Old 04-02-2013, 04:03 PM   #183
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Frs300 View Post
ya i ment bov sorry. im at work doing 100 things at once.
i was going to install my gauge pod that night. this dealership has done turbo/sc on trucks quite a bit. i should have drove to mn and had fullblown install it.
FullBlown you guys have the heads ready yet? i may need some lol
Wrong. You should have taken time off work, and let me help you install the kit over a weekend which is what I offered you in the beginning. I warned you that I would not let a dealer install the turbo kit:
Originally Posted by PM from King Tut
I am still more than willing to help. What kind of plan are you thinking? Dont trust the stealer.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
2forme (04-02-2013), powerj2 (04-02-2013), skatery1989 (04-03-2013)
Old 04-02-2013, 04:07 PM   #184
King Tut
NASA SpecE30 Racer
King Tut's Avatar
this is what fullblown told me. "I have seen the oring on the pump not fully seat and the car would still run but would lean our very bad when it starts to build pressure"
This is the problem I ran into when Visconti was tuning my car. I went from having perfect AFRs to leaning out at WOT. His solution was to install two O-rings instead of one and he had the part number to buy them from NAPA. I pulled my pump, installed the two O-rings and put it back together and my AFRs went back to perfect.
Frs300 (04-02-2013)
Old 04-02-2013, 04:10 PM   #185
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Supermassive ya i shouldnt have let them do it should have done it myself. i just didnt have the time to do it. i work weekends and everyone i know that was going to help works during the week so i said screw it and let toyota do it. big mistake on my part wont happen again. I will get it fixed and running again and call it a lesson learned a rather expensive one at that.
I am glad that you have learned your lesson. I am still here and willing to help you any way possible to get your car back and running. I can make a drive to PC and look over your entire kit install if you want. I can help you work on the motor should you decide to take this out of the stealer's hands.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Frs300 (04-02-2013), Sportsguy83 (04-02-2013)
Old 04-02-2013, 04:23 PM   #186
Frs300
Frs300's Avatar
Drives: Pile of junk
hell with the dealer. i took the car back from them.
just going to have fa20club drop built motor in..reinstall turbo and tune/dyno it and ship the car back. thanks for the offer though should have waited for you from the get go but me being impatient got the best of me and cost me big time.
Frs300 is offline   Reply With Quote
Old 04-02-2013, 04:25 PM   #187
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No problem man. I wouldn't mind seeing the car before you ship it off though. I hope FA20club works out well. I will be interested to see your results.
Old 04-02-2013, 04:28 PM   #188
Frs300
Frs300's Avatar
if you can come before friday you can look at it because thats when its getting picked up
Old 04-02-2013, 04:28 PM   #189
2forme
I don't even want to know how much that is going to cost....
Old 04-02-2013, 04:31 PM   #190
Frs300
Frs300's Avatar
its actually not that bad
Old 04-02-2013, 04:32 PM   #191
2forme
I'm a cheapskate (grew up poor). I have a hard time throwing around money over 2000$. LOL
The Following 2 Users Say Thank You to 2forme For This Useful Post:
ftc~brz (04-23-2013), Spd229 (04-16-2013)
Old 04-02-2013, 04:40 PM   #192
jamesm
toyota never bothered to see what springs the wastegate had in it. all they had in it was the blue spring which is 5.8psi. they went by what the box said was installed.
isn't that the correct spring for the application, 5.8psi? you'd want that if you plan on boosting 7-8 psi with a boost controller, i believe.
Old 04-02-2013, 04:44 PM   #193
Foobar
SLO NO MO
Foobar's Avatar
2K!? I know cheapskates and you sir are no cheapskate!
Sent from my Nexus 4 using Tapatalk 2
Old 04-02-2013, 04:52 PM   #194
Frs300
Frs300's Avatar
no i wasnt using a boost controller spring pressure only
Old 04-02-2013, 05:13 PM   #195
sw20kosh
Drives: 2013 Black FR-S
Doesn't matter what the spring was inside if the wastegate wasn't hooked up properly or if it was leaking or if the fuel pump o-rings were not sealing etc.
Old 04-02-2013, 05:15 PM   #196
jamesm
no boost controller at all? not even a manual? with no gauge! that's nuts.
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 05:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 05:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 11:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 10:24 PM
