Old 04-16-2013, 02:32 AM   #281
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Originally Posted by LeeMaster View Post
The lights are still on even when you shut the car off, it is just facing "the other direction".
For what it's worth, I parked my car during winter and left the ELM327 scanner plugged into the car for a month and I was still able to start her up no problem.
Seriously think I didn't check the other side? Wow thanks for the credibility...
And with that I guess I wont need to make any comments in this thread.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 04-16-2013, 10:22 AM   #282
reeves
Originally Posted by Kamran View Post
The "remaining fuel" is pretty handy when I'm on the track. I like to run with the minimum amount of fuel in the tank to keep the weight to the minimum. Ideally I would like my low fuel light come on during the last two laps of my run (approx 5 miles in distance). So I tried to see how accurate it is. Maybe someone else could please verify, but I think there is some +/- in the exact accuracy.
My low fuel light came on at 2.4 Gal (or at least when I noticed it) on the road. So I pulled into a gas station and put in 10.8 Gal. The new reading on Torque was 12.5 Gal! 2.4+10.8=13.2, not 12.5. So it may be accurate to within a Gal. Can anyone confirm the accuracy.
The max number seems to be 12.5 gallons for whatever reason.. but not a big deal to me really.. it still reads accurately for anything below that.
On the subject of accuracy close to running empty, I've noticed (on several fillups the past 3 months), that it's accurate ONLY if you're not driving hard. If I'm cruising on the hwy, it'll be very accurate down to 0.5 gallons.. below that, you're on your own.
On a few occasions, I've tried to run my as empty as possible (before filling up with E85), and found the app to be less accurate the more I drove hard (revving to redline in 1st & 2nd, etc.).. HOWEVER, if you're in a position to be able to turn your car off and start it up again (close & re-open Torque app too), it will get a more accurate reading. But like I said, anything around ~0.5 gallons or below won't be useful anymore.
Old 04-16-2013, 07:38 PM   #283
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Thanks for the feedback.
I did some looking into and found out the gas that is in the funnel between the cap and the tank, which maybe a couple of feet and partially full of gas will not be read with the tank. So if I get half a gallon in the tube, when filled to the top, it wont register .
I'll keep it in the back of my mind to allow half a gallon for tolerance when I'm on the track. I wonder if slushing around in the tank sideways or forward/backward is why the accuracy goes down.
But still half a gallon is a lot better accuracy than where I was before all this!
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 04-16-2013, 07:42 PM   #284
zoomzoomers
zoomzoomers's Avatar
I've been running with the Torque app running for the past week or so. These are my quick observations.
* the intake temps run mostly in the 70's. seen it in the 60's and 80's too though
* the trans temp and the coolant temp seems to be exactly the same. Could it be the same exact sensor measuring these temps? They are always identical.
* I have yet to do any major bumper to bumper city driving, but the oil temps have not gone above mid 190's F.
I'll contiue to monitor and see what I can see and post back.
Old 04-16-2013, 08:11 PM   #285
reeves
Exactly what I thought!
Apparently, there is no transmission temp sensor.. http://www.ft86club.com/forums/showt...650#post763650
Old 04-16-2013, 11:53 PM   #286
dave-
Drives: 86 GT
I got a V1.5 Super Mini ELM327 OBD2 OBD-II Bluetooth CAN-BUS Auto Diagnostic Tool for another car and find it really slow to update even after you play with the config in the app. Almost to the point that it is basically useless for live data due to the BT streaming.
dave- is offline   Reply With Quote
Old 04-17-2013, 12:18 AM   #287
Yruyur
Yruyur's Avatar
Looks similar to the one I have in my signature but I dont have those speed issues.
Sent from my GT-P3113
Old 04-17-2013, 03:08 PM   #288
zoomzoomers
So now I'm noticing that the intake temps vary a lot. I've now seen intake temps in the 90's, and I've even seen it in the 110's, and the engine oil temp reach 215 F. I wasn't even in dumper to dumper traffic. I can't say I yet know what I'm seeing, but I can say that these temps seem to vary by a wide range. I'll keep monitoring.
Old 04-18-2013, 10:29 PM   #289
zoomzoomers
So I got my first CEL and slip light today. Fault code U0073? WTH is that? SMH...
Old 04-18-2013, 10:41 PM   #290
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Which android are you using? The updates were very slow on my Samsung Sidekick, after I bought a Samsung SIII for my wife the refresh rate is fast now almost real time(0.1 second delay).
Looks bad
https://www.google.com/#output=searc...w=1280&bih=707
LeeMaster is offline   Reply With Quote
Old 04-18-2013, 10:51 PM   #291
xwd
It happens sometimes when you are using Torque and a BT adapter and keep torque running while the car is turned off and then restarted in a short period of time. I run into it when stopping at a gas station to run in and buy something or even pumping gas sometimes. Just clear it. If you exit torque it won't happen.
Old 04-18-2013, 11:22 PM   #292
zoomzoomers
That's exactly what happened! Glad to know it's nothing.
Old 04-19-2013, 12:34 AM   #293
dave-
Drives: 86 GT
HTC One X, could be crap bluetooth but don't have any other phones to try.
Old 04-21-2013, 08:18 PM   #294
Partial Stall
Drives: '13 WRB BRZ
I get this from time to time with the OBD adapter plugged in while I start the car. It's no big deal.
Partial Stall is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
