Old 04-24-2013, 04:25 PM   #1
hyperpunx
Stock Break Wear
I took my frs to get its 15k service and noticed on the form that my rear breaks measured 7mm and my fronts measured 9mm. I thought that cars were supposed to wear the fronts faster?
Thoughts?
hyperpunx is offline   Reply With Quote
Old 04-24-2013, 04:32 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Cars with VSC use the rear brakes more to keep the car stable. Same thing happens with my wife's Mazda3.
cnk is online now   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
strat61caster (04-24-2013)
Old 04-24-2013, 04:39 PM   #3
infinite012
Drives: 13 DGM BRZ Ltd
What were the original values?
infinite012 is offline   Reply With Quote
Old 04-24-2013, 04:45 PM   #4
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
most likely 12mm
Deadspool is offline   Reply With Quote
Old 04-24-2013, 05:11 PM   #5
hyperpunx
hmmm..
Originally Posted by Deadspool View Post
most likely 12mm
yeah hard to know for sure.
Old 04-24-2013, 05:21 PM   #6
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Would the E-brake have anything to do with the wear on the rear brakes? Or is the ebrake a drum brake?
gatorbushmen is offline   Reply With Quote
Old 04-24-2013, 05:23 PM   #7
grodenglaive
Drives: asphalt FR-S
the e-brake is a drum
grodenglaive is offline   Reply With Quote
Old 04-24-2013, 06:39 PM   #8
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just showing nannies at work when u don't know.
Old 04-24-2013, 07:45 PM   #9
FirestormFRS
Ebrake is inside the hat on the rear rotor i believe.
FirestormFRS is offline   Reply With Quote
Old 04-24-2013, 08:15 PM   #10
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
lol e-brakes is a drum thats funny
4agze is offline   Reply With Quote
Old 04-24-2013, 08:24 PM   #11
Ozzman
Drives: old
Most rear brake pads start out thinner than the front pads, I wouldn't worry about it.
Ozzman is offline   Reply With Quote
Old 04-26-2013, 05:40 PM   #12
hyperpunx
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-15-2014 12:35 AM
How much camber wear from Eibach Pro Kit slowbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-23-2013 08:25 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 10:50 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 08:21 PM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 05:25 AM
