Old 05-22-2013, 02:43 PM   #29
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Just checked coolant while the car was hot, and all the coolant is to the top but when the car is cold it shows low...not sure if thats normal
brichard0625 is offline   Reply With Quote
Old 05-22-2013, 02:56 PM   #30
OrbitalEllipses
Drives: Attitude
Coolant expands when it's hot, so that behavior is normal. As to whether or not the values you see are normal, I can't comment.
Old 05-22-2013, 03:02 PM   #31
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
As long as it continues to show correctly while warm, then you aren't losing any.
Old 05-29-2013, 08:59 PM   #32
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Care to expand on that ? I recently noticed that my coolant is barley over the low mark once it sits over a day or two, but after a long drive its almost full ! Should I just top it off or take it to the dealer , considering I'm going to boost my car soon I'm trying to figure out any issues I have
Old 05-29-2013, 09:15 PM   #33
zoomzoomers
zoomzoomers's Avatar
Rule of thumb: if you measure/check your coolant levels when warm then continute to do so when warm. If you check when cold do so when cold. Just don't mix between the two as someone stated earlier coolant does expand due to temperature.
This issue does seem weird to me. Hope you guys get it figured out. GL.
Old 05-29-2013, 10:06 PM   #34
SmsAlSuwaidi
Boosted
That's what I'm currently doing and noticed when cold ( haven't been driven for a day or two ) it's barley above low
After letting it warm up, and driving to Uni (4sh minutes) it's over 1/4, a 15 minute drive gives me a 1/2 reading
What's weird is after a very long drive 1hour or so it's 3/4 full
I'm lost, I do know coolant tends to expand but that much ?
Old 05-29-2013, 10:16 PM   #35
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This is my issue as well.
When stone cold (sitting for 24+ hours), the radiator itself is down ~2" and the overflow tank is halfway between min and max.
When hot, obviously I don't open the rad cap, but the overflow is about 1/4" above max. That's a huge variation between cold and hot coolant levels.
I haven't had the time to have the compression tested by a trusted mechanic yet, but I'm still planning on it.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-29-2013, 10:26 PM   #36
SmsAlSuwaidi
Boosted
All my readings and assumptions are off the overflow tank, I haven't peaked into the raditor yet. Do you just pop the cap open and look in there ( when cool obviously ) ?
Old 05-29-2013, 11:29 PM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You guys are worrying too much. As long as you have some coolant in your overflow, then don't worry about it.
SmsAlSuwaidi (05-29-2013)
Old 05-29-2013, 11:39 PM   #38
SmsAlSuwaidi
Boosted
thats what i thought ! i told my self as long as my car didn't over heat yet I'm good
Old 05-30-2013, 01:12 AM   #39
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm really hoping thats the case, but the white smoke out of my exhaust while on the dyno concerned me. Same with the compression test that the dealer did. If anything, the compression should rise when warm, not the drop (which is what it did).
Parting out HERE
Old 05-30-2013, 01:20 AM   #40
vgi
Drives: frs
i bought my car a month ago, couple of days later noticed an occasional coolant smell under a load (around 4k rpm, still breaking in the engine so try no to rev it above 4k). took it to the dealer, they said they didn't find any leaks (though I think it was just a visual, the guy said the car is hot, so the system is under pressure, there is no point of doing pressure test). anyways, I put a tape on the coolant reservoir in a morning, while the engine is cold, the mileage was just like 50. Now I have just under 800, one month later, the coolant level is about 3/4-1" down, checked again in a morning.
I just did a quick search for 'coolant' in the topic of a thread and a decent amount of threads came up. It looks like the coolant level drops fairly rapidly for lots of people, yet no one in the threads I looked through were able to determine why. Just seems like it just evaporates at a higher rate when it overflows hot into the coolant reservoir.
Curious to see if there will be a reasonable explanation in this thread or if it will just die off like the rest of them
vgi is offline   Reply With Quote
Old 05-30-2013, 03:46 AM   #41
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Well, coolant doesn't evaporate, so its not that. I will figure out what the issue is, but it may take some time.
Parting out HERE
Old 05-30-2013, 08:52 AM   #42
vgi
Drives: frs
sounds good, just please post here whatever you find, don't let the thread die without resolution
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
