go_a_way1
Old 05-13-2013, 05:52 PM   #1359
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by Slick View Post
I am running -2.2 and will be running track events. This is also my daily driver but am not concerned, and as @ill86 mentioned it is really not that much camber.
To an extent, yes it is driver preference, but it is more about ideal tire wear and your driving behaviour.
Agreed. Just an FYI as I haven't ever formally introduced myself; I teach motor sports for a living. I am fortunate to be on track several days a week. I share my professional experience as a way to give back to the community.
Peace
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 05-13-2013, 05:54 PM   #1360
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by jshadeck View Post
Imho, "too much camber" is when the amount of camber > the amount of camber to benefit the handling of the car. I dont personally care for the look of an over cambered car, and would only run more than -1 if it improved the handling for that specific track/car. But thats just me.
For example, heres the most camber ive ever run
Attachment 37175
Was about -.6 i think, -2" springs, 19x8 +38 with 235 tires
Some cars come with more than 1 degree of negative camber off the showroom floor. Just depends on the car and your application.
Old 05-13-2013, 06:30 PM   #1361
jshadeck
jshadeck's Avatar
Right, in which case it is done for beneficial reasons, not solely fitment or "stance". I was thinking -1 on the twins for my preference.
jshadeck is offline   Reply With Quote
Old 05-13-2013, 07:52 PM   #1362
AZ FRS
Drives: 2013 FRS, 2006 Turbo S2000
thanks slick
AZ FRS is offline   Reply With Quote
Old 05-13-2013, 07:54 PM   #1363
AZ FRS
Oh another question.. What lugs do I need to run 17x9 Enkei RPF1s? Are the stock lugs conical/long enough?
Old 05-13-2013, 08:41 PM   #1364
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Stock lugnuts won't work, you'll need aftermarket ones.
Slick is offline   Reply With Quote
Old 05-13-2013, 09:47 PM   #1365
AZ FRS
What size will I need? I'm thinking a set of Work RS Conicals, but not sure what pitch/thread I need for the hub/wheel combo :o
Old 05-14-2013, 01:25 AM   #1366
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
The wheel has nothing to do with the thread/pitch. You need 12x1.25 which is standard Subaru lugs.
I haven't used those wheels, but usually the spline drive lug nuts will have better clearance. Like McGuards, Gorillas, etc. For instance, I have some Drag wheels that are dual drilled. One bolt pattern would take my Project Kics lug nuts, the other set of holes were too small and I couldn't even fit the socket on. My spline lugs from Discount tire fit just fine, though (Gorillas).
Stock lugs are conical, as are every wheel I've ever used, but I haven't had RPF1s...
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-14-2013, 10:48 PM   #1367
Slick
Slick's Avatar
Exactly what 2point0 said, easiest way is to run spline drives, they will always fit the best. I had a set of McGard spline drives on my RPF1's (RX8), but running Gorilla splines on my wheels right now. Can't beat those for the price.
Old 05-14-2013, 10:51 PM   #1368
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Alrighy another one:
245/40/18 on 18x9 +42? Will I need a spacer in the front and will it clear. I'm lowered on h&r supersport.
The Racers Line is offline   Reply With Quote
Old 05-14-2013, 11:09 PM   #1369
jshadeck
jshadeck's Avatar
Itll be tight, but not quite as bad as mine, ull have an extra 2mm lol
Old 05-14-2013, 11:15 PM   #1370
2point0
2point0's Avatar
Gorilla splines...Can't beat those for the price.
Ya know, I think I got mine thrown in with a set of tires at some point. They're like, "you said you wanted a locking lug nut?" and I'm all, "yeah but not just one on each wheel. I want 'em all!"
Old 05-14-2013, 11:55 PM   #1371
The Racers Line
Any pics? And setup specs?
Thanks
Old 05-14-2013, 11:58 PM   #1372
jshadeck
jshadeck's Avatar
Thanks
Post 1230 and 1236 👍
The Following User Says Thank You to jshadeck For This Useful Post:
The Racers Line (05-15-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
