar
Good fitment, you will have no issues up front even with lowering or camber bolts.
The Following 2 Users Say Thank You to Slick For This Useful Post:
Overland'n'5thGEN (05-23-2013), WithNolock (05-25-2013)
Old 05-23-2013, 12:31 AM   #1424
taimysho0
Drives: frs
sorry if this is already been covered but i bought a set of xxr 530 in 18x8.75 +33 and looking for tires. i was planning to go with 225/45/18 fronts and 245/40/18 rear and keep car STOCK height, which is why i went with bigger profile. i was told this could cause rubbing issues and i should go 225/40/18 and 245/35/18, is this true and will my initial tire size fit? i want to cover up as much wheel gap/wheel well as much as possible on stock height. thanks
taimysho0 is offline   Reply With Quote
Old 05-23-2013, 01:19 AM   #1425
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Wheel 17X8 +45 i know will fit tire that the guy has on 235/45/17 i would have to replace the tires right?
Lee358 is offline   Reply With Quote
Old 05-23-2013, 10:08 AM   #1426
Slick
Slick's Avatar
If you go with a higher profile, you will have a taller diameter and raise the height somewhat of your car.
Stick to the closest diameter to the OEM size and gearing will not change as a result, so yes, 225/40R18 for front and 245/35R18 for rear will get you almost perfect diameter.
Not sure if there is a reason you are running staggered tires, you could run the same tires front and rear if you have the same wheels and offsets. Even a 245/35R18 all around will not rub on stock suspension. This is an ideal tire size for that wheel width, unless you like the stretched look.
Old 05-23-2013, 10:20 AM   #1427
Slick
Slick's Avatar
Not sure I understand your question.
Your stock tires will fit on these wheels, with a bit of stretch.
If you are buying wheels and they already have 235/45R17, (I think is what you're asking) they will fit although they are taller, and it will alter your gearing by 2.8% (you will be travelling 2.8% faster than your indicated speed). But it will affect your acceleration more because of the gearing, which is not a good thing (unless you don't care about it). But they will fit and not rub.
Better tire size would be 245/40R17 which is almost exactly same as stock.
Old 05-23-2013, 10:23 AM   #1428
stancypants
stancypants's Avatar
Drives: FR-s
I am going for stance look so does anyone know if a 18x9.5+20 front and 18x10+15 has ever been tryed i know i will have to do a fender pull in the fornt and rear with some camber. can anyone suggest some tire sizes for me i was thinking like a 225/35 front and rear any suggestions ?
stancypants is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
