Old 03-30-2013, 09:17 PM   #43
cocoy_labuyo
Drives: WRB BRZ
Originally Posted by tuckdaddy View Post
Yes you can do that and depending on what wax you use anywhere from a month to every four to six months
I use mother's step 2 and 3. will that suffice?
cocoy_labuyo is offline   Reply With Quote
Old 03-30-2013, 09:21 PM   #44
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Originally Posted by chandz05 View Post
Well thanks for all the advice and suggestions guys! Car is finally buffed out. One last question: is there any way to soften the wax if it gets too hard? Buffing that crap out was a workout ha.
do it section by section way easier
i.e. wax hood, wait a tiny bit, remove wax, on to the next section
eddieEndo is offline   Reply With Quote
The Following User Says Thank You to eddieEndo For This Useful Post:
tuckdaddy (03-30-2013)
Old 03-30-2013, 10:13 PM   #45
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
yup that should be good. i use the same sort of system but with the adams products (lasts longer IMHO with deeper shine) :happy0180:
tuckdaddy is offline   Reply With Quote
Old 03-31-2013, 01:42 PM   #46
quasimoto
quasimoto's Avatar
Drives: SWP BRZ Limited
Should I still be waxing and clay barring if I had my car opti-guarded? And if so, would the procedure be any different then an non-opticoated car?
quasimoto is offline   Reply With Quote
Old 04-07-2013, 01:17 AM   #47
tracerit
Drives: '13 SSM BRZ Limited 6MT
just got my BRZ and will be doing my first wash. I"m thinking about doing it with these steps:
1. Wash with Meguiars Gold Class Shampoo
2. Claybar with Meguiars Clay Kit
3a. Wash with Optimum No Rinse Wash/Wax
OR
3b. Wax with Eagle One Wax as you Dry
In the future, i'm just going to use the ONR Wash/Wax only every other week and clay every six months.
I'm trying to make the whole washing process simple and quick.
tracerit is offline   Reply With Quote
Old 04-07-2013, 06:22 AM   #48
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
A few related things - I've been using the clay / wax routine for many years.
1. To know when to clay, put a thin plastic bag over your hand and very lightly rub the surface. If it feels rough, it's time to clay.
2. If your car is clean you can clay right over wax, no need to strip it or remove it. Use the detail spray and the clay will pull any contaminants right through the wax. The clay will not remove the wax (saves a lot of time). But you will have to re-apply a thin coat of wax wherever you clayed to fill in the 'pores' left by the removed contaminants.
3. If your clay ever falls out of your hand and touches the ground, throw it away. Not worth taking a chance on scratches to save a few bucks.
4. You can also use plain water as a lubricant for clay but it's better to use a detail spray as it has more actual lubricants in it and will keep any contaminants from scratching the surface. I use the cheap Meguiars spray and it works fine. And use plenty of it - if the clay 'drags' or leaves a residue, you are not using enough lubricant. Clay should just 'glide' over the surface with very little or no pressure. That's when it works the best.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 04-07-2013, 12:37 PM   #49
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
OR
Eagle wax as you dry is good to use every time you wash, but I would put a good coat of paint sealant on. Wax as you dry just doesn't last-I've used it for years as an in between maintenance wax which works well once you have a good base sealant or good quality wax underneath.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 04-07-2013, 09:48 PM   #50
kuma
Drives: Whiteout FR-S MT
I finished claying my car in 30 minutes with this thing. Works just as good if not better than clay bar. Plus takes so much less effort! Look on YouTube for some directions.
[ame="http://www.amazon.com/Speedy-Surface-Prep-Fine-Grade/dp/B0091II8X8"]Speedy Surface Prep - Fine Grade : Amazon.com : Automotive[/ame]
kuma is offline   Reply With Quote
Old 04-23-2013, 07:05 AM   #51
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by was385 View Post
I'm not going to take a side in the soap discussion, but just because they are paid to detail expensive cars, doesn't necessarily mean they know what they're doing. Ex: http://www.monkeysee.com/play/1571-c...iling-exterior
OMG that is the worst technique I have ever seen.
It is a perfect example, as you mentioned, of a so-called expert having no idea. Seems like he has some magic "chemical" there though!
nzer is offline   Reply With Quote
What does your user name mean? Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 355 05-01-2016 08:52 AM
User name trueno86power Site Announcements / Questions / Issues 7 11-28-2012 12:48 AM
FRS ad - youtube user generated Rotr8 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 09-16-2012 08:34 PM
New user, thinking about getting a BRZ Mateo BRZ First-Gen (2012+) — General Topics 23 08-31-2012 07:59 PM
