Old 04-22-2013, 01:55 PM   #29
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Originally Posted by Tainen View Post
plus, you know, you don't really want to support a manufacturing industry that is known to cause cancer in their workers at an extremely high rate, have very little safety laws on the books, and pay their workers just barely enough to live. Not to even mention the average quality of components. Some companies are better than others, but US made products with US sourced materials just can't be beaten.
(for aftermarket parts companies)
+100%
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 04-22-2013, 01:57 PM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by ft_sjo View Post
Why not just put the stock exhaust back on?
Because it is not made in the USA. Duh.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Pete (04-25-2013), raul (04-23-2013), Sportsguy83 (04-23-2013)
Old 04-22-2013, 01:59 PM   #31
djdnz
1337
Drives: 2013 BRZ WRB S/C
I have heard the Perrin resonated is quiet, and made in USA
djdnz is offline   Reply With Quote
Old 04-22-2013, 02:06 PM   #32
ngabdala
America! Fcuk Yeah! Here to save the mothafcuking day!!
Old 04-22-2013, 02:08 PM   #33
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
If you want the most quiet, just buy the Nameless axle back with all the resonators and the biggest mufflers
shu5892001 is offline   Reply With Quote
Old 04-22-2013, 02:51 PM   #34
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
From everything that I have seen, the Perrin-resonated is about as quiet as aftermarket gets. There was an exhaust shootout a while back put on by some magazine and the Perrin was barely above stock in dbs.
Scott
naikaidriver is offline   Reply With Quote
The Following 2 Users Say Thank You to naikaidriver For This Useful Post:
Chad86 (06-05-2016), ngabdala (04-22-2013)
Old 04-22-2013, 02:57 PM   #35
Hanakuso
TRD or Perrin resonated fits what you want. With TRD, at least if you have an FRS the dealership can't give you any BS warranty excuse.
Hanakuso is offline   Reply With Quote
Old 04-22-2013, 03:29 PM   #36
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by ngabdala View Post
I want quality welds done by a human, not a robot, and the company must have good customer support and quality control.
Quality is a by product of consistency. A robot doesn't give 2 shits that's its Friday at 4pm and 6 more whatever needs to get welded, your statement is flawed, you don't give a damn if its welded by a human or a robot you just want to know that it's being inspected by a good QA department, and normally high speed NDT is done by a form of robot as well. There's a reason robots are taking the easy jobs, and that's because they are 99.9% consistent. Not to mention creating your parts at a fast pace, and making them for cheaper, I don't know where this shun for robots is stemming from but anyone that has an easy job should be in fear, with the new tactile sensors are replacing humans left and right, even the McDonald's humans are being phased out.
Side note perrin resonated is very quite, I didn't have to adjust my radio when I went from stock to UEL and perrin resonated. So quite I'm gonna replace it with the titanium cat-back that is linked below my post.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 04-22-2013, 04:24 PM   #37
ngabdala
PM me a price on the resonated Perrin you're getting rid of
Old 04-22-2013, 08:25 PM   #38
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Your statement about proper inspection by a good QA department is absolutely correct - unfortunately I haven't seen many companies who do overseas exhaust procurement that have gnats-ass level QA requirements. Do you tell your customers that their back ordered parts just came in and failed QA because of some little nickel and dime issue that may result in failure and will certainly result in you eating an entire shipment of products or do you just ship the parts out and deal with the collateral damage down the line when the parts eventually fail? It's almost always the latter.
That being said, the fallacy of 'robotic welds' vs. hand welded by skilled craftsmen is that 99% of aftermarket overseas produced exhausts are not robotically welded. They are welded on an auto-tig which is basically a sewing machine for tig welding that requires the operator to rotate the tacked parts by hand aligning the seam with the arc/wire feed. In order to accommodate the imperfections in fitment between part a and b, the settings are cranked up to a high amperage with high wire feed which results in a weld convolution that has a crater in the middle of every single one of the 'dimes' in the weld. In order to make those craters go away and reduce stress risers/leak points in the welds, the speed that the operator rotates the part through the welder has to be very consistent in order to ensure that the next 'dime' in the stack fully overlaps the crater in the prior pulse in the weld convolution. If you look at overseas produced welds, you can usually spot 10-50 areas in a single exhaust where the part was rotated too fast and the crater in the middle of the weld convolution is exposed.
