AVOturboworld
Old 02-19-2013, 11:25 PM   #2227
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Originally Posted by Huehuecoyotl View Post
is there any way to oil the turbo without the extra oil pump? cant one elect to use the cars oil pump pressure?
The scavenge pump is for the oil return... not the feed. It returns the oil from the small resivour under the turbo to the head/block.
Same style pump as used on the factory turbo F engines.
The feed is still fed by the usual pressure from the block/factory pump.
JP is offline   Reply With Quote
The Following 2 Users Say Thank You to JP For This Useful Post:
Huehuecoyotl (02-20-2013), Sportsguy83 (02-19-2013)
Old 02-19-2013, 11:45 PM   #2228
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by vubaru View Post
Got a text from the fiance while at work today at about 5 PM. "The turbo is here."
Thanks Paul and Ross! I'm talking with WORKS about installing and tuning this beast then it's dyno time!!
More pics, reviews comments PLEASE!
Old 02-20-2013, 12:18 AM   #2229
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by DriftEightSix View Post
Can't wait for this result!
What size exhaust are you running?
2.5" Perrin.
nix is offline   Reply With Quote
Old 02-20-2013, 03:14 AM   #2230
sw20kosh
Drives: 2013 Black FR-S
I live in SF! =) May I please come take a ride in your beast when it is all up and running properly? I am really interested in getting this kit but want to experience it first hand before $$$ plunking.
Old 02-20-2013, 06:26 AM   #2231
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by nix View Post
2.5" Perrin.
Would the kit benefit from going any larger?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-20-2013, 12:18 PM   #2232
Alienate
Drives: 2013 Scion FRS
I am not an expert, but Paul told me the 2.5" is fine. I have his kit installed on my FR_S in anticipation of the Stage TWO in the next month or so.
BTW, it sounds great.
Bigger is not always better. (which I tell my wife alot)
Scionara to you
Alienate is offline   Reply With Quote
The Following User Says Thank You to Alienate For This Useful Post:
DriftEightSix (02-20-2013)
Old 02-20-2013, 12:24 PM   #2233
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I'd never have anything less than a 3" exhaust on a turbo kit, less restriction the happier the turbo is. More power, faster spool.
Tansey86 is offline   Reply With Quote
Old 02-20-2013, 07:27 PM   #2234
nix
nix's Avatar
Drives: AVO BRZ
Nope this turbo will max out before it makes enough power to need a 3" system.
The Following User Says Thank You to nix For This Useful Post:
Old 02-21-2013, 02:19 AM   #2235
sw20kosh
Yes. Warning: the suspension is pretty stiff.
Just an update, WORKS Tuning in Sonoma, CA will be installing and dyno tuning my kit next week. The car goes in Monday. Hopefully I'll have some numbers to post by the end of next week but I don't want to get my hopes up!
It's a Stage 1 kit + BOV + ceramic coating with a headerback 2.5" (internal diam.) throughout exhaust already on the car. I'm hoping for 250 WHP, but I think that's optimistic on CA 91 Octane. I may see if WORKS can do a tune at 93 or > octane on a switchable map but I don't know if they have that capability.
@86_ZN6 gave me a great idea. I'm going to try out that WORKS panel filter too since the AVO kit keeps the stock airbox, but I wonder if the stock fuel system can keep up...
Your build thread says RCE yellows... Thats not stiff! I have had stiff suspension and my RCE yellows are plush. =) GOod luck with everything! Where do you live?
Old 02-21-2013, 03:57 AM   #2236
Sportsguy83
Drives: Limited BRZ
I would advise against an oiled filter when the MAF sensor is so close to it, moreso on a turbo setup.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
JP (02-21-2013)
Old 02-21-2013, 02:15 PM   #2237
Alienate
Nice man!! Do you have any pics up or a build thread?
Paul also told me that 2.5" is fine, but remember if you have a Hi-flow cat or 'test pipe' you need to get a "tweaked" base tune and find a local tuner ASAP.
I got lazy and paid my mechanic friend with a lift a few bucks to install it.
Took less than 30 mins and fit fine. no pics. I got the one without the resonator.
BTW, i got a very nice drop in hi-flow air filter ( dry ) from Apexi.
HAH! I just realized you think I got the turbo kit... NO. just the Exhaust kit.
Scionara to you
MSTiFK8R (02-21-2013)
Old 02-21-2013, 04:20 PM   #2238
diss7
Drives: AE86, 2x GT86, TE27
Seems to be some misinformation in some of the above few posts about exhaust size considerations with this kit.
To clarify...
The system will make more peak power with a 3" exhaust instead of a 2.5" However, only marginally.
BUT, this will be at the expense of low down power and spool. The turbo will NOT spool quicker with a 3" exhaust, over a 2.5" exhaust.
For the minimal top end gain, for the expense for low down power/spool, it is not advisable to choose a 3" system over a 2.5" system FOR THIS KIT.
On a similar point, where others have commented that the turbo will run out of power before a 2.5" becomes restrictive, this is basically true. What they are meaning is that a 2.5" exhaust system does not become significantly restrictive when compared to a 3" system at the power levels this turbo turbo is capable of. It's not like it reaches a magic point where one is better than the other, its like 90% of things on cars, its all about compromise.
The more boost this kit is running, the larger the peak HP difference will be between a 2.5" system and a 3" system, but the 2.5" will ALWAYS be better for this kit in a daily driven setup.
If you are track racing the car, a 3" system is probably a better choice for you, BUT, then you really have a mismatched exhaust system/turbo kit, and I would advise looking at a different turbo kit if you are chasing peak power.
Remember, dyno's are done are full throttle. And even worse, some people only focus on the peak power on a dyno graph. How often do you drive the car at full throttle, and at max revs on the street?
In short, a 2.5" exhaust system is perfectly mated to this turbo kit power delivery.
(FWIW, if you seriously believe a larger exhaust would help spool and low down power, then take the exhaust system off from the turbo back and go take it for a drive)
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
Alienate (02-21-2013), JP (02-21-2013)
Old 02-21-2013, 05:05 PM   #2239
Tansey86
Tansey86's Avatar
350rwhp or less 2.5 will be fine
351rwhp and more id suggest 3"
You will see a gain in power and a gain in spool. I've seen a gain of up to 50rwhp in a turbo setup by removing a cat, you dont want any restriction in a turbos exhaust. Thats why high HP cars have about 1 foot of exhaust and exits right off the side of the engine.
Old 02-21-2013, 06:08 PM   #2240
diss7
Removing a cat is not what we're talking about.
You don't want any restriction for peak power, this is why high HP cars have as little exhaust as possible. But back pressue helps spool turbos. When you're talking high HP, using a smaller exhaust to create back pressure to generate spool sooner will act as a massive restriction on peak power.
This is not the case for this setup.
Edit - Prove to me with dyno graphs showing the same car running the same turbo setup, the only difference being a bigger exhuast, that shows the larger exhaust helps spool. Until then I still call BS.
Is a 2.5" system going to be a significant restriction on this kit? No its not. So, use it, as the smaller piping will create more back pressure to help the turbo spool sooner.
Alienate (02-21-2013), Tansey86 (02-21-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
