Old 03-13-2013, 05:57 PM   #141
2forme
Originally Posted by Coheed View Post
does anyone know the pulley sizes along with the psi they support? I'm at high elevation, and if this kit is considered for me I would like to see what options I have to make decent power with it.
Stock is 6 psi, there is also a 10psi pulley. Perrin has a 14 psi one, but it might be a one-off. That's all I've heard so far.
Old 03-13-2013, 06:31 PM   #142
skatery1989
Drives: BRZ Limited
Where are you at?
skatery1989 is offline   Reply With Quote
Old 03-13-2013, 08:00 PM   #143
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
octane limited
So. Biggest pulley got me 239.5whp and 190tq at 1500 feet altitude on 91 gas at 8.5psi, will post pics when I get home. I didn't have a tune for the medium pulley, but it got me 9.1 psi at same altitude so that the setup still has more to go. My limiting factor wasn't air, heck I can make 12 or 14psi, right now, tho it's only usable boost below red line without fuel that is more dense for my tuning needs. For those of us who are tuning for optimal operation at red line, I'm seeing detonation at higher rpms with my fuel at my altitude over my current boost level...still, next i will get perrins tune so this is the conservative setup from Vortech. I would be surprised if this number will change by more than a few percent, is the right number for what I am building, which needs to be able to take a beating on the track in triple digit heat. 250hp is a realistic target for me at 1500 feet on pumpgas at 9psi. That leaves room for mis shifts and oover boosting.Im not far off from where I can feel like im done. Can 250 be had at nominal cost from whet Im at? Those of you who want to push the limit can as more timing, more boost, is added, but for me without a way to bleed off pressure near redline or better gas, this isnt bad for a start.and pursue more power than i likely will without risking loss of my Vortech warranty. Surely you guys with 93 @ sea level may see few extra horses With time and more aggressive tune, and using the available air, perhaps e85 is on the menu for me after all. I don't see me going past 12 psi in the end that's pushing it for me, im already content where I am knowing this has allot of safety right where it is at. Future plans in life include testing a boost controller for more kick in the pants down low. Im not sure I want to try and use all 14psi. That m will mean more tire, and more budget over all. But it can be done. You can bet e85 will be played with, hello Visconti. Flex fuel with this kit is worth flying @Visconti into Phx.how many hp on e85 at 12 psi? How much at 14? 239.5 ok for my starting baseline
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
swift996 (03-13-2013)
Old 03-13-2013, 08:06 PM   #144
2forme
Visconti has noted that this kit doesn't make any discernable power between 91 and 93. He also mentioned that the 10 psi pulley didn't make much more power.
Where did you dyno it?
What other mods do you have, power wise?
What type of dyno?
Also, if you're getting detonation up high on the conservative tune from Vortech... you might want to hold off on the Perrin. Every Perrin Vortech dyno I've seen has knock up high.
Old 03-13-2013, 08:45 PM   #145
Calum
That Guy
Drives: 2013 asphalt FRS MT
What type of dyno?
More fuel to the fire that the compressor is running outside of its efficiency island up top. BOO. I'm still waiting to see final results, but I'm getting more and more un-excited.
Sorry gem, hopefully with a boost controller you can return to a safe boost level while keeping the low end.
Gem, what were your IAT's like at the top end with the smaller pulleys?
The Following User Says Thank You to Calum For This Useful Post:
2forme (03-13-2013)
Old 03-13-2013, 08:58 PM   #146
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Can you explain this? Perhaps by pointing out where on the dyno chart you are seeing it?
Amadeus is offline   Reply With Quote
Old 03-13-2013, 09:11 PM   #147
2forme
Sure,
http://www.ft86club.com/forums/showthread.php?t=30008
There are three different cars in that thread. Notice the difference in the smoothness of power delivery in the higher RPMs between stock and the PVK (Perrin Vortech Kit).
I think @Pete got the Perrin Vortech. Not sure if he ever ended up dynoing it, though. Never saw the results.
Old 03-13-2013, 09:25 PM   #148
Amadeus
Amadeus's Avatar
Here's Pete's Dyno from that thread.
http://www.ft86club.com/forums/showp...8&postcount=54
So you are suggesting that any dip in the tune (such as 6600 7100) is a knock? And that is discernable from just looking at a dyno chart?
Old 03-13-2013, 09:30 PM   #149
2forme
Usually a series of bumps up and down (especially on a smoothed map) would indicate the ECU detecting knock, retarding the timing slightly, then re-advancing. Unless the map was designed with a roller coaster timing advance up high lol, but I doubt that.
You can notice that the stock dynos don't really have these.
The Following User Says Thank You to 2forme For This Useful Post:
Amadeus (03-13-2013)
Old 03-13-2013, 09:38 PM   #150
skatery1989
Drives: BRZ Limited
I ran Perrins tune for a long time and never had any knock. Here is my dyno sheet with their tune. the max HP was with a aggressive tune they had. and none of the dyno pulls showed know on the logs.
Old 03-13-2013, 09:46 PM   #151
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by skatery1989 View Post
Where are you at?
I am in utah. Approx 4700ft from the suby's GPS.
There are a lot of things that can cause minor dips. It could be pulling timing, or it could be an anomaly. It depends how repeatable it is, but a datalog should reveal what is going on. Anything else is speculation.
Coheed is offline   Reply With Quote
Old 03-13-2013, 09:48 PM   #152
2forme
Agreed, but across 3 different cars that showed no anomalies on their corresponding stock dynos? Seems like a trend, at that point. Especially when non Perrin kits don't show the same.
Old 03-13-2013, 09:49 PM   #153
2forme
Attachment 30639
OK. What caused the dip you have at 6800? That's a pretty big dip (RPM wise).
Old 03-13-2013, 09:54 PM   #154
skatery1989
Drives: BRZ Limited
Colorado 5280ft. I am pretty sure thats timing being pulled away. Ill look and see is i still have a log I can post for you to see theres no knock. I have hundreds of them saved right now.
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 12:19 PM
Pete's Perrin Vortech build thread Pete Member's Car Journals 91 06-04-2013 01:38 AM
*PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) PhastekSport Forced Induction 425 04-26-2013 10:06 AM
