Old 04-03-2013, 01:55 PM   #15
Steve86
Steve86's Avatar
Drives: 2013 Argento FR-S
Originally Posted by Mandy View Post
Over 9000 RPMS!
I think you meant to post this in an RX-8 or S2000 forum somewhere.
Steve86 is offline   Reply With Quote
Old 04-03-2013, 01:56 PM   #16
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Full tank 3/4k ..... Under half a tank redline time
Old 04-03-2013, 02:00 PM   #17
Hardrock4445
Hardrock4445's Avatar
7395 at least once every trip. Because racecar.....
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 04-03-2013, 02:09 PM   #18
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
normal driving, usually around 3.5k. If I'm having to go from 2nd to 6th (90 degree right onto highway) I go all the way to 7k in 2nd then shift from 3rd to 5th, then 6th to settle in. If you ever get the chance shifting from 6th to 4th on the highway is the most fun way to get a speeding ticket ever....you can't not wind it out.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 04-03-2013, 02:25 PM   #19
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
Originally Posted by Sekal View Post
When my valves and seals start to begin blowing up.
You can tell this because the valves begin to float and not close completely so the engine gets kind of quiet for a fraction of a second, that's how you know when to shift for maximum performance!
But really, just when it seems right, probably 3,000-4,000 most of the time, although with the engine deadspot I tend to go more 4,000 plus. ANd of course at redline because it is more fun.
MTCRX is offline   Reply With Quote
Old 04-03-2013, 02:33 PM   #20
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Between 3-4 1/2 for me. I get about 29-32 mpg which is a nice tradeoff for higher revs
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 04-03-2013, 02:33 PM   #21
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I bounce the rev limiter at every shift and cruise at 6000rpms because I am really Ken Block behind the wheel FTW!
Scott
J/K. I'm old and drive an automatic which, according to some around here, means I can't drive and the disconnect to my car means I will inevitably crash it if I try to drive like the "experts" around here.
naikaidriver is offline   Reply With Quote
Old 04-03-2013, 03:01 PM   #22
DarkSunrise
DarkSunrise's Avatar
Upshifts:
- Hard acceleration/track/autocross -- 7000-7400 rpm
- Normal acceleration from stop -- 3000-3500 rpm
- Puttering around -- 2500 rpm
2022 BRZ Build
2013 FR-S Build
Old 04-03-2013, 03:05 PM   #23
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Just wondering, do you drop it from 6th to 4th or you just go from 6, 5, 4? I want to have fun lol(:
JohnAyySays is offline   Reply With Quote
Old 04-03-2013, 03:38 PM   #24
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
All depends on traffic. No one on the road, 4.5K. Need to get ahead of traffic, 6.5K and up. Stuck behind a slowpoke, 2.5K. Getting on the highway, Redline.
5hairpins is offline   Reply With Quote
The Following User Says Thank You to 5hairpins For This Useful Post:
husker741 (04-03-2013)
Old 04-03-2013, 04:59 PM   #25
6-Shift
Señor Member
6-Shift's Avatar
Drop from 6th to 4th. If you REALLY need the power you can actually drop into 3rd if you're going right around 60 but if you're going 70 4th is best. The process is put in clutch, press on the gas so it revs around 5.5k or so and then move over into 4th. Quickly let the clutch out before the revs fall and keep on the gas to maintain the revs. It's a super quick shift and the quick rev is necessary to make you not lurch as much as the clutch re-engages. If you have an intake/exhaust it sounds godly too. It's fun to experiment with downshifting and upshifting. If you can start to learn where the rpm's are at each mph, you can downshift and upshift much easier while being an overall smoother driver too. Hope I helped.
Old 04-03-2013, 05:07 PM   #26
Hanakuso
As high as I can without making the sensor trip out that leads to "Warning! Danger to Manifold"
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
Muaddib (03-10-2014)
Old 04-03-2013, 07:44 PM   #27
JohnAyySays
Thanks! Will definitely try this out! If I have any problems I'll PM you(:
Old 04-03-2013, 08:41 PM   #28
BMA
Drives: Twin Turbo
I am usually shifting b/ 3000-4000 rpm
BMA is offline   Reply With Quote
Saturday 3/23 DRIVE: Last chance to drive "The Most Dangerous Road in California" PMok Northern California 173 05-02-2013 03:11 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 09:30 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 02:11 PM
Shift Knob yomchi1989 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2012 10:19 PM
Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" Sport-Tech BRZ First-Gen (2012+) — General Topics 36 12-07-2011 04:13 PM
