Old 03-04-2013, 07:30 PM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
P(t) implies that power is varying with time. That's the problem with it. It is misleading for the case we are talking about.
If we're talking about a given fixed torque value and a given fixed rpm, P(t) = T*w is not the right way to express the equation for power. P = T*w is.
Old 03-04-2013, 07:32 PM   #30
BRZnut
Drives: BRZ DGM Limited
Good info, but back to a basic question I have always had...why does the FRS/BRZ have the dip at 4000 RPM and a peak at 3K and 5K??? Do other NA engines do this?? Is it a boxer thing?
Old 03-04-2013, 07:52 PM   #31
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I agree P(t) = T*w is incorrect due to its use of scalar constants on the right hand side. But P(t) = T*w is correct due to it being a vector equation. I get that it's unecessary and misleading. But misleading and incorrect are two completely different things.
Old 03-04-2013, 07:54 PM   #32
switchlanez
I think the peaks come largely from the way the direct injection is tuned. That's why I mention people should be thankful we have the peaks instead of complaining about the dip. Because one way to rid of the dip is to take away direct injection. Then torque will be weaker EVERYWHERE.
The Following User Says Thank You to switchlanez For This Useful Post:
Ocala FR-S (03-04-2013)
Old 03-04-2013, 09:08 PM   #33
GotM
GotM's Avatar
Drives: 14 Porsche Cayman S
I think when I read through the D4S literature this is what I gathered as to why this was happening. I will need to read though it again.
These types of dips are not unique to this car. I think you will find all engines have some unique signatures. Personally I like that this curve is rather flat except for the dip.
If you really think about, in a straight line pull you will only see this dip once if your goal is max acceleration. Once you shift you will always be past the torque dip. check out this link to see how each shift falls past the torque dip in each gear.
http://www.ft86club.com/forums/showthread.php?t=24456
If you look into the date that created these graphs. The torque dip lasts about 0.68 seconds.
On a track, this may or may not make a difference.
Previous cars:
2013 Subaru BRZ (2012-2017)
2009 BMW135 6MT (2009-2012)
1999 BMW M Roadster (2000-2010)
2004 Audi A6 2.7T (2004-2007)
Last edited by GotM; 03-04-2013 at 09:37 PM. Reason: Added line on how long the torque dip lasts
GotM is offline   Reply With Quote
Old 03-05-2013, 07:32 AM   #34
ZDan
ZDan's Avatar
Drives: '23 BRZ
If the right-side terms are vectors, that doesn't make them time-dependent. Vectors can be constant or time-dependent just like scalars. Dot product of two constant vectors is a non-time-dependent scalar, so still shouldn't be P(t) = T dot w.
So they I get that it's unecessary and misleading. But misleading and incorrect are two completely different things.
The representation is wrong for our case.
Can you link me to where you got it? I'd like to see the context.
Old 03-05-2013, 08:18 AM   #35
GotM
GotM's Avatar
Wikipedia search - Power(physics) specifies it this way.
Previous cars:
Old 03-05-2013, 01:37 PM   #36
sol740
You've all certainly wasted a function of my time to tell my brain in nerd what my ass knows in car.
N/A 4 banger is slowish.
sol740 is offline   Reply With Quote
Old 03-05-2013, 03:46 PM   #37
Saab2Frs
Drives: 2013 Hot Lava Scion FRS
So much for "simple" explanation with everyone busting out their physics.
Saab2Frs is offline   Reply With Quote
Old 03-08-2013, 02:24 AM   #38
Dazza
Dazza's Avatar
Drives: Tornado Grey Toyota 86 GT
After reading this thread I just realized I am dumb.
I'm just really pleased I can read and wright (even if I can't spell )
Dazza is offline   Reply With Quote
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
A not so simple question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 10 01-18-2013 08:40 PM
Simple blinker mod, nice look Carban Cosmetic Modification (Interior/Exterior/Lighting) 7 09-29-2012 08:09 PM
Simple Question! Spencer Strayer Scion FR-S / Toyota 86 GT86 General Forum 0 09-09-2012 06:53 PM
simple tires? jarviz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-02-2012 03:43 PM
