go_a_way1
Old 03-25-2013, 05:18 PM   #1037
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by D1cker View Post
It will not effect the outside diameter of the tire. You will be just fine with 215/45/17's on those wheels.
indeed
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
DR 86 (03-26-2013)
Old 03-25-2013, 05:38 PM   #1038
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Originally Posted by dori. View Post
correct me if I'm wrong but 235 on a 9.5 is a slight stretch, no?
235/35 is acceptable (by manufacturer) on 8 inch to 9.5 inch. So 9.5 inch will fit fine, but will be at the upper end. The pic above is a 215 on an 8 inch - which is also the max "allowed" size.
This is a "wide" 215 on another 8 inch wheel. Totally fits fine but that slope inwards is a mild stretch which you may or may not like.
This is a fat 235 on an 8 inch wheel, which is the minimum rim size. Fits fine.
If you had a tire with a weak sidewall (like the conti extreme contact) you'd want the mild stretch. A pilot super sport can go fat.
None of this stuff is the stupid crazy stretch you see on the Euro boards with the rim sticking out past the tire. It's just a balance of looks, sidewall strength vs how wide you want your contact patch. You can shoehorn a 215 onto 9 inch wheel if you want.
Khyron686 is offline   Reply With Quote
Old 03-25-2013, 05:51 PM   #1039
Skurj
Drives: SOLD...
If you are in Toronto.. you don't get enough snow to not lower the car, but I wouldn't go more than 1"...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 03-25-2013, 05:55 PM   #1040
Khyron686
Originally Posted by eddieEndo View Post
kk so i think i've settled on 225/40 on the front 8.5 and 235/40 on the rear 9.5, i'm a liiiittle worried about rubbing in the rear, think that'll work?
Crap I missed your rear number. Understand the /40 part is not a measurement, it's a percentage of the first number. So a 225/40 is a different sidewall (3.5 inches) height than a 245/40 (3.7 inches). (40% of 225 vs 40% of 245). So your wheels will be different size (slightly but you will notice!).
Also, 1 inch is 25mm so if the rear is 1 inch wider, the tire should be roughly 25mm bigger than the front if you want them to look similar.
225/40-18 is a good size for our cars. 255/35-18 is only .1 inches different which would be better for the rear (both will have exactly 3.5 inches sidewall). Now you have to consider what tire models are available in both sizes.
You can play around with sizing here:
http://www.miata.net/garage/tirecalc.html
Old 03-25-2013, 06:06 PM   #1041
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
so looks like i'll be doing 225/40 in the front and 255/35 in the back thanks for your help
eddieEndo is offline   Reply With Quote
Old 03-25-2013, 07:05 PM   #1042
itdansharpe
itdansharpe's Avatar
hmmm are both wheels gonna be stretched? trying to avoid stretched heard some horror stories
help me come up with a fitment for those wheels haha, I don't want stretch and i like my sidewall so probably sticking with 40
The rears are going to look stretched a bit more than the fronts.. I have 245s front on 8.5 and that's got a small bit of tire poking past the wheel.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 03-26-2013, 10:41 AM   #1043
philosophy
philosopher
Drives: '13 BRZ Sport-Tech CB MT
Fair, but I don't want to change springs because I hear that it damages the suspension in the long run, and hurts the handling (though I will be tempted to get STI springs if they come to Canada). I also don't want to get coilovers because I hear that they don't last in the salt. There is probably more salt in Toronto than snow.
If someone could prove me wrong about anything I've just said, it'd be greatly appreciated!
philosophy is offline   Reply With Quote
Old 03-26-2013, 12:35 PM   #1044
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by philosophy View Post
That was my worry. But it seems, from what is said here, that half an inch extra in diameter won't make a big enough difference. I sure hope not because it looks like I'm gonna get some 17x7.5's!
Go for it. STI uses the stock Michelin Primacy HP tires on their 17x7.5 +48 wheels:
Old 03-26-2013, 12:52 PM   #1045
OrbitalEllipses
Drives: Attitude
Yes, but STI will also sell you Michelin Pilot Super Sports for those wheels
Old 03-26-2013, 01:09 PM   #1046
switchlanez
Yeah, they recommend that tire for their 18x7.5 +48 wheels as does TRD for their 18x7.5 +46 wheels. I haven't seen them publish a recommended tire for the 17" version but their pics sorta indicate what they use.
Old 03-26-2013, 01:09 PM   #1047
OrbitalEllipses
Drives: Attitude
Just bought me some PSS anyway.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Huehuecoyotl (03-26-2013), switchlanez (03-26-2013)
Old 03-26-2013, 06:13 PM   #1048
djdnz
1337
Drives: 2013 BRZ WRB S/C
Any thoughts on
18x9.5 +45 f/r 255/35/18? Might put a 5 mm spacer on the rear
Looking for no poke at all.
edit: after looking at the mach-v wheels at 9.5 +42, sounded like it doesnt clear the spring perch... and I guess it's not as flush as I hoped
djdnz is offline   Reply With Quote
Old 03-26-2013, 06:17 PM   #1049
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by djdnz View Post
Any thoughts on
Rear should be perfect without a spacer
http://dudesphotography.smugmug.com/...IMG0071-XL.jpg 18x9.5 +44 with a 255/35/18 rear. Looks perfect
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
djdnz (03-26-2013)
Old 03-26-2013, 06:33 PM   #1050
djdnz
1337
Thanks man, yeah the rear looks spot on. I have a feeling the front will look more like this though :*(
I'm confused though, these are 18x9.5 +42, yet I've seen pictures of the Gram Light 57Xtreme's in 18x9.5 +40 and they don't seem to be as pokey. Maybe they have just been running more camber? I'd like 1.5 deg front, 2 MAX.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
