AVOturboworld
Old 03-07-2013, 09:56 PM   #2283
AVOturboworld
So I've been running the turbo kit for about 6000 miles now. Recently we stepped up the pace and have been testing and tuning at 8psi. This has brought power up to the 265-275whp range with 225-230ft/lbs of torque on 92 octane pump gas. It's a lot of fun. But a bit too much fun for the clutch, which is starting to slip in 6th gear on the freeway.
The car hasn't been babied - much - as all the drift practice videos can testify. I've also been doing a lot of dyno runs and other testing in various situations, so it's not exactly a surprise. But if you were interested in knowing where the limits of the clutch are, it's right about that 8~8.5psi point.
It's not stopping us, just will be taking it easy till the new clutch goes in.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
BRZranger (03-08-2013), Sportsguy83 (03-07-2013)
Old 03-07-2013, 10:16 PM   #2284
Blue86
Drives: Sonic Blue 86GT Manual
So it is still on a stock clutch?
Blue86 is offline   Reply With Quote
Old 03-07-2013, 10:17 PM   #2285
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Thanks for the feedback and a general guideline for the stock clutch. This seems to be right in line with what others have found.
cmss2000 is offline   Reply With Quote
Old 03-07-2013, 10:34 PM   #2286
AVOturboworld
Yes, it's been on the stock clutch for the last 6000 miles of turbo testing. On our stage 1, 5psi setup the stock clutch isn't an issue. It's only after pumping up the volume and running to 8psi (and past that...) that the issue comes up. It's quite wet here in the Pacific Northwest, so it's been rare to have dry pavement to test on - literally - over the last few months. So it would wheelspin (in every gear) before the clutch would give way. Today was a rare, dry day, and the power was going down good.
Old 03-07-2013, 10:38 PM   #2287
diss7
Drives: AE86, 2x GT86, TE27
diss7 is offline   Reply With Quote
Old 03-07-2013, 10:44 PM   #2288
alex48
Are you willing to share an approximate wait time at present? Just a month if someone was to oreder one today?
alex48 is offline   Reply With Quote
Old 03-07-2013, 11:08 PM   #2289
AVOturboworld
Keep in mind, I'm R&D for the kit. I can't give people advice on when to replace a clutch unless I slowly ramp up the boost and test it and find out exactly where it started spinning. Same for a lot of other components, like engine mounts that are fine at 5~6psi, but have too much movement at 7+ psi.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 03-07-2013, 11:10 PM   #2290
AVOturboworld
If ordered today, literally, probably 1st to 2nd week of April. We've moved a lot of staff over from other projects onto the BRZ and FR-S turbo kits, so production is ramping up to catch up to the current pre-orders and beyond.
Apex Chase (03-08-2013), BRZranger (03-08-2013)
Old 03-08-2013, 09:01 AM   #2291
Nazarite
0 RWHP
Nazarite's Avatar
Drives: 2008 Mazdaspeed 3
Originally Posted by cmss2000 View Post
I'm also hoping to avoid some of the other supporting mods that are needed (or useful) when you start making big power...suspension, driveline mods, oil coolers, fans, etc.
While supporting mods are the least fun to spend money on, it's almost never a good idea to skimp on them as the results of one or more of them failing will cost more to fix on the backend than if you'd just done it right to begin with. Plus, peace of mind is a heckuva thing.
Nazarite is offline   Reply With Quote
The Following User Says Thank You to Nazarite For This Useful Post:
civicdrivr (03-08-2013)
Old 03-08-2013, 09:45 AM   #2292
OrbitalEllipses
Drives: Attitude
People are fooled by price points. Yes a turbo kit only costs X amount, but you should be considering a clutch, injectors, fuel pump, mounts, etc. on top of the kit. Not saying anything about AVO or anyone else, but that's how this game has always been.
Huehuecoyotl (03-08-2013)
Old 03-08-2013, 02:16 PM   #2293
AVOturboworld
We picked 5psi for stage 1 not because of any limitations of the kit, but because of the limitations of the rest of the car. 5psi on Stage 1 with the stock exhaust, stock clutch, stock injectors is doable because it still stays within their general operating parameters. Stage 2 doesn't require any major upgrades to the turbo kit itself, it's just easing people in to the supporting hardware requirements.
And for something new, video of the day (I was working on getting the right gopro settings for in-car).
[ame="http://www.youtube.com/watch?v=eGfx7sirSvY"]AVO Turbocharged FR-S - short acceleration run. - YouTube[/ame]
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (03-08-2013), cmss2000 (03-08-2013), Sargy (03-08-2013), Sportsguy83 (03-08-2013)
Old 03-08-2013, 02:29 PM   #2294
buditjoenawan
Drives: Very very slowly
Increasing power beyond stock limitations will ALWAYS require other 'stuff'. It doesn't matter how you increase the power. AVO's stage 1 doesn't require a clutch, injectors, fuel pump, mounts, etc. on top of the kit. Same goes for Vortech's current offering, and if I may guess, Innovate's upcoming kit. All the kits above stay within stock limitations. So comparing price points and return on investment is absolutely fair.
-budi
buditjoenawan is offline   Reply With Quote
The Following User Says Thank You to buditjoenawan For This Useful Post:
Old 03-08-2013, 02:55 PM   #2295
OrbitalEllipses
Drives: Attitude
And I never said that they required those pieces. It's just a fact of modifying. You change one component and you must then change another...eventually. The car is a system, an organism if you will, so homeostasis has to be maintained.
Old 03-08-2013, 03:42 PM   #2296
Gen
Drives: Scion FR-S
Are you saying the engine mounts can't handle 7+ psi or are you simply using it as an example?
Gen is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
