| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#43 |
Drives: WRB BRZ
#44 | |
Smokin on Dat Endo
i.e. wax hood, wait a tiny bit, remove wax, on to the next section
| The Following User Says Thank You to eddieEndo For This Useful Post: | tuckdaddy (03-30-2013) |
#45 |
Because Racecar
Drives: 2013 Asphalt FRS
#46 |
Drives: SWP BRZ Limited
Should I still be waxing and clay barring if I had my car opti-guarded? And if so, would the procedure be any different then an non-opticoated car?
#47 |
Drives: '13 SSM BRZ Limited 6MT
just got my BRZ and will be doing my first wash. I"m thinking about doing it with these steps:
1. Wash with Meguiars Gold Class Shampoo 2. Claybar with Meguiars Clay Kit 3a. Wash with Optimum No Rinse Wash/Wax OR 3b. Wax with Eagle One Wax as you Dry In the future, i'm just going to use the ONR Wash/Wax only every other week and clay every six months. I'm trying to make the whole washing process simple and quick. |
#48 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
A few related things - I've been using the clay / wax routine for many years.
1. To know when to clay, put a thin plastic bag over your hand and very lightly rub the surface. If it feels rough, it's time to clay. 2. If your car is clean you can clay right over wax, no need to strip it or remove it. Use the detail spray and the clay will pull any contaminants right through the wax. The clay will not remove the wax (saves a lot of time). But you will have to re-apply a thin coat of wax wherever you clayed to fill in the 'pores' left by the removed contaminants. 3. If your clay ever falls out of your hand and touches the ground, throw it away. Not worth taking a chance on scratches to save a few bucks. 4. You can also use plain water as a lubricant for clay but it's better to use a detail spray as it has more actual lubricants in it and will keep any contaminants from scratching the surface. I use the cheap Meguiars spray and it works fine. And use plenty of it - if the clay 'drags' or leaves a residue, you are not using enough lubricant. Clay should just 'glide' over the surface with very little or no pressure. That's when it works the best.
"You'll never know if you don't try" - Shinroko Momose |
#49 | |
First 86
Drives: Scion FRS Argento Automatic
Life is short...NO BORING CARS |
#50 |
Drives: Whiteout FR-S MT
I finished claying my car in 30 minutes with this thing. Works just as good if not better than clay bar. Plus takes so much less effort! Look on YouTube for some directions.
[ame="http://www.amazon.com/Speedy-Surface-Prep-Fine-Grade/dp/B0091II8X8"]Speedy Surface Prep - Fine Grade : Amazon.com : Automotive[/ame] |
#51 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
It is a perfect example, as you mentioned, of a so-called expert having no idea. Seems like he has some magic "chemical" there though! .
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
| What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 355 | 05-01-2016 08:52 AM |
| User name | trueno86power | Site Announcements / Questions / Issues | 7 | 11-28-2012 12:48 AM |
| FRS ad - youtube user generated | Rotr8 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 09-16-2012 08:34 PM |
| New user, thinking about getting a BRZ | Mateo | BRZ First-Gen (2012+) — General Topics | 23 | 08-31-2012 07:59 PM |
