Old 05-13-2013, 05:11 PM   #15
OrbitalEllipses
Drives: Attitude
It could be pistons/rings for the low compression, but that doesn't make any sense if you add coolant to the equation.
NOTE: I'm only an e-expert, not a real expert.
Old 05-13-2013, 05:13 PM   #16
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I check my oil about once a week, I'm not burning any. I'd think oil consumption would be an issue if it were pistons/rings.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Shenks (05-18-2013)
Old 05-13-2013, 10:21 PM   #17
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
After letting the car sit in the garage since ~2am Sunday morning:
- Overflow tank is past the max line now
- Radiator is 1.5-2" low on coolant
The car will be going back to the dealer in the morning.
Parting out HERE
Old 05-14-2013, 10:23 AM   #18
Mac1235
Mac1235's Avatar
This seems to be a rare occurence so far. Hopefully they will get it taken care of for you.
Mac1235 is offline   Reply With Quote
The Following User Says Thank You to Mac1235 For This Useful Post:
civicdrivr (05-16-2013)
Old 05-16-2013, 01:36 PM   #19
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Finally got clarification from the dealer regarding the compression test.
According to them all four cylinders were down 4psi over 15 minutes when hot. That sounds odd to me, and I plan to bring it to a different dealer for another compression test.
Sent from my Nexus 4
Parting out HERE
Old 05-16-2013, 01:43 PM   #20
ahausheer
Re-member
Drives: Toyota camry
Wonder if the air in the cylinder/pressure gauge cooled off a bit resulting in less psi? Is your oil cloudy or water fouled? How bout the underside of your oil cap?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 05-16-2013, 03:29 PM   #21
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Oil looked fine during the last change. I'll be sending a sample to Blackstone for the next oil change. The cap is clean as well.
The coolant has a weird oily film in the rad filler. Not sure what that is as I'm not losing oil, and I check the oil level often.
I'm almost tempted to put the car back to 100% stock (engine wise) and toss is on the dyno. I wonder if my exhaust has anything to do with the low numbers.
Im also curious if the AOS has a small amount of condensation in it, which is what the white smoke from the exhaust was. I need to get another compression test done though to rule out an engine issue though, but it still wouldn't explain the disappearing coolant.
I'm a bit perplexed by this and just want to toss the damn supercharger on already, but I don't want to exacerbate a potential manufacturing defect and cause them to deny warranty coverage.
Parting out HERE
Old 05-16-2013, 04:06 PM   #22
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I would put 100% back to stock then resolve this issue. GL and keep us updated
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 05-19-2013, 09:50 PM   #23
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Having the same issue..2 months ago i noticed my coolant was low and i topped it off. Went to a meet on may 5th and someone pointed out my coolant was at the low mark and i was curious as to how when i just topped off a month before..its only may 19th and coolant is halfway down again. I do get white smoke coming out of the tail. I have tune/intake/frontpipe. I guess ill have to take my car to the dealership soon.
brichard0625 is offline   Reply With Quote
Old 05-19-2013, 10:06 PM   #24
ahausheer
Re-member
Out of personal curiosity, as I am watching this coolant issue very closely, how does the oil/stuff in your catch cans look if you using one?
Old 05-19-2013, 11:44 PM   #25
Lonewolf
Lonewolf's Avatar
Drives: Moped
Crap, that does sound like a headgasket issue...
Old 05-20-2013, 01:59 AM   #26
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Wish I could tell you, but I'm using a Crawford AOS, its sealed. Its been on the car since ~9k miles.
I drove up to NY this weekend and just got back into town tonight. Tomorrow morning/afternoon I will check the coolant levels again (once cold). I put about 900 miles on the car since the last dealer visit - which was 5/15.
Parting out HERE
Old 05-20-2013, 02:10 AM   #27
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Yeah it does. If oil and radiator fluid are going that quick I would expect something leaking out the head gasket. Check the tail pipe with the AC off and see if you get anything out of it. If you see any fluid I would have it back to stock and to the dealership as soon as possible.
Sent from my SGH-T989 using Tapatalk 2
Old 05-20-2013, 06:59 AM   #28
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I saw something posted where the piston sleeves fall about 2mm or so closer to the crank. I'm honestly not sure if it was a post here on this forum about this car though. I know, not too helpful, but worth a look.
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