So even in semi-automated overseas TIG welding, you're going to get a reduction in quality and potential for weld failure. Additionally, often times the parts are MIG welded with mild steel wire prior to TIG welding over the tacks using 308 filler wire. Run a magnet along a weld seam from an overseas part and there's a very good chance that it'll stick to every spot where the parts were tacked. The other 'trick' that a lot of these companies employ is to mig weld the entire exhaust, then polish it, and then simply go over the welds with the auto-tig in order to make the welds 'look' like a tig welded joint. This effectively doubles the impact of heating/cooling the part and is one of the other reasons why overseas exhausts often do not fit the vehicle properly.
I've seen a lot of this, worked for companies who do work overseas and I've visited a number of factories where this type of exhaust construction work is done. And I'd never employ that technology again. That is exactly why our systems are hand welded entirely. Our guys don't give a shit if it's 4:30PM on Friday either. They take pride in their work and do a spot on job every time.
And if and when you ever have an issue with our parts, the value-add of a dedicated customer support team and commitment to our customers results in the best solution whether you've had the system for 3 minutes or 3 years.
Last point: I have NEVER seen any manufactured parts made in the USA get polished before TIG welding unless we're talking about fabricated Sched 40 exhaust manifolds. And yet, every overseas exhaust is made exactly that way. If you see shiny and TIG welds, don't believe the Made in USA hype.
Just my 2 cents.
Jason
Jason@Nameless is offline   Reply With Quote
The Following 12 Users Say Thank You to Jason@Nameless For This Useful Post:
Adeets (04-23-2013), Chewie4299 (04-23-2013), DocWalt (12-12-2014), Jeff86 (04-23-2013), Marchy (04-23-2013), ngabdala (04-22-2013), raul (04-23-2013), sho220 (04-23-2013), Sportsguy83 (04-23-2013), Tainen (04-26-2013), tripjammer (04-23-2013), Tunz (04-23-2013)
Old 04-22-2013, 08:35 PM   #39
ngabdala
Thanks Jason,
You're among 4 exhaust manufacturers I would do business with, without any worries about quality and customer care.
The Following User Says Thank You to ngabdala For This Useful Post:
Old 04-22-2013, 08:41 PM   #40
DJCarbine
Thupercharged
DJCarbine's Avatar
For what its worth, the welds on my Q300 and N1 are excellent. Q300 is VERY quiet, almost stock level. I'm selling my Q300 because its too quiet, that's how quiet it is.
For mass production, they have their stuff together.
DJCarbine is offline   Reply With Quote
Old 04-22-2013, 09:31 PM   #41
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
If you want quiet, go drive a Camry.
Grateful Dave is offline   Reply With Quote
Old 04-22-2013, 10:59 PM   #42
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Go with Nameless. I have the cat-less front/over pipe a Helmholtz resonator and the offset axle back with the 5"x6" mufflers and it is pretty quiet until you get on it. Nameless Performance makes their axle backs with larger mufflers now, I believe, so I can imagine it would be even quieter. Reasons: They seem to make some of the higher HP numbers on the market (I could be wrong), the quality is superb, it's made in the PNW, it's fairly priced, you would be supporting a small business, sounds great, I'm sure there's some I'm missing. Talk to @Jason@Nameless he could tell you more about it.
Cade01 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cade01 For This Useful Post:
ngabdala (04-23-2013), Sportsguy83 (04-23-2013)
Loudest to Quietest Exhaust System list (FRZ/BRZ) Invalid Engine, Exhaust, Transmission 163 03-16-2019 02:25 PM
We made it to Japan . V1B FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-13-2013 02:40 AM
What the BRZ/FRS was made for gonzo BRZ First-Gen (2012+) — General Topics 5 11-18-2012 03:29 AM
Lightest/quietest exhaust system out there GTB/ZR-1 Engine, Exhaust, Transmission 25 10-31-2012 01:45 AM
Made some (bad) 'shops! :D Guff FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-27-2011 08:26 PM
