Old 04-26-2013, 12:23 AM   #57
ayau
Drives: Some rust bucket
Originally Posted by Hanakuso View Post
Mine arrive on Monday. I took the day off
Hopefully I'll have them installed plus a few other things
You running the included 275/350 springs?
Old 04-26-2013, 12:26 AM   #58
ayau
@Dave-ROR, is there a certain way the front and rear top plates should face when installing them?
Old 04-26-2013, 12:42 AM   #59
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Without checking to be sure, the fronts will only go in one way correctly (ie camber adjustment is going from one side of the car to the other, not at a drastic angle to the front/rear of the car) and the rears shouldn't matter (as far as the top hat is concerned, the shocks themselves are specific so you can reach the adjustments and so they don't hit anything).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ayau (04-26-2013)
Old 04-26-2013, 01:34 AM   #60
Hanakuso
Yeah. I plan on buying hypercoils or eibach down the road. Maybe I'll wait to see which tires ill buy and see what spring rates work for others
Hanakuso is offline   Reply With Quote
Old 04-26-2013, 08:27 PM   #61
ayau
I removed the middle nut that holds the top hat to swap springs. What should the middle nut on the top hat be torqued to?
Old 04-26-2013, 08:34 PM   #62
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
37ft-lbs.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-26-2013, 08:38 PM   #63
ayau
37ft-lbs.
I'm assuming it's the same for both the front and rear nuts (the front nut is larger)?
Also, what's the best way to remove the top nut for the front struts? I placed a 10mm wrench to hold the rebound shaft and a 22mm wrench on the nut and turned them in opposite directions, but I wasn't able to loosen the nut. I don't want to strip the rebound shaft if this isn't the proper way to remove the nut.
Old 04-26-2013, 08:41 PM   #64
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's what I did. I think I used SAE sizes, I don't recall the actual sizes. By rebound shaft you don't mean the red adjuster I hope? You mean the machined in hex surface right? I'd have to snap a pic to show you.
Yes, both should be 37ft-lbs per Mark @ Eibach. The manual specifies for each thread pitch bolt as well but I haven't double checked the info.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-26-2013, 08:43 PM   #65
ayau
I placed the smaller 10mm wrench on the hex surface (below the red rebound knob). Is that the correct way?
See pic below for reference.
Old 04-26-2013, 09:01 PM   #66
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yep, that is correct. It will be fairly hard to turn it loose.. a lot easier on the car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-26-2013, 09:40 PM   #67
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Would it be OK to run the HVT non-raising camber plates with the R2?
JackSmiley is offline   Reply With Quote
Old 04-26-2013, 11:18 PM   #68
Hanakuso
I want to know this as well.
Old 04-26-2013, 11:33 PM   #69
JackSmiley
JackSmiley's Avatar
Shoot! I'll try it just to find out. If it doesnt work out, then at least we know.
Old 04-26-2013, 11:41 PM   #70
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Just curious why would you want to change them?
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Eibach Multi-Pro R2 Coilover Review donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 254 05-08-2016 11:56 AM
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
